  Spark Plugs
Spark Plugs by hunter29
Started on: 03-18-2020 06:50 PM
Replies: 7 (804 views)
Last post by: theogre on 03-19-2020 04:30 PM
hunter29
Report this Post03-18-2020 06:50 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Guys, looking for plugs, the manual calls for AC R42CTS the parts store has R42TS so whats the C mean, I am thinking good old AC plugs is all I need, if you have any other in mind please let me know.
The car will not be driven much so stock plugs should be fine.. ( I think ) With that said the car has the factory plugs with 13K on them, should I even bother to replace them ?
PS planing on new cap and rotor and wires too ? should I based on age ?
[This message has been edited by hunter29 (edited 03-18-2020).]
Report this Post03-18-2020 07:14 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The C may stand for 'Commercial' according to internet guessers. At any rate, what you want is the R42TS copper plugs if you want to change them, but they should be good for a lot more than 13K miles.
[This message has been edited by Gall757 (edited 03-18-2020).]
Report this Post03-18-2020 07:32 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero seems to like the recommended factory plugs best. Champion or AC. Lots of owners have reported poor performance out of the fancy plugs. Gap at .045-.047. Some have said they went as far as .050 for a hotter spark but beyond that they started having misfires and weaker spark.
Report this Post03-18-2020 11:56 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM HEI and DIS engines Can use better plugs but can hate other "better" ones like Many Gimmick plugs that cost more and do nothing if your lucky. DIS Hates BOSCH +2 and +4 and others. Some may remember Split Fire and others got sued by FTC and more for false ads and even wrecking engines.
Main thing for Fiero is use better plugs w/ nickle etc coated metal shells that are way more rust preventive then most standard copper plugs. You find water just from washing can rust Fiero plugs easy.
HEI can use any basic Platinum plugs from ACDelco and some others. Fiero V6 ACDelco 1 Rapidfire (Yes 1 is the PN)
DIS can use "Double Platinum" plugs from ACDelco or Autolite. These put Platinum on tip and ground arm so ones that fire backward sees exact same setup. Example: 87-88 L4 can use AUTOLITE APP666 or ACDelco 41-816 Double Platinum Spark Plugs.
Note: RA and some others has NOS of older plugs or simple have wrong data. I get plugs locally and check I get right part before leaving store.
When removing plugs for any reason use compressed air and a wire to stir up and blow out crap before you use a wrench.
claude dalpe
Report this Post03-19-2020 09:35 AM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I always use ACDelco No 41809 for its resistance to rust "the shell is made of stainless" Remember how difficult it is to remove the 3 spark plugs from the firewall side when they are rusty!
More Information from Rock auto for ACDELCO 41809 :
* Dual platinum tip for improved resistance to spark erosion, fouling, and corrosive combustion chamber environment
* A platinum center electrode and a platinum pad lower the ignition demand voltage
* One-piece integral suppressor seal helps reduce radio frequency interference, meters spark plug energy to help provide long electrode life, and seals against compression leakage
* Designed with corrosion-resistant shell
* Spark gap remains virtually unchanged during the life of the plug
[This message has been edited by claude dalpe (edited 03-19-2020).]
sledcaddie
Report this Post03-19-2020 01:51 PM Click Here to See the Profile for sledcaddieSend a Private Message to sledcaddieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. This is good info to know, especially about the anti-corrosion plating. We all know how stubborn Fiero spark plugs can be.
hunter29
Report this Post03-19-2020 04:24 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info...
Report this Post03-19-2020 04:30 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worse when many way over torque Spark plugs (and oil filters) when installed. Even easier when also use "anti-seize" on them.
Plug's Cone is locking and sealing for the plugs and that hates anything on the cone shape.
Might use a little anti-seize on threads but throw away any torque data because Nearly all torque tables are only for clean dry threads.
