  Remove gas from gas tank?
Remove gas from gas tank? by ricksmastermix
Started on: 11-10-2018 02:06 PM
Replies: 7 (879 views)
Last post by: Fiero2m4Fastback on 11-19-2018 02:33 PM
ricksmastermix
Report this Post11-10-2018 02:06 PM Click Here to See the Profile for ricksmastermixClick Here to visit ricksmastermix's HomePageSend a Private Message to ricksmastermixEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the best (Easiest) way to empty the gas tank? I have some bad fuel.
Thanks.
Report this Post11-10-2018 03:28 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Detach the fuel line at the fuel filter. Jumper the ALDL connector to run the fuel pump. (A to G)
Report this Post11-10-2018 07:04 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much? How "bad"?
< ¼ even < ½ just fill w/ new and run until near empty.
If tank etc let water in and now have water/ethanol on bottom then try draining like above. But that won't drain last ~ 1 to 1½ gallon.
If you want near dry empty... carefully remove big fill hose and/or smaller fill vent hose on back of tank and siphon. put car level to nose up to get more of "bad" gas and water.
You may have to replace the hose doing this.
⚠️ Warning: Above Jump A-G is wrong. That will Short the Power Line to FP to Ground.
Put Power to ALDL G to Run the FP.
Use Light Bulb or Meter to G and Ground to watch FP Relay working when FP is quite or dead.
[This message has been edited by theogre (edited 05-21-2022).]
fgt1988
Report this Post11-11-2018 09:56 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had to do this not long ago and what I did was disconnect the inline going to the fuel filter and got myself a siphon pump from Harbor Freights and plug it in that line and start pumping onto a bucket took me about an hour to fill up about a 5 gallon jug and then I just added some good fuel in the tank to balance it out a little and run the car for a long time enough to get it low enough where you can fill up once more with good gas and voila ....
css9450
Total ratings: 86
Report this Post11-12-2018 08:20 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have one of those Motive Power brake bleeding pressure bottles; I used it to pressurize my Fiero tank and drained most of a nearly-full tank using it.
I ran the hose from the pressure bottle into the Fiero fuel filler, and I used a second hose to drain gas out from the vent hose opening at the tank I used rags to seal all around both openings. It took awhile but worked great. I sat on a lawn chair next to the car and pumped often to keep the pressure up.
Fiero2m4Fastback
Report this Post11-17-2018 11:39 PM Click Here to See the Profile for Fiero2m4FastbackSend a Private Message to Fiero2m4FastbackEdit/Delete MessageReply w/QuoteDirect Link to This Post
Adding heet should help make the fuel reabsorb the water/ethanol. Getting as much out as you can as suggested then running heet should really help.
[This message has been edited by Fiero2m4Fastback (edited 11-17-2018).]
Report this Post11-18-2018 10:36 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
My post here mainly covers "stale gas." If you have ethanol problems then again using FP doesn't help but remove most gas so can drop and dump the tank or whatever to remove the water/ethanol at bottom.
Heet, DryGas, etc does not help when you have ethanol problems. 12oz bottles of Methanol/Isopropyl are only to help for Small amounts of water in the tank and lines to stop water freezing in winter. Adding more "Dry Gas" is often bad and can wreck the car because both alcohols are stronger solvents then ethanol. ("Dry Gas" includes all brands and Christy DryGas.) This is why most cars say will take up to 10% Ethanol, 5% Methanol, and now "banned" 10-15% MTBE. If the Owner books say anything else is often to say other alcohols and most gas additives are "banned" by the manufacturer and can void your warranty.
You can't use the FP to remove water in the tank. Water sinks to bottom and FP inlet can't suck down the last ~ 1gal depending on system design. More so when FP lives in baffles like Fiero because often the baffles add more clearance to the tank bottom. Even more when FP is install higher than designed as many replacement FP are.
Your only help is to try a small flexible siphon that reaches the bottom and park Fiero nose up so water will move to back. Even then likely can get all of it but maybe "Dry Gas" can do the rest. I won't count on that even then.
Fiero2m4Fastback
Report this Post11-19-2018 02:33 PM Click Here to See the Profile for Fiero2m4FastbackSend a Private Message to Fiero2m4FastbackEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Fiero2m4Fastback:
That's factually incorrect.
