  Pulse windshield wiper switch repair
Pulse windshield wiper switch repair by 30+mpg
Started on: 11-09-2018 04:47 PM
Replies: 2 (178 views)
Last post by: 30+mpg on 11-09-2018 05:14 PM
30+mpg
Total ratings: 97
Report this Post11-09-2018 04:47 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
The wipers on my 86 2M4 would only run at low speed. All other positions were inoperative.
The pulse switch is no longer available.
Sooo, with nothing to lose, I remove the wiper switch.
By drilling & Dremeling the long rivets disassembly is achieved.
Using a multimeter to check continuity, open circuit is found between a rivet and the white power wire's copper end terminal.
A small bit of flux & solder closes the circuit.
Next a check on the other end of the same rivet revels the same lack between the rivet and the copper base plate. Solder again fixes the problem.
Next I swing the copper arm ( seen in bottom of above photo) back into its recess and solder the rivet head to the arm.
Reassembly by placing small glob of solder on each of the rivets where material was removed holds the switch parts firmly together.
Continuity test show all switch positions working properly.
After reinstallation of the switch and reassembly of the tilting steering column (that was the hard part), the switch works like new!
[This message has been edited by 30+mpg (edited 11-09-2018).]
wftb
Report this Post11-09-2018 05:04 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write up.
30+mpg
Total ratings: 97
Report this Post11-09-2018 05:14 PM Click Here to See the Profile for 30+mpgSend a Private Message to 30+mpgEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW 12 contact points on the resistance coil should give the wipers 6 or so intermittent delay speeds.
