  2016 Buick Regal Turbo Ecotec motor for a swap, what are the challenges?
2016 Buick Regal Turbo Ecotec motor for a swap, what are the challenges? by qwikgta
Started on: 05-15-2020 10:45 AM
Replies: 39 (1582 views)
Last post by: Darth Fiero on 03-27-2022 04:03 PM
qwikgta
Total ratings: 84
Report this Post05-15-2020 10:45 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a chance to grab a 2016 Turbo Ecotec from a Buick Regal. Its a auto, but I have an Ecotec F40 trans for it.
If I pull the motor, what else do I need to grab being that its a newer motor, in other words, do I need the BCM, gauges, gas pedal, fuel pump.. ect.
I'm familiar with what to grab for a 3800 and 3.4 DOHC motor, but with this being a 2016, Gen III motor i've never looked into what needs to be pulled.
thanks in advance
Rob
arbakken
Report this Post05-15-2020 12:05 PM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I really wanted to do that swap, but my car isn't nice enough.
There is an easy/expensive way to do it: gm sells a control pack with the computer, pedal, wiring.
I would grab the fuel pump, I believe it is computer PWM controlled to provide the correct fuel before the engine itself compresses it to the high pressure for direct injection.
You'll definitely need the gas pedal. You should be able to program it to run without the BCM, but you may lose stuff like cruise control and the gauges. I'm doing a 2.2 na ecotec swap right now and I'm planning on keeping the bcm and gauges.
For my own curiosity can you take some pictures of the engine, and measure how far the exhaust/turbo sticks out from the head? This is going to be an awesome swap!
[This message has been edited by arbakken (edited 05-15-2020).]
wftb
Report this Post05-15-2020 12:59 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get everything you can. Unless you are going to do standalone engine management. Entire wiring harness with the bcm ecm all of it. Get the steering column with the key in the ignition (you might use the switch, not the column), gauges fuel pump everything electrical. Modern GM harnesses use all different connectors so you can't put it together wrong. The harness will come with a large fuse block and a small fuse block and cables to go to the battery . If you get it all, it is plug and play and you can have it working fairly quickly. Get the drive by wire pedal assembly and grab the charcoal canister and its harness too.
The only thing my Fiero uses that is Fiero are the lights, heater fans and controls,wipers etc and the ignition switch turns on the starter for the ecotec. I pared down my harness too much and I do regret that now. I use HP tuners and for my setup anyway it will run both a manual and automatic transmission. I doubt the newer cars would be set up like that, my control system is from a 2004.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
[This message has been edited by wftb (edited 05-15-2020).]
qwikgta
Total ratings: 84
Report this Post05-15-2020 06:02 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I pulled the motor. Got the engine, 6 speed Auto trans, ECM, engine harness, engine sensors (MAF, MAP ect), coolant bottle and a few odds/ends. Only has 35K on it, and was driving when it was hit in the rear with a push to the front. Kind of a Buick sandwich. No damage to the motor, only thing I've seen is that the cold side metal tube was pushed back into the A/C and has a small dent in it.
I've pulled a lot of engines and this one was different, the engine harness was a stand alone. It connected to the main car harness via a multi-pin pack. In the others, I had to pull the main harness thru the firewall and it was connected to the fuze box and had/has a lot of misc connections for fan, brakes, horn ect..
I am going to have to go back tomorrow and pick the other stuff I didn't get today, i was just too tired and thirsty to care. I'll grab the gas pedal and harness, look for the BCM and harness and all the other crap i missed.
For now, I'm just happy to have the motor.
More to follow.
wftb
Report this Post05-15-2020 08:57 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 6 speed auto sounds kind of nice to me. I had a 6 speed dual clutch auto in the last Focus I had and it was awesome once they did all the recalls. Turbo motors work better with autos.
rear SLA suspension
qwikgta
Total ratings: 84
Report this Post05-15-2020 09:17 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
yea, I love auto's for daily drivers too. My DD is a 3800 NA w/ auto and I love driving it.
My plan was to get a motor for the 87 GT i picked up the other day, its a 5 speed and if I flip it, i'd want to keep it a 5 speed. I had planned to just pick up a 2.8L for it and call it a day, but folks I've talked to want upward of $600+ for a good working, low mileage motor, and those are 6 plus hours away. Not really sure what i'm going to do with this motor, i may just put it in the garage for a future project.
Maybe i'll just finish cleaning up and working over the LSJ motor for the 87 GT.
