  IAC (intake air control valve)
IAC (intake air control valve) by sledcaddie
Started on: 09-08-2019 08:19 PM
Replies: 8 (980 views)
Last post by: fierogt28 on 09-09-2019 11:00 PM
sledcaddie
Report this Post09-08-2019 08:19 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985 SE with 2.8L 4 speed, 114,000 miles. I've got the plenum off to install stainless vacuum lines (yep, found a broken plastic one). While I'm in there, I thought I'd clean all the carbon out the IAC and throttle body port. If I just go ahead a install a new one, I've read on here that there is some procedure for "learning" for the new one? What does this involve? Before I buy a new one, is there a way to check the original to see if it is operating okay? Thanks, in advance, for any help.
Blacktree
Total ratings: 350
Report this Post09-08-2019 10:05 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
To reset the IAC, you jumper the diagnostic pins in the ALDL connector, then turn the key to the Run position (but don't start the engine). Wait about 10 seconds for the IAC to reset. Turn the key off, remove the jumper, and it's good to go.
You can also do that with your old IAC. After it resets, the valve should be fully closed. Then you can start the engine and let it idle. Unplug the IAC while it's idling, then shut off the engine. Check to see if the valve is partially open.
Side note: IAC stands for idle air control.
sledcaddie
Report this Post09-09-2019 01:11 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some of the older posts state that the ECU will teach the new IAC during the first time it is driven. So, caIibrating isn't necessary. Is this accurate?
Report this Post09-09-2019 02:12 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
go up to 40 mph for about 10 minutes and the learning should be complete.
Report this Post09-09-2019 02:26 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Above is not needed. Is part of directions how to set the Idle Stop screw on TB/TBI itself. See my Cave, Idle Stop
You only adjust the screw for replacement units or damage/maladjusted screws. Screw might move/wear over decades but Many morons think can adjust that screw but only make more problems that ECM and IAC may try to "fix" or not.
IAC will "reset" "relearn" itself ever time the car is driven over ~ 35mph in all Fiero and others w/ old GM OBD1 ECMs.
Note that you will often get high idle first after replacing or often cleaning IAC because you often mess w/ the motor to install/clean it.
The motor and valve must be "force" to retract when installed or can easy damage the IAC and TB/TBI seat the valve hits.
Most new ones have directions to retract out of the car. If not find same in most books and many web sites.
"Force" does not = much Force by you but directions to retract change a bit for different IAC types and should tell how to ID the type for directions at hand.
Take more effort then doing it wrong or IAC is binding for whatever etc.
Blacktree
Total ratings: 350
Report this Post09-09-2019 07:18 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nobody said anything about adjusting the idle set screw. But yeah, you definitely shouldn't mess with it.
Also, if you use the reset procedure I described above, you won't have high idle. So you can just hop in the car and drive it. The idle re-learn will happen while you're driving.
sledcaddie
Report this Post09-09-2019 08:21 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Besides cleaning the carbon off, I reset the spindle length to the service manual specs of 28mm. It was about 30mm when I had removed it. Also found a broken vacuum line. So now, if the idle is corrected, I won't know which defect caused the "searching" idle.
Blacktree
Total ratings: 350
Report this Post09-09-2019 09:43 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 28mm spec is to make sure the IAC valve isn't damaged during installation. It will of course adjust its length as necessary.
fierogt28
Report this Post09-09-2019 11:00 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Ogre is right about the driving 35mph and over for the re-learn.
The correct size socket to remove the IAC is 32mm. Rodney has this tool for easier removal. I know, I have one.
And yes, the correct spec length to set the pintle on the IAC to base is 28mm or 1"1/8.
Be sure to follow Blacktree's set-up installation procedure.
fierogt28
88 GT, Loaded, 5-speed.
