  What do I need for replacing a water pump? (Page 1)
What do I need for replacing a water pump? by Cliff Pennock
Started on: 05-04-2020 09:54 AM
Replies: 77 (2793 views)
Last post by: greenturnedblue on 10-18-2022 04:09 PM
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-04-2020 09:54 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since no garage is doing Fiero's anymore here, I'm going to try to replace my water pump myself. Not something I'm looking forward to (since this is going to be a side-of-the-road job)...
I'm making a list of stuff I need:
  • Water pump
  • Torque wrench
  • C-Clamp (instead of bracket for holding the timing cover in place)
  • 3/16" hex bit (for draining the system)
  • Torx: T30, T40, T50
  • Anti-seize
  • Thread sealant
  • Gasket sealer
  • Brake cleaner
Am I missing something?
Since I'm also thinking of replacing the bolts with standard hex bolts, does anyone know what sizes I need?
Report this Post05-04-2020 10:52 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like you are all set to go but forgot one important item. Before you start, cut apart a large plastic leaf/trash bag. Use that big plastic sheet to cover all of the fiberglass insulation around the wheel well. Use masking tape to keep it in place. If you don't do this, be prepare to be itchy. You probably know this already but the battery needs to be removed for working space. Just take your time work carefully and if you have a bit of luck the job will go smoothly.
Lou6t4gto
Report this Post05-04-2020 03:13 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
BAND AIDS ! LOL
Notorio
Report this Post05-04-2020 03:31 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, two things I normally do to help with reassembly on car projects are:
1) Take a piece of stiff cardboard and draw the rough outline of the water pump, in this case. Make a small hole in the cardboard for each bolt at the approximate location and when you remove that bolt insert it into the cardboard template. This helps especially when bolts are the same head but different length. You can also jot a note or two on the cardboard if needed to keep things organized.
2) Take lots of pictures before taking things off (and 'in process' if needed) to record the position of the various brackets, routing of wires and hoses, etc. I didn't do that last time and ended up badgering kind Forum Members for pictures THEY had taken to salvage my operation .
John
p.s. and Thank You! for all you do to give us a place to keep Fieros on the road.
fierosound
Total ratings: 286
Report this Post05-04-2020 03:53 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post05-04-2020 04:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This version of the last image happens to show the one bolt that requires sealant upon re-installation.
Originally posted by Patrick in This thread:
[This message has been edited by Patrick (edited 05-13-2024).]
Spoon
Total ratings: 61
Report this Post05-04-2020 07:57 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure your replacement water pump does not have a plastic impeller or you may be repeating this job sooner than you thought.
Spoon
Report this Post05-04-2020 08:39 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is one vital piece that doesn't come with every water pump, and that is the clamp to hold the timing cover against the block. Without the clamp, you stand a chance of breaking the seal at the top left corner of the timing cover where the water jacket comes through to the pump. This can cause coolant to leak into the crankcase and you wouldnt know it until it's too late.
Here is a link with lots of information on water pump replacements that we published in our newsletter.
http://gafieroclub.org/pics...sletters/Feb2020.pdf
This is a clamp that was sold at auto parts stores and is discontinued. I and another club member just found 2 this week and purchased them.
https://www.ebay.com/p/1333381983
creaky78
Report this Post05-04-2020 08:50 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Before replacing the pump on my '87 GT, I read that it is a real pita. I didn't find that to be the case. Only difficulty was removing a semi stripped out torx head screw at the bottom of the pump. Note that in the photo I have installed two guide studs for installing the pump, this makes it a snap to get the pump on with no fuss. Be sure to use the clamp to hold the timing cover in place. The Gates 43092 pump comes with the clamp and has a cast iron impeller.
[This message has been edited by creaky78 (edited 05-04-2020).]
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-05-2020 03:55 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks all for your advice. 😊
This is the water pump I bought on eBay some time back.