[This message has been edited by qwikgta (edited 05-15-2020).]
qwikgta
Total ratings: 84
Report this Post05-16-2020 04:17 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
went back today and grabbed all the wiring I could, got the BCM and all the rest of the engine wires. took 3-4 hours to pull it all thru the firewall and out from under the dash. not sure I got everything, I did have to cut some. The large bundle of wires went under the driver seat and keep on going. I had to cut the harness right there so I could remove all the dash and engine wiring. Got the drivers pedal and all its wiring. Grabbed something from the trunk, not sure what it is but it looked important. I did cut the wires going to all the stereo and cut the stuff going into the doors. It was quite an ordeal. I had to remove the whole dash just to get it all. Had to remove the brake peddle and all its hardware to get the plug out of the firewall. That task alone took at least 2 hours. I had no idea the brake master cyl held the whole thing together. 12" inch bolts going from the master - thru the booster - into the firewall. I'll sort it out later. Still need to go back and grab the fuel pump, steel lines and the charcoal canister.
Rob
[This message has been edited by qwikgta (edited 05-16-2020).]
qwikgta
Total ratings: 84
Report this Post05-17-2020 09:28 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
well strike one.
I just found out the 2.0 Ecotec Getrag F40 that I have from a 2007 Saab will not fit the 2.0 Ecotec LTG motor. I guess b/c the LTG was designed to be a RWD motor, the bellhousing is RWD. They do make a Getrag F40 for the LTG, but it has a different bolt pattern, one that match's the RWD trans. They can be purchased for cheap ($600) but i'm not that excited about having to spend that for what I thought I already had. CRAP!!!
wftb
Report this Post05-18-2020 08:27 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is some info I found on the LTG. It was designed to be used in longitudinal or transverse applications. There are diagrams of everything except the bolt patterns here. https://gmpowertrain.com/as...s-specifications.pdf
I always thought all ecotecs had the same bolt patterns. I will do some more digging , there has to be a diagram somewhere.
Does that Regal you are getting the parts off have the Hyperstrut front suspension? It will have an upper ball joint on the spindle if it does.
rear SLA suspension
[This message has been edited by wftb (edited 05-19-2020).]
wftb
Report this Post05-18-2020 08:40 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
wftb
Member since Jun 2005
wftb
Report this Post05-18-2020 08:50 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
wftb
https://gmauthority.com/blo...l-turbo-i4-ltg-2.jpg
Front wheel transverse drive. The only difference seems to be the exhaust. On the old eco's like mine the exhaust comes out the left side of the engine. On the LTG it comes out of the right side or towards the front of a Fiero. To me that would be an improvement as exhaust could be routed like a stock Fiero. Still have not found a bell housing diagram yet.
rear SLA suspension
qwikgta
Total ratings: 84
Report this Post05-18-2020 10:10 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
starter is in the wrong location, and the bolt pattern is different. Starter is over the axle in the LTG and its on the opposite side on the "other" ecotec.
14-17 LTG
Early Ecotec
wftb
Report this Post05-18-2020 10:31 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the name of the automatic that is bolted to your LTG ? This is a rear drive tranny that is listed as the manual for the LTG, no fwd trans is listed on the Chevy performance website.
https://www.chevrolet.com/i...ansmissions/ltg.html
The LTG is a clean sheet design, nothing from the old 4 cyl ecotecs fits it. I notice the alternator is on the opposite side, the waterpump is belt driven instead of the internal chain drive like mine and because of that you have to leave the AC compressor on. With earlier eco's you can just take the compressor off and run a short belt from the cavalier that had no AC. I did not realize they had changed so much.
rear SLA suspension
[This message has been edited by wftb (edited 05-18-2020).]
qwikgta
Total ratings: 84
Report this Post05-18-2020 04:04 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its 6T70, its a FWD trans but b/c the motor was for Cadillac and the Camaro it started out as a AWD/RWD motor first. At least that's what I've been reading.
Rob
[This message has been edited by qwikgta (edited 05-18-2020).]
wftb
Report this Post05-18-2020 06:49 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info that all makes sense. For a lot of car companies the 2 litre 4 cylinder turbo has become a universal engine. Variations of it is all Volvo uses in all their cars and SUV's.
rear SLA suspension
Total ratings: 237
Report this Post05-19-2020 10:01 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is some info I found on the LTG. It was designed to be used in longitudinal or transverse applications. There are diagrams of everything except the bolt patterns here. https://via-autoworks.my-on...002281_20063234.aspx
Wrong Link?
arbakken
Report this Post05-19-2020 10:24 AM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm nearly certain the bolt pattern is the same on FWD and RWD ecotecs. I've never seen anything to the contrary. They may have put the starter in a different place due to packaging, but that's on the transmission side anyways.
qwikgta
Total ratings: 84
Report this Post05-19-2020 11:58 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Once the wx clears here in Va Bch, i'll pull out the 07 F40 and put the two together once and for all.
