  What the heck are these?
What the heck are these? by Habanera Hal
Started on: 12-25-2018 01:05 PM
Replies: 11 (500 views)
Last post by: Tony Kania on 12-27-2018 08:58 PM
Habanera Hal
Report this Post12-25-2018 01:05 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pulling my interior apart for refurbishing. Took off the ECM cover/armrest and removed the passenger seat and found these two cables with red and green connector ends. What are they?
Edit: Sorry, can't seem to get photos to load. Cables appear to be factory, one long one coming from ECM ends with the red connector. Short one attaches under seat bolt ends with green.
[This message has been edited by Habanera Hal (edited 12-25-2018).]
Habanera Hal
Report this Post12-26-2018 03:01 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let's try again:
Report this Post12-26-2018 03:22 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where's other end of long one?
Is not factory to ground anything to chair hardware or other wire simply pass thru firewall.
Report this Post12-26-2018 03:23 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are not stock, so they could have been for anything, but most likely for an alarm or amp.
steve308
Total ratings: 58
Report this Post12-26-2018 03:23 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ejector seat power source!
cvxjet
Report this Post12-26-2018 03:38 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
>>Ejector seat Power<< ...........BINGO!!!!! (Missing the optional C4)
Back when I was very young we had just seen Goldfinger with that fancy Aston Martin...My Father bought a 64 T-Bird which had a whole bunch of switches for this and that....My Mom stated she was afraid that at some point she would hit a button for the ejector seat....(That was the Best T-Bird ever)
Report this Post12-26-2018 06:03 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking hookups for an aftermarket amplifier.
Chris Eddy
Report this Post12-26-2018 06:48 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The connectors are Anderson Power Pole.. good for high currents. Never used by the factory, and usually just industrial use. My guess is a plate amp, which takes a lot of Amps.
Habanera Hal
Report this Post12-26-2018 09:16 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, guys! I was certain they were factory because of the way it came out of the firewall.
Rickady88GT
Total ratings: 200
Report this Post12-26-2018 09:23 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely not stock, and certainly heavy current. Could be anything?
Sorry to repeat others but....
Habanera Hal
Report this Post12-27-2018 06:51 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, they were apparently for a plate amp the PO had installed and removed when sold, leaving the hook ups. As I'm adding after-market PWs and PDLs, it's a convenient place to pull power from.
Tony Kania
Total ratings: 305
Report this Post12-27-2018 08:58 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks to be well made.
