  No ALDL port on a 3800SC series II engnine swap to 87 fiero GT
No ALDL port on a 3800SC series II engnine swap to 87 fiero GT by Simple Man
Started on: 07-30-2019 11:37 PM
Replies: 8 (439 views)
Last post by: Simple Man on 08-03-2019 09:54 AM
Simple Man
Report this Post07-30-2019 11:37 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
The prior owner did the swap and removed the ALDL port.
presently the engine fires up but it is running a bit rich.
does anyone know what wires from the PCM are used to hook up to the ALDL port from a 98 gran prix?
There are 4 mystery wire that are unattached
I want to be able to get my PCM tuned and need the data
Any help woudl be appreciated!!
[This message has been edited by Simple Man (edited 07-30-2019).]
Report this Post07-31-2019 11:45 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Seems like a wiring diagram for a 98 Grand Prix would help you out.
Sorry though I haven't dealt with 3800s
BadNewsBrendan
Report this Post07-31-2019 11:56 AM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pin 59 on the blue connector of the PCM should go to the purple on the OBD2 connector. Here is the pinout: http://www.gmtuners.com/fil...o_L67_PCM_wiring.pdf
The wire was missing from the PCM for me and had to pin it into the connector.
Believe you just need the power and ground wires to the OBD2 connector also hooked up? Can't remember for sure.
[This message has been edited by BadNewsBrendan (edited 07-31-2019).]
BadNewsBrendan
Report this Post07-31-2019 12:08 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
BadNewsBrendan
Member since Aug 2018
Looks like also pin 15 also goes to the OBD2 connector and 2 grounds as seen in the link above and it tells you which pin on the ODB2 connector to connect it to.
Total ratings: 206
Report this Post07-31-2019 12:43 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
ALDL is a term used with OBD 1
DLC (Diagnostic Link Connector) is the term used with OBD 2
DLC 2 - PCM BLUE 59 - ppl
DLC 4 - ENGINE BLOCK GROUND - blk/wht
DLC 5 - ENGINE BLOCK GROUND - blk/wht
DLC 9 - PCM BLUE 15 - tan
DLC 16 - BATTERY 12VDC FUSED 10A - org
[This message has been edited by olejoedad (edited 07-31-2019).]
Simple Man
Report this Post07-31-2019 08:25 PM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
]Thanks for the help guys,
One of the cut wires (purple) coming out of the loom was traced back to Pin 59
Unfortunately Pin 15 the tan wire is missing in action. From the picture it looks like it was there at one time. Can this Pin be added back in?
What do you guys use to wrap your wire harnesses with?
Again thanks for the help much appreciated
[This message has been edited by Simple Man (edited 07-31-2019).]
BadNewsBrendan
Report this Post07-31-2019 08:58 PM Click Here to See the Profile for BadNewsBrendanSend a Private Message to BadNewsBrendanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I had wire with the pins on them that I removed from the connector that were for auto trans stuff since my car is a 4 speed and I didn't need them. You take the back of the connector off and can take the blue or clear plastic piece off if needed and can push the pin in.
They will be similar to this if you need to buy some. Would do some research to make sure you get the right wire guage and size. I'm sure someone more knowledgeable than me will chip in some more info as well.
[URL=https://www.amazon.com/Micro-Pack-100-Terminal-Gauge-Female/dp/B0040CVUX0/ref=asc_df_B0040CVUX0/?tag=hyprod-20&linkCode=df0&hvadid=312142335725&hvpos=1o2&hvnetw=g&hvrand=391438299708786986&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=10 [/URL]
Total ratings: 206
Report this Post08-01-2019 01:52 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a wrap of tape around the bundle every so often and then use the OEM style high temp corrugated split loom.
Simple Man
Report this Post08-03-2019 09:54 AM Click Here to See the Profile for Simple ManSend a Private Message to Simple ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys appreciate the info!
