Hey everyone, My heat shield on my alternator rattles like crazy at idle. I’ve removed, tightened the clips, and put back on only to find out it still rattles...my question is, do I really need to keep this on? I see the insulation, but was curious if this is absolutely critical to the health of the alternator. Thoughts??
Besides the clips isn't there a stud & nut on the rear of the alternator to secure the shield?
Spoon
I've only ever seen a short bolt, but I suppose a stud and nut could've been used in some applications. Found an image from the PFF archives which I believe shows a bolt...
[This message has been edited by Patrick (edited 07-09-2024).]
Yes there is a bolt and washer. As mentioned I removed it, adjusted the clips, and reinstalled it using the nut & washer. It’s as tight as possible so the bolt isn’t the issue; still rattles. Obviously I don’t want to burn up the alternator- that was the reason for my question. I’ve removed heat shields on dozens of cars in years past and have never had an issue result. Thanks again for the input!
[This message has been edited by Mmpete0131 (edited 08-31-2019).]
Make sure the bolt is not too long. Could be bottoming out before getting tight against the shield. Here's a pic of mine that I modified years ago to fit the CS130 upgrade. I show bolt vs stud as options. I know the CS130 has a built in fan and a shield isn't required but the heat from the manifold is still present.
Spoon
I would have to disagree with you there. On the '88 Fieros with a 2.8 (which came from the factory with CS130 alternators), a heat shield is still required. However, instead of it being attached to the alternator itself, it's attached to the exhaust manifold.
I stand corrected. I haven't had to deal with the 88's.
Spoon
