  88 V6 Throttle Body Idle Screw
88 V6 Throttle Body Idle Screw by fgt1988
Started on: 10-20-2018 09:55 AM
Replies: 9 (1247 views)
Last post by: fgt1988 on 10-23-2018 08:59 PM
fgt1988
Report this Post10-20-2018 09:55 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know if all of the V6 Throttle Bodies Idle screws were all same design STAR key ? I had mine bored many years ago and never thought of looking at it until recently when I went to adjust and realized it is a FLAT screwdriver type - Wasn't sure if it was replaced by someone or did any came like that from factory? An 87 GT I looked at not long ago had the STAR key screw --- If it was replaced then they surely messed me up on the factory spec adjust and i ll need to get that corrected -
Report this Post10-20-2018 10:02 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hard to know for sure, because they are supposed to be not visible......but the few I have seen were all slot screw heads.
fgt1988
Report this Post10-20-2018 10:06 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
That s interesting but you are correct it is hidden deep in the socket hole and if I recall from factory the hole was sealed so no one would mess with the idle control screw -
fierosound
Total ratings: 286
Report this Post10-20-2018 01:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there something wrong with your idle speed?
fgt1988
Report this Post10-20-2018 08:09 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes i think it is out of its normal setting- I had my OBD1 doing data programing and my idle is running around 1100 when warm and no vacuum leak whatsoever
I had brought it down a bit by adjusting the screw but I had to question this funny adjusting screw which Im not sure if factory or was the original lost and someone put a different in there - Just a guess as I have no proof of anything. .....
fierosound
Total ratings: 286
Report this Post10-21-2018 01:48 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just helped a friend who had the same problem with a Fiero he just bought.
Try this:
Get engine fully warmed up. Shut off engine.
Jumper the ALDL connector.
https://www.fiero.nl/cgi-bin/main.cgi?ECMCodes
Turn key ON, but do not start engine.
After 30 seconds, unplug wiring from IAC motor. (#8 in diagram)
Start engine now (ignore flashing Check Engine light).
Turn adjustment screw until engine idles at 800rpm.
Shut off engine, remove ALDL jumper and reconnect IAC motor.
The ECM should now idle engine at proper RPM unless there is something else wrong.
[This message has been edited by fierosound (edited 10-22-2018).]
fgt1988
Report this Post10-22-2018 09:43 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yup I had seen this process before and performed it once or twice - Appreciate you providing it here and surely others can use it as well - A refresher never hurts especially as we get older -- Thx a bunch -- -
fierosound
Total ratings: 286
Report this Post10-22-2018 07:59 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
It may be another item then, like the MAP...
Report this Post10-23-2018 12:40 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fix whatever then Screw reset in my Cave, Idle Stop
fgt1988
Report this Post10-23-2018 08:59 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good Info -- Thx.....
