  Tire Size Conversion Chart
Tire Size Conversion Chart by Jcbigbie
Started on: 05-20-2020 09:19 AM
Replies: 8 (1371 views)
Last post by: Jcbigbie on 06-22-2020 09:55 AM
Jcbigbie
Report this Post05-20-2020 09:19 AM Click Here to See the Profile for JcbigbieSend a Private Message to JcbigbieEdit/Delete MessageReply w/QuoteDirect Link to This Post
How wide is my tire? How tall is my tire?
Well, i created a spreadsheet with the more common tire sizes. It converts Eveything to inches, gives you side wall height and total height with a 15",16",17" and 18" rim.
My stock 88 gt size is Underlined.
Any suggestions are welcome.
A direct link to this sheet.
A Google docs link.
Search terms: fiero tire sizes, tire size options, fiero biggest tire size, fiero wheel sizes, tire combos
[This message has been edited by Jcbigbie (edited 06-21-2020).]
Total ratings: 328
Report this Post05-21-2020 06:20 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice write up but the supply chain on 15" tires is thinning. The modern look of larger rims is here.. What I try for a more modern look, is to use tires that have about the same OD as the OEM tires. This way the speedometer error will be minimal or not at all.
For 17' wheels I use 225 x 45 R17 rear and 205 x 45 R17 front
For 16's wheels I use 225 x 50 R16 rear and 205 x 50 R16 front
As for 18's I wouldn't use them. The ride is rough enough with the 17's. Actually the 15" tires provide the best ride but IMO the larger rims do modernize the look..
Not trying to hijack your thread; just provide something useful as you have done.
Jcbigbie
Report this Post05-21-2020 07:52 AM Click Here to See the Profile for JcbigbieSend a Private Message to JcbigbieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
I just added 16" - 18" rim sizes to the sheet.
Total ratings: 328
Report this Post05-21-2020 04:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Jcbigbie:
Thanks.
With so many Fiero owners going to sport wheels this is very helpful.
Spadesluck
Report this Post05-21-2020 06:42 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very helpful for sure. I can not tell you how many times I use a google chart to look up widths and rim sizes when tire shopping.
Jcbigbie
Report this Post05-22-2020 01:41 PM Click Here to See the Profile for JcbigbieSend a Private Message to JcbigbieEdit/Delete MessageReply w/QuoteDirect Link to This Post
If anyone has a size they would like to see here, let me know. I can edit this file very quickly.
88 gt
5 speed, Fidanza aluminum flywheel
2.8 V6, 1.6 roller rockers
Leather interior
Total ratings: 461
Report this Post05-26-2020 04:25 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool! Thanks for your effort.
Habanera Hal
Report this Post05-26-2020 05:12 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
For any tire size, wheel width/diameter, offset, etc., try this:
http://www.rimsntires.com/specspro.jsp
Will also offer clearance specs, speedo change, and other info.
Jcbigbie
Report this Post06-22-2020 09:55 AM Click Here to See the Profile for JcbigbieSend a Private Message to JcbigbieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just added support for 19" rims.