No idea if it's any good quality wise but it feels heavy and it has a metal impeller. One thing that did surprise me a bit is that the pully/impeller doesn't rotate freely. I mean, it hardly takes any force to rotate it, but it's not rotating freely. So if I spin it, the moment I release it, it stops. So it doesn't keep rotating and slowly comes to a stop, it stops instantly.
Is it supposed to do that?
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-05-2020 04:51 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Also, I accidentally mixed coolant (it had green, put in orange - wasn't paying attention) some time ago. When draining the coolant system, does it need to be flushed in some way?
Report this Post05-05-2020 07:18 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would flush the system and refill with old style 50/50 green ethylene glycol /H2O mix. As for the friction on the water pump shaft; that's the result of the tight seal around it. that prevents leaks.
Report this Post05-05-2020 08:15 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, I see that your pump didn't come with the clamp. I also noticed that in my link, the image has been removed. Here's an image of a clamp, though it isn't the cheap kind that comes with most water pumps. Our newsletter article has a picture of that one.
Here's the image that's missing in my link:
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-05-2020 09:31 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I read in another post that a C-Clamp would also work?
Originally posted by CoolBlue87GT here:
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-05-2020 09:55 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Also, looking at this photo:
It seems that the timing cover is still held in place by three bolts making me wonder a clamp is necessary at all since it would require a tremendous amount of force bending the timing cover to make it come loose at the top:
ltlfrari
Total ratings: 127
Report this Post05-05-2020 10:58 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did it once without the clamp because I couldn't figure out how to use it. It worked ok but maybe I was lucky. I've read some people having a bugger of a job getting the pump off and I can see the timing cover seal being broken in those circumstances.
Since then I've always used a clamp of some sort. Had to modify the supplied one (expand the cut out to clear the case)
Dave
www.ltlfrari.com
fierosound
Total ratings: 286
Report this Post05-05-2020 11:03 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
... wonder a clamp is necessary at all since it would require a tremendous amount of force bending the timing cover to make it come loose at the top:
You won't be bending the timing cover.
But it doesn't take much to break the seal of the timing cover gasket and create an oil leak.
Report this Post05-05-2020 12:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, V6 WP "bracket thing" above keep pressure on T-cover to save the gasket there. You might not bend the cover you see w/o that or something equiv to it but enough to F'd the casket.
Watch you Don't cut into the Timing cover etc to scrap off gasket(s). Very easy w/ aluminum parts.
Best is use spray Gasket Stripper and wait for that to loosen old casket. Then use Brake cleaner as final wash before new gasket.
Use paint or spray Permatex High Tack or equivalent w/ new gasket. Not RTV Silicone.
Bolt Torque specs, most need Clean Dry holes and bolts. Use a torque wrench w/o that is useless and can even break bolts or strip threads. Anti-seize and thread sealer is lube during install and throw out most torque specs.
When done w/ WP, empty the rest and fill w/ 2 gal equiv w/ pure coolant then add water.
If possible, fix WP, then flush, then refill same method.
Coolant is HAZMAT and regulated waste in most "Western" countries and get big fines catching dumping in sewers etc.
See my Cave, Coolant Fill
Report this Post05-05-2020 01:37 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used the supplied clamp... but if a C-clamp will hold the top of the timing cover tight the whole time you're loosening the pump bolts, removing the pump, and installing the new pump... go for it.
Originally posted by Patrick Here:
Speaking about the clamp, I have never seen an image anywhere on the 'net (including Pennock's) of one actually being used. Behold...this is where it goes!
And yes, you install the clamp before you loosen any water pump bolts!
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-05-2020 02:10 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think I can get the clamp here. Not even sure what it would be called in dutch. 🤔
Report this Post05-05-2020 02:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
From This thread...
Originally posted by PK:
Total ratings: 463
Report this Post05-05-2020 09:09 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does your water pump use Torx bolts instead of hex bolts?
I was under the (perhaps incorrect) impression that Torx bolts were an 88-only thing.
Anybody? Bueller?
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-06-2020 06:20 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I actually haven't checked. Let me do that in a moment.
