  Cruise Control Filter
Cruise Control Filter by computer_engineer
Started on: 06-13-2020 10:00 PM
Replies: 3 (156 views)
Last post by: computer_engineer on 06-14-2020 10:20 PM
computer_engineer
Report this Post06-13-2020 10:00 PM Click Here to See the Profile for computer_engineerClick Here to visit computer_engineer's HomePageSend a Private Message to computer_engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a question about what to replace the filter that goes on the cruise control vacuum valve assembly. It has rotted off and I would like to replace it with something .
What have you guys used?
Thanks!
Frenchrafe
Report this Post06-14-2020 05:42 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was actually something on that thing? Hence the metal clip.
I would say that most cars don't have anything anymore after 30+ years!
Mine doesn't, and the cruise control still works fine.
Regards,
Rafe
"Turbo Slug" - '87 Fiero GT. 3800 turbo. Sticky tyres. Driven hard!
https://www.youtube.com/cha...1wZvWQlkYxTjivW_0XNg
[This message has been edited by Frenchrafe (edited 06-14-2020).]
Total ratings: 206
Report this Post06-14-2020 08:26 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I block of open cell foam provided filtration of the incoming air on the vacuum dump solenoid.
I have made them, no replacements are available as far as I can tell.
computer_engineer
Report this Post06-14-2020 10:20 PM Click Here to See the Profile for computer_engineerClick Here to visit computer_engineer's HomePageSend a Private Message to computer_engineerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well,
I came up with a solution... I may not need to bother, but since the GM engineers seemed to be concerned, then so am I.
Just cut the end off of a cheap foam paint brush.
Then stretch it over the end of the tube and the metal clips, and you have yourself a filter. If it gets dirty or damaged, you may have to sacrifice another paint brush.
[This message has been edited by computer_engineer (edited 06-14-2020).]
