  L61 2.2 Ecotec Swap
L61 2.2 Ecotec Swap by arbakken
Started on: 05-06-2020 12:25 PM
Replies: 2 (841 views)
Last post by: arbakken on 05-10-2020 10:35 AM
arbakken
Report this Post05-06-2020 12:25 PM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally made my own thread! I intend to make this thread my general ecotec swap discussion thread, and then I'll make individual threads (or maybe posts in a how to thread) with what I learned, did, and actually worked.
So, my 85 SE with the 5 speed iron duke has had a few issues. The reason I bought the one I did, was because the PO had painted it (although the paint is flaking a bit) and had put a rebuilt engine in. I was looking for a daily beater driver that was going to be pretty reliable and not need a lot of work. Well, that's pretty much the opposite. I only drove it probably 30 times, and it broke down 4 of those. It also wouldn't pass emissions, which ended up being due to the fact that they had put a rebuilt short block in, and didn't rebuild the head. The valves leaked so bad (I don't remember the numbers off the top of my head, but the best cylinder leakdown was like 28%, and the worst over 50) that all the exhaust wasn't staying in the engine at idle. Shortly after this diagnosis, I hit a bump on the way to work and the engine wiring harness melted and the ECU/fuel injector quit.
I ended up finding a crashed 2008 Cobalt with the 2.2 L61 Ecotec, F23 5 speed manual, with 159000 miles for a whopping $260. I have thus far pulled the engine, fuel/evap system, and most of the wiring. I bought a FSM off ebay that should be arriving later this week so I can figure out what to do with all the wiring. I'm planning on doing this on as much of a budget as possible. As mentioned in Trace26's ecotec thread, I'm going to try and do the rest of the swap for under $300. You all think I'm crazy and going to do a crap job, but I will go over budget and do a nice, factory looking install. But it's still my goal.
I'm going to use the factory ECU and wiring, and probably keep the BCM to run the gauges and cruise. I don't think the cobalt cluster will fit at all in the Fiero dash, so once I get it running I will probably disassemble the cobalt cluster remote mount the stepper motors in the fiero housing, and make the cobalt cluster run the bulbs in the fiero dash. I will probably end up buying HP Tuners. I'll only charge the credits towards the budget, so there's $100
For mounting, I'm going to fabricate motor mounts to reuse the fiero engine/trans mounts. The ecotec mounts are in strange places for the fiero cradle (halfway up the engine). I'll bet the NVH of the ecotec is worlds better than the old duke, so it should be pretty smooth. I have an entire 88 suspension in my garage that I saved from the crusher. I haven't decided if I'll use it, but I probably will.
The exhaust... is probably going to be a problem that might blow the budget. The factory exhaust manifold looks like it's going to get really close to the trunk, and I'm not going to cut it out. Hopefully I can weld up a flange that makes the turn. A solstice header might work better. This is ideal, but also $400 http://www.turnkeyenginesup...tec-off-road-header/
I'm going to keep the cobalt fuel system and try to keep the evap canister. I've fought with emissions enough in this and another one of my cars, I'm going to play it safe with the utah air quality people. I'll need a few of those stupid GM plastic quick connectors, which is probably another $100.
For the shift cables, I'm going to fabricate a mount/linkage. It sounds not ideal but possible to use the factory cables. If not, new longer cables should be $250. That might be another budget breaker. lol
Coolant hoses and heater hose should be easy. A/C will probably be next year.
wftb
Report this Post05-06-2020 07:57 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/wTGC7SiHNT4
My 2.2. they do not shake and rattle, nice and smooth.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
arbakken
Report this Post05-10-2020 10:35 AM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
So the engine in the Cobalt (did that a couple weeks ago) and the engine/cradle in the Fiero are out. Did that last night. It was kind of a ***** , only because the legs on my engine hoist were competing for space with my roller dolly I was trying to drop the cradle onto. I think I'll make some sort of cradle dolly when it goes back in.
Obligatory me standing in the engine bay shot:
Duke in cradle, Ecotec on blocks
Apparently the PO might not have torqued the alternator bolt on the duke! That might have been exciting at some point...
Anyways, I learned something about the shifter cables that probably only applies to the 4 speed and Isuzu 5 speed, the ball studs on the transmission are 13mm, on the F23 (and probably all getrags?) is 10mm. So I'll either need to get new cables, convert the ecotec to 13mm, or use the cobalt cables.
Hopefully my service manual dvd shows up one of these days, I'd like to start figuring out the wiring.
