  Materials of construction?
Materials of construction? by RussellCupples
Started on: 04-27-2019 08:36 PM
Replies: 14 (881 views)
Last post by: cvxjet on 04-29-2019 12:11 PM
RussellCupples
Report this Post04-27-2019 08:36 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen You Tube videos saying that the frame was made from Magnesium and some more that said it's cast iron . Which is it . I am trying to learn all I can about these cars since I a newbie owner of 2 of these great cars . I have always wanted one since the 80's and finally acquired 2 .One I am leaving stock and the other I am wishing to play around with . So I will probably be asking some stupid questions and I hope you great people will have some patience .
Report this Post04-27-2019 08:40 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Time for you to get off YouTube!! The correct answer is good 'ol sheet metal......STEEL.
[This message has been edited by Gall757 (edited 04-27-2019).]
RussellCupples
Report this Post04-27-2019 09:24 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lmao .Your right Sir . LOL .Not cast just straight up good materials right ?
Report this Post04-27-2019 10:01 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
well, pretty good material. As you can see by the photo, they rust easily, and that is an issue.
RussellCupples
Report this Post04-27-2019 10:08 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
It certainly don't look cast or Magnesium to me .
Report this Post04-27-2019 10:30 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero spaceframe, front and rear cradles and doors are steel. The spaceframe has certain stampings that are made of high strength steel alloys and are difficult to drill into, particularly the large crossmember across the lower front of the engine bay and the fuel tank tunnel.
To promote corrosion resistance (they really don't rust easily) the entire assembly was spot welded together, then cleaned and passivated in a multistage dipping operation, and then electropainted by dipping into an electrically charged tank of paint. The process completely encapsulated the welded up spaceframe (even in the areas of overlapping stampings and inside the A pillars) in a very corrosion resistant paint coating.
cvxjet
Report this Post04-27-2019 10:33 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Underneath the plastic body, the space-frame is regular sheet steel......The only magnesium that I know of was the rear deck grill on the 1984s. My 85 Fiero only has surface rust but I live in CA where salt is not dumped on the roads in the winter.
Spoon
Total ratings: 61
Report this Post04-27-2019 10:49 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
This should get you excited!!!
https://www.youtube.com/wat...ue=451&v=bxdFWFDT3qs
Spoon
RussellCupples
Report this Post04-28-2019 11:11 AM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to thank CVX and OleJoe for your very informative responses .I now feel enlightened and now know what I can and can't do to my chassis . TY
RussellCupples
Report this Post04-28-2019 07:48 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
RussellCupples
Member since Mar 2019
I've talked to a bunch of people that says the Fiero is a Magnesium chassis . According to the pic posted on here I don't see a drop of magnesium .Yet another wide spread lie or misinformed about the Fiero . I have heard a lot of lies about the Fiero . It's amazing that Fiero lasted the 4 years it did with this many uninformed or non truths said about the poor lil cars . The more I learn the more I like them period .
Report this Post04-28-2019 09:37 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
No magnesium in the chassis... it is stamped sheet metal.
5 years of production: 84, 85, 86, 87, 88
Report this Post04-28-2019 09:54 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I must say that I've heard a lot of less than factual tales about these cars, but the cast magnesium story is a new encounter.
Trust this site for accurate and factual information on these fine automobiles!
cvxjet
Report this Post04-29-2019 12:24 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes....We hear on this sight all NO the reel facts about the Fiero.....Like that only the GREEN Fieros had a fire problem- ALL of them caught fire and burned...and that is why you never Cee a (Factory)green Fiero!
(Be careful to filter what you "Here" about the Fiero.......)
(Oh and did you know that A) Magnesium is rarely used in cars because of it burning at high temp and creating extinguishing problems...But that B) They now have an alloy that is non-flammable....So we could have Magnesium wheels that would weigh....say 8-10 lbs for a 16 x 7 size?)
[This message has been edited by cvxjet (edited 04-29-2019).]
armos
Report this Post04-29-2019 09:49 AM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen some people on the internet say that the Fiero's frame is plastic. Of course those aren't car people, but they watch cars on TV and they slept in a Holiday Inn last night.
The slightly smarter people think it's a rebodied Chevette.
It's kind of sad that the way the Fiero was constructed made it stronger, safer in a crash, heavier, and more expensive to build -
but the common perception has always held that it's flimsy and a death trap.
So from a marketing standpoint, nothing was accomplished.
If that's what people were bound to think anyway, then GM might as well have made it a standard unibody. Would have at least been lighter and cheaper that way.
cvxjet
Report this Post04-29-2019 12:11 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Three big problems that were insurmountable for the Fiero; A) The magazines after 1985 were on the take from Toyota (Read R&T and MT road tests of 85 GT, then read any later road test in any mags- Car & Drivel was the worst- it was so blatant!) B) That first year, they had the fire-situation in a total of 5000 of the the 110,000 made- and only 260 caught fire; That doesn't sell Newspapers tho, so at one point they were claiming "One in Twenty Fieros had caught fire!!!!!!!!!!" and the last big problem; C) Chevrolet did not want competition for the Vette....Hard to imagine the Fiero being comparable, but then the early C4s were not that good....Too bad they could not understand the "Stepping-stone" concept of buying a cheaper, lower performance car first, then later getting the "Big boy" when income finally opened the door.
