  Fan switch location
Fan switch location by Lilchief
Started on: 07-29-2019 05:59 PM
Replies: 21 (860 views)
Last post by: Blacktree on 08-08-2019 09:55 PM
Lilchief
Report this Post07-29-2019 05:59 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems my fan isn't working on my new 88 coupe 4 cylinder. I looked for the switch on the head and couldn't find it. Also where is the relay at . Thanks Rick
Total ratings: 465
Report this Post07-29-2019 06:17 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe with the '87 and '88 dukes that the ECM controls the rad fan.
Lilchief
Report this Post07-29-2019 07:28 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
So which sensor, ecm temp or gauge temp or does one do it all ? Think I saw 2 sensors by the water outlet. I'm use to my 85 so 88 is a little different. Thanks
Total ratings: 465
Report this Post07-29-2019 08:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
All I know is that there's no fan "switch" on '87-'88 dukes like there is on all the other Fiero engines. I wouldn't be surprised if this is all covered in the Ogre's Cave.
Report this Post07-29-2019 09:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The ECM gets temp readings from the Coolant Temp Sensor. Could be it is bad.
[This message has been edited by Gall757 (edited 07-29-2019).]
Total ratings: 465
Report this Post07-29-2019 09:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so we're all clear, that image above is not an '87-'88 duke.
Report this Post07-29-2019 09:44 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did the remaining sensors change location in '87 & '88?
Total ratings: 465
Report this Post07-29-2019 09:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Off hand, I don't know. I do know that the '87-'88 duke got a MAT sensor. I just didn't want the OP to think from the diagram that his '88 had a Coolant Fan Switch.
Blacktree
Total ratings: 350
Report this Post07-31-2019 12:25 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like Patrick said, the '87-88 Duke doesn't have a fan switch. The ECM acts as the fan switch. It uses input from the coolant temperature sensor to determine if the fan needs to be on. The coolant temp sensor should be on the thermostat housing.
The coolant temperature sensor is just a variable resistor. As the sensor ages, the resistor will degrade. And as a result, the activation temperature of the cooling fan will be skewed. You can check the accuracy of the sensor with an Ohm meter and a thermostat. Measure the resistance of the sensor (across the 2 terminals), and compare it to the actual temperature, using the chart below. If the resistance is significantly different from what's specified on the chart, you should replace the sensor. Because that sensor also affects fueling. AND it helps the ECM determine if it should be in open or closed loop mode.
That said, if your radiator fan isn't coming on at all, it's probably a bad relay. Because if the coolant temperature sensor is completely dead, it'll throw a trouble code. Also, turning on the A/C should turn on the fan (the A/C bypasses the temperature sensor). If the fan doesn't turn on with the A/C, then the sensor isn't your problem. BTW, the fan relay is up front, below the driver side headlamp assembly.
[This message has been edited by Blacktree (edited 07-31-2019).]
Vicophine
Report this Post08-01-2019 12:25 PM Click Here to See the Profile for VicophineSend a Private Message to VicophineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have this exact same issue on my 88 4-cylinder, and found a weird little solution.
When I turned on the AC (hot or cold, does not seem to matter), the front radiator fan kicked into gear.
Just something to maybe try, hope this helps.
EDIT: Wow, totally missed what Blacktree said, yup, follow that exactly.
[This message has been edited by Vicophine (edited 08-01-2019).]
Lilchief
Report this Post08-02-2019 07:59 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Blacktree. Finally got around to working on my 88. I did notice that the fan comes on with the a/c. I believe I'll change both the relay and Temp sensor.
Blacktree
Total ratings: 350
Report this Post08-03-2019 12:09 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI, if the fan comes on with the A/C, the relay is OK.
Total ratings: 465
Report this Post08-03-2019 12:29 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has your engine shown any signs of actually overheating? Are you positive the engine is getting hot enough for the ECU to be turning the fan on? Keep in mind the fan doesn't get activated by the ECU until the coolant reaches 235°F.
Blacktree
Total ratings: 350
Report this Post08-03-2019 10:50 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick: Keep in mind the fan doesn't get activated by the ECU until the coolant reaches 235°F.
That's assuming the temperature sensor is working correctly. The reason I suggested the multimeter test is because that activation temperature can be affected by a degraded sensor. Unfortunately, the ECM doesn't set a trouble code unless the sensor has a dead short, or an open circuit. So the reading could be WAY off, and it won't set a trouble code.
Total ratings: 465
Report this Post08-03-2019 12:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, I completely agree. My point was more to address the fact that it's very common for people to post here who are concerned that their fans aren't automatically coming on, and it turns out that their coolant simply hasn't actually reached (the factory setting) of 235°F yet.
Blacktree
Total ratings: 350
Report this Post08-03-2019 03:13 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, we're both in agreement. I just wanted to make sure all angles were covered.
Lilchief
Report this Post08-03-2019 09:00 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I changed out the relay, guess I didn't need to. Oh well. Tomorrow I'll change the temp sensor. The gauge goes to 240 before I turn on the a/c. Also my 88 coupe has a 120 speedo the different tach, compared to my 85 gt and 2 gauges on the center dash. Would that have an affect on it ?
Total ratings: 465
Report this Post08-03-2019 09:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The gauge goes to 240...
Which doesn't necessarily mean a thing... unless you've actually calibrated the temp gauge/sender and know that they're both accurate.
Lilchief
Report this Post08-05-2019 09:34 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went and got an infared temp gun today. Guess the gauge is off by about 40 degrees. The temp gun read about 225 at the base of the thermostat housing, the gauge read 260. That's when the fan kick on and got it down to 195-200, the gauge was at 240. So now I need to find a sending unit for the gauge. Where would be a good place to get one? Think there's something odd on one of the corners. Thought I'd give everyone an update. Thanks Rick
Blacktree
Total ratings: 350
Report this Post08-06-2019 05:58 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The temperature gauge sender is an inexpensive and widely available part. For example, I checked RockAuto and they have over a dozen brands available. Most of them are under $20, some under $10.
Lilchief
Report this Post08-07-2019 05:37 PM Click Here to See the Profile for LilchiefSend a Private Message to LilchiefEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I got both sensors changed today. But upon taking the cap off found no thermostat. Guess there's no way to put a stat between the housing and head is there ? I tried to find a picture of the housing but had no luck. Looks like a small 1/2-5/8" tube in the center. I put a small rubber hose in it and seemed to go all the way into the head. Hope there's no stat in there. Got a new stat and cap on order. Sorry I'm still learning on these 4 cylinders.
[This message has been edited by Lilchief (edited 08-07-2019).]
Blacktree
Total ratings: 350
Report this Post08-08-2019 09:55 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Duke and V6 use the same thermostat. Just FYI.
