Just dropped this gas tank from a 1986 GT that I bought about 6 months ago. PO said that the old tank had rusted and he couldn't find a stock tank so had this one built by a guy in Florida (said it cost about $800). Was considering putting it into my other car, but when I looked at the top of the tank (sending unit area) found that it doesn't have the lock ring design used with stock gas tanks. I haven't taken it apart, but it appears that the sending unit it secured by five screws and that the opening in the tank may not be large enough for a stock sender/fuel pump. The car has an external fuel pump (noisy) and the supply side is attached to the lower port in the rear of the tank (has a plug in it while being removed). Does anyone have any experience with this tank and, if so, do you know if the tank can be adapted for a stock sender/pump?
Sender on top of the tank.
![](https://images.fiero.nl/2017/GT1_1.jpg)
Better picture of sender
![](https://images.fiero.nl/2017/GT2_1.jpg)
Tank viewed from the passenger side.
![](https://images.fiero.nl/2017/GT3.jpg)
Rear of tank showing all ports.
![](https://images.fiero.nl/2017/GT4.jpg)
Front of tank from passenger side.