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-06-2020 06:25 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Yes, they are in fact hex bolts. 😁
Total ratings: 463
Report this Post05-06-2020 06:41 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay... I forget which sizes you'll need. But I'm thinking a 15 mm, 10 mm and probably a 13 mm. Please don't hold me to that, however.
I'm sure someone else knows.
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-06-2020 11:06 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made a start today. Spent about 10 minutes removing the battery and getting the cables and EGR solenoid out of the way.
Hey, like I said, it's a start! 😁
One I thing that surprised me was that the tube from the EGR solenoid was attached to... nothing! Which is probably why I always get code 32 after a while...
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-06-2020 11:08 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Well, maybe not... that side only pulls in air of course...
Report this Post05-06-2020 04:25 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, Cliff, I heard there's this really great Fiero Forum where you can find out what that tube does and where it goes if you use the SEARCH FUNCTION. For the life of me, I can't remember the name, though.
cvxjet
Report this Post05-06-2020 07:29 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Everybody forgot to tell you the most impotent thing you need on this job.......A French dictionary.......
Report this Post05-06-2020 07:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sacré bleu !
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-07-2020 05:11 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, next step is to drain the coolant. Again, this is a side-of-the-road job so what would be the best way to do it? I know I can (try to) remove the drain plug on the passenger side coolant pipe, but I'm guessing that will start a 14 quart flow of coolant coming out that I won't be able to pause - and I don't have a 14 quart pan...
Perhaps syphon off as much as possible using a hose stuck into the thermostat housing? Hopefully that will get it below the level of the water pump? But that wouldn't get all coolant out. And since I'm pretty sure most coolant is just goo, I want to get all out.
Or drain from the radiator petcock? Will that get enough coolant out to at least replace the waterpump?
Report this Post05-07-2020 07:12 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That will work for replacing the pump but not to drain the entire system. The plugs on the coolant tubes will help get the last bit of coolant drained Or you could just jack up the rear of the car a few inches, take off the thermostat housing cap, pull the thermostat and just drain from the radiator petcock in the front. That should drain most of the coolant in the system out. When refilling make sure to follow the proper refill procedure.
css9450
Total ratings: 86
Report this Post05-07-2020 07:52 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with the above. The coolant doesn't need to be drained 100%. I suppose if you drain out a quarter or a third of it, would be enough.
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-07-2020 11:46 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just got a 2m hose to siphon the coolant from the radiator. But when I wanted to do that, it turned out the radiator was completely empty already...
So I just unbolted the water pump and only at the last bolt very little coolant came out, maybe 200ml or so. Also turned out bolt #8 was sheared off. I can't remember if I ever had the water pump replaced but not in the last 15 years or so. So that bolt must have been sheared off for at least that long. It wasn't leaking from that spot so I think I'll leave the (remaining part of the) bolt where it is.
Getting the bolts out was a b*tch. Not because I couldn't get them out but simply because some took almost 10 minutes of ratcheting! When all the bolts were out, the water pump came loose quite easily. I just used a large screwdriver in the notch between the water pump and the timing cover and pried it loose. It took no force/effort at all.
The old water pump had a broken bearing. I could move the pulley quite a bit.
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-07-2020 11:52 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
BTW, is it okay to leave the waterpump off for a couple of days? I won't have time to work on it until at least saturday.
Report this Post05-07-2020 12:08 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shouldn't hurt anything
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-08-2020 09:34 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the best way to get all the gunk out of the bolt holes in the timing cover? Just use air? Or spray some WD40 in them? Or will that react with the anti-seize?
Report this Post05-08-2020 03:55 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if it's the "best" way, but I normally use a tap to clean out gunked-up and/or corroded threads on whatever I'm working on.
creaky78
Report this Post05-08-2020 04:25 PM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
I run a bottom tap into the holes, spray carb cleaner in to flush out the crud, blow the holes with compressed air and clean up the mess. Wear a face shield.
[This message has been edited by creaky78 (edited 05-09-2020).]
Cliff Pennock
Administrator
Total ratings: 696
Report this Post05-10-2020 04:33 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Won't using a tap cram all dirt in the hole?
