  EGR solenoid
EGR solenoid by creaky78
Started on: 02-25-2020 10:06 PM
Replies: 15 (628 views)
Last post by: creaky78 on 03-17-2020 04:27 PM
creaky78
Report this Post02-25-2020 10:06 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Many thanks to all who have posted info on the EGR solenoid. The info has allowed me to disassemble it, clean up the carnage, add a little solder and IT WORKS!
Report this Post02-26-2020 09:30 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Congratulations! Can you post which threads helped you? It would help future readers.
https://www.fiero.nl/forum/Forum2/HTML/122507.html
[This message has been edited by Gall757 (edited 02-26-2020).]
Report this Post02-26-2020 10:51 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or....are you interested in repairing a few?
creaky78
Report this Post02-26-2020 11:25 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
It was pretty easy to find the posts. Rather than using the forum search, I Googled "Fiero egr solenoid" and came up with several posts on this forum, lots of info and photos.
creaky78
Report this Post02-26-2020 11:26 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
creaky78
Member since Nov 2015
Once I finish up the rehab on my '87 GT, I will consider it.
Report this Post02-26-2020 04:29 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you road test them to confirm the repair? That's how I've tested ones that I've sold.
creaky78
Report this Post02-26-2020 05:23 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's the only way I would know how to test, only takes a couple minutes to swap them out.
creaky78
Report this Post03-03-2020 11:33 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update. Haven't had the code 32 show up until now.....after driving in the rain for about a half hour today, it showed up, light came on while decelerating for a traffic light. Any thoughts?
fierobear
Total ratings: 382
Report this Post03-03-2020 04:03 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did a vacuum line pop off?
Report this Post03-04-2020 10:47 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The factory setup had a 'clean air' hose that ran from the front of the solenoid over to the air cleaner. Many times that hose is lost or broken and the car runs just fine, but water could easily get into the solenoid if the hose is missing.
creaky78
Report this Post03-04-2020 06:11 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
The hose is connected as it should be, I'll see what happens next time I drive.
creaky78
Report this Post03-11-2020 12:08 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've driven it several times since the last post, no code 32.
donuteater306
Report this Post03-12-2020 11:39 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Along with the repair, did you replace the o-rings inside of it?
creaky78
Report this Post03-13-2020 07:14 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes
donuteater306
Report this Post03-17-2020 10:04 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm. Had you pulled the battery to clear the previously set code(s)?
creaky78
Report this Post03-17-2020 04:27 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Driving daily, still no 32 as yet. Calling for rain next couple of days, will see what happens.
[This message has been edited by creaky78 (edited 03-17-2020).]
