| quote | Originally posted by sdgdf: Thanks for the ideas! That all sounds like possible issues.
I posted here before going to bed and wasn't very clear, P0151 appears to be bank 2. Does that mean EGR isn't on this side?
Any advice for dealing with the injector spider? Get an injector and change them around to see if 1 is bad? Run an injector leakdown test? Use a scantool and look at fuel trims as its running or something? I've never believed in injector/fuel system cleaners or services but maybe that could help?
Also, are you saying there's 2 or more MAFs? There's just 1 intake, and a V6 Fiero only has 1 MAP sensor??? This might have more? |
I have had several 4.3s (1 even in a Fiero) and a L31 Vortec 350 for about 9 years... so I know these engine quite well.
EGR tube connects to Bank 1 (cylinders 1, 3, 5), so if the issue is Bank 2 it won't be EGR tube related. Here is a pic from one of my engine way back when. This shows the EGR tube running down the intake and connecting to the driver side (Bank 1) exhaust manifold.
It isn't MAF, MAP or Fuel pressure related as all of those are single components and support both banks. Only seeing the issue on one bank, means it is something specific to that individual bank. I fixed my typo as I meant to say swap the upstream O2s not MAFs.
Fuel trims are only bank specific, so the scan tool will only show Bank 2 being very lean, which you already know. That is pretty much the extent that computer diagnostics will get you unless it is also saving an individual cylinder misfire code.
Beyond that, you will have to do physical troubleshooting.
O2 sensors can be swapped from bank to bank (you should have 4 O2 sensors, 2 per bank, with 1 before the catalytic converter and 1 after). You would want to swap the O2 sensors that are in front of the cats.
O2 sensors signal wire should be checked for continuity and resistance.
Exhaust leaks you can normally hear and normally show a carbon dust pattern near the leak.
Vacuum leaks can also be heard with an automotive stethoscope or hose to ear technique.
Ignition components on Bank 2 should be checked - plugs, plug wires, distributor cap etc...
The best way to check the Injector spider is to pull the upper intake off. Most of the inside surfaces should be black from carbon build up. If one of the poly lines is cracked or leaking, the fuel spray will make a clean spot on the intake surface. Disconnect the coil wire to the distributor, remove 1 poppet valve at a time and have a friend crank the engine over. You want to verify clean spay and once the engine is off, no dripping. Do this for all 6 and try to notice if one is spraying less fuel than the other. This test sprays fuel into the air, so no flames, sparks, or smoking while doing this.
If you find an issue with the injector spider, or it hasn't been replaced in the last 5 years, it would we good to replace it and upgrade it to the newer version that moves the injector bodies to the poppet valve locations and eliminates the poppet valves. The upgraded version looks like this, but isn't cheap.
[This message has been edited by fieroguru (edited 05-11-2019).]
