  Power locks: positive or negative pulse?
Power locks: positive or negative pulse? by imacflier
Started on: 03-14-2020 10:16 AM
Replies: 1 (249 views)
Last post by: fierosound on 03-14-2020 01:11 PM
imacflier
Report this Post03-14-2020 10:16 AM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Subject says it all. I am going to install a remote start/keyless entry system in my '88 GT and am trying to figure out how many relays I will have to add to get the right polarity pulse.
I have the FSM as a PDF, but finding the schematics I need sure seems to be more difficult than it needs to be!
Appreciate your help!
Larry
fierosound
Total ratings: 287
Report this Post03-14-2020 01:11 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
In your 88 Manual, look at wiring diagram page 8A-130-01
You will need 2 relays (lock & unlock) between your remote start/keyless entry system module and Door Lock Relay assembly.
The new relays should be wired to provide +12v to A (unlock Black) or B (lock Lt Blue) wiring to the Door Lock Relay assembly.
Door Lock Relay assembly is under dash on passenger side.
You should be able to find wiring on the driver's side from driver's side door switch to tap into.
In your 88 Manual, look at diagram page 8A-201-12 Figure D
[This message has been edited by fierosound (edited 03-14-2020).]