Correct me if I'm wrong, but the starter bolts to the motor right? if so, then the early F40 will not work, b/c there is no "hole" in the 07 F40 case for the starter to "poke out". So even if the 07 trans "could" bolt to the 2016 block, the starter (attached to the block) will interfere with the trans.
Also, I don't think I can just cut the 07 case to fit the 16 starter location. Before I did all that, I'd prob start to see how difficult using the 6spd auto trans will be.
just for ref, here is a pic of the 6T70 auto trans.
and here is a pic of the engine side of the LTG motor.
Rob
[This message has been edited by qwikgta (edited 05-19-2020).]
wftb
Report this Post05-19-2020 01:05 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Will:
Wrong Link?
Yes sorry about that. Fixed it.
arbakken
Report this Post05-19-2020 04:51 PM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
What car did your F40 come out of?
This is from a ZZP F40 swap kit for earlier 2.0 ecotecs
Requires Saab 9-3 ('07+ preferred for best performance gearing) or 2011-13 Regal 6 speed F40 transmission and PCM reprogramming to adjust for the new speed sensor. It does fit pre-2007 Saab F40 but the gearing is not optimal. The Regal transmission has poor gearing for drag or road course cars (wide gears, tall final drive), but can be useful for half mile racing. Please don't ask if it will work with XX transmission. It's designed for a Saab or 11-13 Regal trans as stated above and nothing else.
Both the 2011-2013 and 2014-2016 F40 6 speed option code is MR6, but they don't seem to interchange. The regal didn't get the LTG until 2014, so I guess it's possible they changed the transmission... but... man that seems dumb
[This message has been edited by arbakken (edited 05-20-2020).]
Total ratings: 461
Report this Post05-19-2020 07:02 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
They do, however, list a FWD 6 speed manual trans Engine controller and install guide.
LINK
"Front Wheel Drive with 6 Speed Manual Trans Kit Part Number 19331686"
The engine controller looks to be "stand alone". Probably spendy as hell, but it kind of gives some hope that maybe the tune can be loaded into an existing PCM, that is already in hand.
(Of course, that doesn't help with the trans. )
[This message has been edited by Raydar (edited 05-19-2020).]
qwikgta
Total ratings: 84
Report this Post05-21-2020 05:58 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
yep, for one car, the Regal GS, and three years of production they changed the bellhousing for the F40.
qwikgta
Total ratings: 84
Report this Post05-21-2020 06:07 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
qwikgta
Member since Jan 2001
LINK
So if you google that part number you'll see that its the engine harness, ECM, gas pedal, O2 sensor, MAF and a few other odds/ends. I have all that, when I pulled the motor, I knew enough to grab everything. I even went back a few days later and grabbed the in-tank pump, the charcoal canister, steal gas lines. I have the BCM, all the harness under the dash and all the harness attached to both fuze panels. I have a lot of wiring.
Still unsure if i'm going to use this. I may put it up for sale.
Rob
Total ratings: 237
Report this Post05-24-2020 10:04 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
They did it for two years of G6 production.
pmbrunelle
Total ratings: 63
Report this Post05-24-2020 10:34 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
From what I know, die-cast molds are scrap and have to be redone after about 100k pieces.
So if you're going to make about 100k of something, the fact of it being different won't result in a cost increase (other than the administrative burden of managing another part number).
Blue Rocket
Report this Post05-26-2020 02:24 PM Click Here to See the Profile for Blue RocketSend a Private Message to Blue RocketEdit/Delete MessageReply w/QuoteDirect Link to This Post
The LCV 2.5 liter n/a version also shares this bell house. So my swap is also on hold there as well. A few places making adapters to bolt these to other rwd transmissions, so maybe a adapter can be made.
Total ratings: 328
Report this Post05-26-2020 03:37 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The complete swap kit from GM for this engine runs $2700. Add in the cost of the engine clutch and all else and you are over $3,000 , maybe closer to $4,000 and that is for a DIY job. Doesn't seem to be cost effective.
[This message has been edited by Dennis LaGrua (edited 05-26-2020).]
qwikgta
Total ratings: 84
Report this Post05-27-2020 03:40 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are you talking about? I have a complete 35,000 mile motor w/ accessories, including turbo and cold side plumbing, 6 speed 6T70 auto trans, ECM, BCM, engine and body harness, both fuel pumps, charcoal canister, axles, spindles, hubs, calipers, rotors, steel fuel and return lines and with all that I'm still under $350 bucks.
[This message has been edited by qwikgta (edited 05-27-2020).]
qwikgta
Total ratings: 84
Report this Post05-27-2020 04:42 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
qwikgta
Yes, the block bolt pattern is for RWD/AWD drive cars, like the Camaro/Cadillac. They do make an adapter for the 4T60 RWD trans. Not worried about an adapter, if I cant modify my 2007 F40 to fit, i'll stay with the 6T70 AT.
arbakken
Report this Post05-27-2020 08:36 PM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be fair, that's a pretty rocking deal!
imacflier
Report this Post05-31-2020 06:02 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
qwikgta,
Have you looked at the harness packages made by Swap Specialties: https://swapspecialties.com...s-and-pcms-eco-tech/ ?
