  Essential (IMO) Scan Gauge if you have a 3800 Swap - Video Review of Aeroforce Gauge
Essential (IMO) Scan Gauge if you have a 3800 Swap - Video Review of Aeroforce Gauge by DimeMachine
Started on: 01-23-2020 08:56 AM
Replies: 7 (303 views)
Last post by: Dennis LaGrua on 01-26-2020 08:46 AM
DimeMachine
Report this Post01-23-2020 08:56 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guys,
I have had the Aeroforce Scan Gauge for 8 years and it is my strong opinion that it is the most useful gauge you can install in your 3800 Fiero (or any OBD 2 performance vehicle).
It is fairly easy to move between vehicles as I have done here to my C5 from my SC Fiero. You can simultaneously scan any two OBD 2 parameters such as (Ignition Timing and Knock Retard) or (Long Term Fuel Trim Bank 1 and Bank 2) (Oxygen Sensor Voltage Bank 1 & 2) etc, --- there are numerous ways to set it up to have the gauge display the info YOU want to see. It can also read and clear Check Engine Lights (DTC's), it is a performance measurement tool (1/4 mile and 0-60MPH) and it can act as a shift light shining two bright RED LED's when you hit whatever RPM you set it for. I set it up so anytime I have any knock retard, the RED LED's light up to get my attention. I absolutely love this gauge and I am pretty sure you will too.
Here is a review of the Aeroforce Interceptor Scan Gauge if you would like to see it in action.
https://youtu.be/PTnlxysKwnQ
hnthomps
Total ratings: 51
Report this Post01-23-2020 10:30 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have also had an Aeroforce Interceptor gauge installed on my 3800 SC for a number of years. I like it but have one issue that I have never managed to resolve. To get it to function properly, I must unplug it from the OBD II connector after startup and then plug it in again. After that it works quite well. If anyone has a solution I would be really pleased to hear suggestions.
Nelson
fieroall
Report this Post01-23-2020 10:43 AM Click Here to See the Profile for fieroallSend a Private Message to fieroallEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3 essential gauges for a 3800sc Fiero:
1 - Boost Gauge
2 - Aeroforce Interceptor
3 - WiBand Gauge
DimeMachine
Report this Post01-23-2020 11:00 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
1 - Boost Gauge
3 - WiBand Gauge
Totally agree but know that in a pinch you can pull boost up on the Aeroforce Scan Gauge. I like the analog boost gauge though because of the cool factor !!
84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.85 at 114mph
DimeMachine
Report this Post01-23-2020 11:02 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
DimeMachine
Member since Sep 2011
Nelson
Interesting- I always leave mine plugged in and it comes on 15 seconds after I start the car and goes off on its own within a minute of shutting it off. Try your scan gauge in another GM car and see if it does the same thing or now. That will tell youif it is the gauge or if something is up with your 3800 SC wiring..
Total ratings: 328
Report this Post01-25-2020 03:21 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO, the wideband O2 sensor and air fuel gauge is the most important. You go lean on these engines and they won't last long. A scan tool can monitor and show the LTFT's but if the program isn't tuned correctly or working properly, the A/F ratio will give you an idea of the overall fueling as you drive.
DimeMachine
Report this Post01-26-2020 07:49 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the comment - I agree - WOT air fuel ratios are very important!!
The way I operate, in all honesty - I rarely look at my wideband DURING a WOT pull so I would miss it if it told me my AFR was lean. If the car was on a dyno, looking at the WBO2 sensor would be much easier to do.
Instead, I like to use the annunciator light to come on for any knock - which is going to tell me to LET OFF THE THROTTLE and check it out. Plus, with these engines you can hear even a degree or two of KR - they make a very distinctive sound. I always have my wideband installed when at the strip and review each pass looking at AFR, timing and any knock retard. I do like to have the LTFT's up when driving normal though. The one or two times in my life where I had a fuel pump starting to go bad the LTFTs start to go up as a "canary in the coal mine" indicating there is a bigger problem with the fuel system starting.
When tuning a new setup, I like to have the timing VERY conservative and do short pulls as I sneak up on the tune. Pull from off idle to 3000 RPM, investigate scan, tweak tune, pull from off idle to 3500, investigate scan, tweak tune, pull to 4k , repeat, all the way up to redline.
Just two different approaches to keeping the pistons in one piece I guess...
[This message has been edited by DimeMachine (edited 01-26-2020).]
Total ratings: 328
Report this Post01-26-2020 08:46 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
All of the things you mention are important, especially KR but I regularly do full scans with HP tuners on my laptop while I drive The Aeroforce gauge can be valuable but once dialed in, the WB Air fuel gauge represents my quick check as an accurate indicator of fueling. .
