  Only Trunk Key Accidentally Locked in Trunk
Only Trunk Key Accidentally Locked in Trunk by jhobbins
Started on: 10-18-2019 07:34 PM
Replies: 26 (845 views)
Last post by: Jake_Dragon on 06-08-2021 11:49 PM
jhobbins
Report this Post10-18-2019 07:34 PM Click Here to See the Profile for jhobbinsSend a Private Message to jhobbinsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I accidentally locked my only key in the trunk. The switch on the dash hasn't worked since I bought the car. What is my best option here? I'm seem to recall having some luck prying one of the vents off on my old 84, I just don't want to damage the deck too bad.
Report this Post10-18-2019 07:56 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't access the trunk lock through the engine vent. Probably the best, aside from a locksmith, is to take a small drill bit and drill into the key slot and pick out the springs and pins. I believe you drill at the top of the key slot. Then you can turn the cylinder with a screwdriver.
You might also try one other thing. Find a key that will insert into the lock. Take a set of jumper cables and clamp one cable to the key and go underneath and clamp the other end the engine. Try the trunk release to see if it releases.
There is also a method of applying power to the release button harness but I'm not familiar with which wires to use. Someone else might explain that method.
Report this Post10-18-2019 09:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...take a small drill bit and drill into the key slot and pick out the springs and pins. I believe you drill at the top of the key slot. Then you can turn the cylinder with a screwdriver.
Years ago when I locked my keys in the trunk (while across the border a hundred miles from home), I didn't bother with a drill. I just hammered a slotted screwdriver (with a square shank) into the keyway, put a crescent wrench on the shank... and turned the screwdriver as if I was using a key. Popped right open. Yes, the lock cylinder was now toast... but I was very glad to get my keys out of the trunk!
cvxjet
Report this Post10-18-2019 10:35 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bingo! I have done this in the JYs to access the engines for parts (Other people use a crow bar and destroy the lid, tail lights and rear bodywork.......)
Report this Post10-18-2019 11:12 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what I found done a few years to an '88 Fiero GT which had perfect tail lights... until some idiot broke them while trying to force the decklid open. I was choked.
Report this Post10-18-2019 11:27 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what the previous owner did on my 86 but he boogered up the hole around the lock. Not bad, but the fiberglass is damaged all the way around.
TopNotch had once posted that he used the drill method I referred to on his 88 Coupe. Absolutely no damage to the decklid. I would imagine a drill bit about 1/8 would do the trick.
Report this Post10-19-2019 12:55 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Charlie, just in case you've misinterpreted what I posted... hammering the screwdriver into the keyway and forcibly turning the lock didn't damage the decklid at all.
Report this Post10-19-2019 08:40 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, no. I didn't misinterpret. I meant that the PO of my 86 did that. I know very well it can be done without damaging the deck lid. I've seen it done in the junk yard. I have no idea why he apparently pried around the edges of the lock. Maybe to pull the metal cap off the cylinder, I'm guessing.
wftb
Report this Post10-19-2019 09:31 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your car came with an inside trunk switch and it doesnt work you can still jumper it out and make it work. There is a relay under the dash that you can remove(it is probably pooched) and then feed 12 volts to the wire that goes to the trunk solinoid and the trunk will open if the wiring is still intact. Better than wrecking the lock and having to buy a new one.
FX
Report this Post10-19-2019 09:58 AM Click Here to See the Profile for FXSend a Private Message to FXEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it could be a bad dash switch. When mine went, I just took the switch out, and jumped the two terminals on the plug. It opened...
wftb
Report this Post10-19-2019 11:38 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
To find the relay, take off the lower valance that covers the steering column.It is on the right side of the steering column. Remove the relay and run a jumper from the yellow wire to the black wire. If your switch is still good it should now operate the trunk latch. If the switch is bad, remove it and momentarily jump across the switch wires. If that still doesnt work, the trunk solinoid is not getting a good ground and your will have to butcher the lock to get in the trunk.this is the connector with a jumper installed:
[This message has been edited by wftb (edited 10-19-2019).]
Report this Post10-19-2019 10:02 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
wftb, if the problem is that there is no ground to the latch solenoid, one can be provided as I described by using a key inserted into the lock, attaching a jumper cable to it and the other end to the frame. My brother had a garbage bag get over the latch hook when he closed it. He didn't have a key for the trunk and the jumper cable method is what I used to make the system work.
wftb
Report this Post10-19-2019 11:00 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a good solution for no ground at the solinoid. I think all the bases are covered now.
Report this Post10-20-2019 03:28 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless trunk solenoid or wire to it is dead...
