  WIndow motor swap- what rivets to use
WIndow motor swap- what rivets to use by cam-a-lot
Started on: 05-07-2020 07:49 AM
Replies: 8 (897 views)
Last post by: theogre on 05-08-2020 02:57 PM
cam-a-lot
Total ratings: 97
Report this Post05-07-2020 07:49 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello
Does anyone know what is the correct rivet to purchase to swap the window motor? I did a search on the forum but can't seem to find this info
thanks
Report this Post05-07-2020 10:21 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most people just bolt them in.
fierosound
Total ratings: 286
Report this Post05-07-2020 10:59 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
In Factory Service Manual - Section - Doors
Replaced all motors in both my cars last year.
Window motor and almost everything on door is 1/4" x 1/2" aluminum. You'll need about 12 per door.
Also a couple of smaller ones, for door lock rod bracket.
https://www.fiero.nl/forum/A...130314-2-111836.html
You'll need something like this to install them.
[This message has been edited by fierosound (edited 05-07-2020).]
OldGuyinaGT
Report this Post05-07-2020 12:51 PM Click Here to See the Profile for OldGuyinaGTSend a Private Message to OldGuyinaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO, the answer to this question is "none". You can certainly use rivets (and I have in the past) but I think M6 or 1/4-20 bolts and nuts (I like washer heads for this) are a better choice. Easier to install, better retention (assuming proper torque and Loctite), easier service later.
Lou6t4gto
Report this Post05-07-2020 03:46 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
just use Bolts, makes it alot easier if you ever have to take them out or adjust. factory used rivets because they are Cheap.
cam-a-lot
Total ratings: 97
Report this Post05-07-2020 03:53 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to everyone for your advice
Much appreciated
Orig88GT-NC
Report this Post05-07-2020 04:42 PM Click Here to See the Profile for Orig88GT-NCSend a Private Message to Orig88GT-NCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like said, Nut & Bolts are the way to go...I would recommend using nylon insert lock nuts to keep them from coming loose.
fierosound
Total ratings: 286
Report this Post05-08-2020 12:02 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Completely agree if someone goes the nuts and bolts route.
I had to fix someone's door when their window fell down inside of it.
A previous "fixer" used nuts and bolts that all shook loose and completely disappeared from inside the door!
We used rivets.
[This message has been edited by fierosound (edited 05-08-2020).]
Report this Post05-08-2020 02:57 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Big rivets work but no point getting new ones and install tool for most DIY.
Many small bolts/nuts have too small heads and need washers to clamp better and/or to protect the parts. Add lock washers or equiv too for some joists.
Just buy a box w/ bolt/nut of different size and washer kit too from HF Ace etc. Any leftovers can use on other things and takes next to nothing to store.
Just watch for extra threads don't hit/bind when window moves up/down.
Nyloc nuts are a brand name but now most common name for them.
Loctite Blue on small hardware is often = Red and Won't come off again if you need to work on whatever days to years later. Make sure you have spares before removing them.
Loctite 222 Purple made for small/weak parts but hard or impossible to find at most local stores.
