  Vapor canister filter - anybody replace filter media?
Vapor canister filter - anybody replace filter media? by Kitskaboodle
Started on: 06-14-2019 08:58 PM
Replies: 9 (988 views)
Last post by: theogre on 06-19-2019 01:04 PM
Kitskaboodle
Report this Post06-14-2019 08:58 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
While thumbing through the latest Fierostore catalog, I happened to see that they sell a flat, white round filter thingy for the vapor canister filter. I assume we are talking about the black “soup can” that’s next to the cruise servo module? If so, you can replace the filter element in it? I thought the soup can was a sealed unit. Anybody ever replace the white disk filter inside of it? Pics please if you have them as I have never even taken mine off.
Thanks, Kit
Report this Post06-14-2019 09:31 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not the soup can.....it's next to the air filter on the diver side fender......I wouldn't know when to change the filter tho.....
Total ratings: 465
Report this Post06-14-2019 10:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The filter for the vapor canister is more under it than "in" it.
css9450
Total ratings: 87
Report this Post06-14-2019 10:43 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
On a different car (not a Fiero), I looked high and low for a change interval, and never found one.
Report this Post06-14-2019 11:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
EVAP has 2 small vac lines and 1 "gas line" to vent the fuel tank.
That filter Is Not the EVAP media. That is loose active carbon.
Filter only block big crap trying to plug up the EVAP can and is in the bottom of the can.
Fram BA3865 is/was common filter for Fiero but likely discontinued because Fram site said "NOTES: 1. Use until inventory is depleted." Fram etc Is basically stamped cut of quilt batting. OE was stamp cut of fiberglass batting.
code:
Product Specs
Height 0.5
Outside Diameter 4.156
You don't need one unless old is "rotten"/damaged.
to replace.
Carefully pull out old or what's left of it then push in w/ a small stick.
Kitskaboodle
Report this Post06-15-2019 12:29 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, thanks for all the replies.
So then, the soup can never needs replacing and it’s not serviceable?
Kit
Total ratings: 465
Report this Post06-15-2019 01:33 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless the can has rusted out, the chicken kaboodle contents will be fine.
[This message has been edited by Patrick (edited 06-15-2019).]
fierosound
Total ratings: 287
Report this Post06-18-2019 11:36 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
to replace.
Report this Post06-19-2019 10:18 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure I changed one on the bottom of the can years ago on a Duke powered Fiero, because the filter was 99 cents added to a parts order, not sure it made a difference to anything though
[This message has been edited by 2.5 (edited 06-19-2019).]
Report this Post06-19-2019 01:04 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You wouldn't nor anyone else. Is just to keep big crap out trying to plugging the carbon etc in the can.