Access it See my Cave, Trunk Release at bottom.
Report this Post10-20-2019 07:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want to not destroy the lock cylinder, keep a good lock pick handy, and you can open any lock. Its just a simple matter of lifting the lock pins off of the notch and turning the cylinder. Look on You Tube here for instructions,.
picking a trunk lock
[This message has been edited by Dennis LaGrua (edited 10-20-2019).]
Report this Post10-21-2019 12:43 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes and not just old cars. Many cars are still easy to pick or bypass the locks. GM VATS/PassKey and others try to making starting a car w/o right keys "impossible" and most new methods fail too.
But...
Having a pick and not being a locksmith can cause problems if cops sees you using or they search you etc.
Is same problem having a "Slim Jim" and related tools to open a car on you or in a vehicle not being a Tow or Lock service company.
Because in many areas they fall under "possession of burglary tools" and can get arrested just having them. Even if you win your case, you're out of a lot of money time and maybe out of a job too.
This is likely a part of why Bosnianbill says "Stay Safe, Stay Legal" at end of most of his videos.
Report this Post10-21-2019 01:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Dennis LaGrua (edited 10-22-2019).]
Report this Post10-21-2019 01:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2000
Originally posted by theogre:
[QUOTE]Originally posted by Dennis LaGrua:
But...
I doubt if you will get arrested for trying to open the lock on your own car.
[This message has been edited by Dennis LaGrua (edited 10-21-2019).]
Mike in Sydney
Report this Post06-05-2021 08:49 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have a remote trunk release switch of is this on of the rare cars w/o it? IUf yoiu have the switch an it's not operating, have you:
1) Checked the fuse?
2) Checked the wiring you can get to?
3) Checked the switch?
4) Checked the relay?
I had a problem where the trunk wouldn't release when I pushed the button. The fuse was good but as was the wiring. When I pulled the switch out, I found that the connector on the back of the switch had either been removed or had fallen off. I cleaned the terminals on the switch and in the connector as best I could, added a bit of dielectric grease and put the connector back on the switch. Pushed the button and bingo-bango, the trunk popped open.
I hope your as lucky as a I was.
Report this Post06-05-2021 09:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Especially since it was more than a year and a half ago that the OP locked his keys in the trunk!
[EDIT] Upon reviewing this thread, I notice that jhobbins never did report back. Good gawd, perhaps he's still stranded!
[This message has been edited by Patrick (edited 06-05-2021).]
Notorio
Report this Post06-05-2021 11:17 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have more than one Fiero, or keys from a previous one, or a local Fiero buddy with keys, IIRC there were only 4 key configurations used. You could get lucky ...
Notorio
Report this Post06-05-2021 11:22 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
And this reminds me of High School, when I took the red-hot daughter of the local newspaper's editor-in-chief down to the shore in South Jersey, promising six-ways-from-Sunday to bring her home by 9PM. When I locked the keys in the trunk at the beach, my short life passed before my eyes. (I think that might have been the end of our 'relationship.')
[This message has been edited by Notorio (edited 06-05-2021).]
Mike in Sydney
Report this Post06-06-2021 08:37 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL. Dang! Never even looked at the date. What an idiot I am.
MarkS
Report this Post06-06-2021 10:33 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Being a South Jersey guy myself, have to ask what shore town & newspaper; Courier Post? Gloucester County Times? Have a lot of good memories of the shore & my Fieros. But, never did lock the keys in the trunk....thinking back, hmmm, almost as good as the old adage, we ran out of gas, guess we'll have to sleep on the dunes
Notorio
Report this Post06-06-2021 12:45 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's funny ... I also didn't look at the date of this post. Unfortunately it seems that many threads asking for help are never closed out by their authors' sharing the resolution of the crisis. Sigh.
The paper? We were actually from Central Jersey (Scotch Plains-Fanwood area) and the paper was the Courier News. We were eventually rescued by a friendly biker with a tool kit. He took the back seat out and reached into the trunk for the keys . Interestingly, this same car, a few years earlier, was driven into NYC by my brother where he and some friends went to a restaurant, not realizing when he parked the car along the curb that he left the keys in the ignition and the engine running. Hours later when they emerged from the restaurant, there was the car, still running, with a mob of on lookers gathered around it. I often wonder if that car is still on the road, continuing to live a charmed life. Many happy memories there.
MarkS
Report this Post06-07-2021 04:02 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been living in C-J / Flemington NJ for 40+ years myself. I passed the Courier News building on Rt 22 everyday on my way home from work since '89. It was torn down a few years ago.
Total ratings: 399
Report this Post06-08-2021 11:49 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Click to show