Surely looks reasonable for what they promise!
Larry
imacflier
Report this Post05-31-2020 06:17 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
imacflier
Member since Apr 2002
qwikgta,
Larry
cmechmann
Report this Post05-31-2020 08:23 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be curious as to what issues you are going to run into with CANS bus.
Just replaced an ECM on a 2016 Cruise 1.8. There were at least 4 other modules reporting CANS bus error due to not seeing to ECM on the CANS bus.
TCM, ABS, Instrument panel and BCM. I would almost bet that the ECM will report errors for modules it can't get CANS bus communications with other expected modules unless they can be edited out of the flash. Before you get too deep into this, I would make sure that there is enough data out there to edit the flash. Such as editing software that covers that series engine.
We have been seeing a lot of intake leaks and valve cover/PCV issues with this series of Ecotech engines. The smaller 1.4 turbo and 1.7 series have been worse.
Total ratings: 328
Report this Post05-31-2020 10:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you really got all that for $350, that is misleading the members here on the swap cost. Deals like this are very uncommon. Car-Part.com will give you a real cost for this powertrain and its more like $2,000. . .
When you get it running correctly post a video.
wftb
Report this Post06-01-2020 04:26 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
When it comes to getting stuff from a wrecker, prices are all over the map. There is a huge difference in price between buying something online with no work involved and going to a pick and pull and getting everything yourself. The OP is not misleading anyone, he is just stating what he paid for all this stuff. Your results will vary.
Since AWD swaps for hatchback civics have become the latest tuner craze, there are people driving hundreds of miles and pulling the drivetrains out of CRV's and Elements from yards in low populated areas and then selling online at 10 times what they paid for them. A lot of elbow grease for a corresponding lots of profit.
rear SLA suspension
qwikgta
Total ratings: 84
Report this Post06-02-2020 10:12 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by imacflier:
qwikgta,
Larry
yes in google'ing everything LTG on the net i did find that site. Thanks
qwikgta
Total ratings: 84
Report this Post06-02-2020 10:35 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
qwikgta
I'm not posting questions because of the price I paid, it's because of the DI fuel system, VVT and how to make the 6T70 trans work in a 87/88 Fiero? And yes I did get all that for the price posted.
Do I understand that I got a OUTSTANDING deal on this YES I do. But Pick and Pull has a price list. Its the same across the country. A motor is $XXX, a trans is $XXX. When I bought my 87 GT from Pick and Pull with no motor, I asked for a motor to be part of the price, the manager agreed. He gave me 60 days to find and pull a motor. When I saw they had a 2016 Buick Regal on the lot, I asked if the 2.0 ecotec was acceptable and he said yes. I've gone back 3 times to get other misc parts to finish the swap. BTW, the motor and everything I pulled is also for sale, am I asking $350... HELL NO.
arbakken
Report this Post06-03-2020 08:26 PM Click Here to See the Profile for arbakkenSend a Private Message to arbakkenEdit/Delete MessageReply w/QuoteDirect Link to This Post
You got the motor from a pick and pull? Those types of yards in Utah don't have a single car made within the past 10 years! lol
robmox
Report this Post03-20-2022 07:43 PM Click Here to See the Profile for robmoxSend a Private Message to robmoxEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, I was doing research about an ecotec swap, and I happened across this while I was doing research into the LTG. I'm probably going to try an LNF swap, but I just wanted to follow up and see how you were able to get the stock GM BCU to work? Other things I'd read said that it's not possible/likely to get the BCU to work, and that you'd have to get a standalone ECU. Personally, if I'm going to buy a Cobalt SS donor car, I might as well try to use as much of it as possible. And, as difficult as it is, if the stock BCU likely adds features that are nice to have in a restomod. So, I see you mentioned that you need the ignition switch, but are there any other features that are "unnecessarily" tied into the BCU/ECU like blinker controls, dome lights, or anything else that I'd do right to grab from my donor car? If so, are you able to provide a list of such features?
Darth Fiero
Total ratings: 361
Report this Post03-27-2022 04:03 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Generally speaking, VATS (anti-theft / security / immobilizer) can be tuned out of these modern Ecotec ECMs so you do NOT need to install the BCM from the donor car into your Fiero when you do a swap.
That said, if you do want the BCM, it does NOT need to have every single electrical circuit hooked up to it (like blinkers and such) in order for it to work in a swap environment in a limited fashion.
More is more. Less is not enough.
