  Upper Ball Joint Majorly Stuck
Upper Ball Joint Majorly Stuck by Brent7088
Started on: 06-25-2020 11:34 PM
Replies: 18 (546 views)
Last post by: theogre on 06-27-2020 03:49 AM
Brent7088
Report this Post06-25-2020 11:34 PM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm trying to replace the front upper ball joints on my 86 GT. I removed the mounting bolts, castle nut and the grease fitting. I tapped the threaded stud from the bottom with pretty good wacks, and even tried prying up on the top between the mount and the control arm and the stubborn thing still won't pop out.
Is there anything I'm forgetting to do? Thanks in advance.
[This message has been edited by Brent7088 (edited 06-26-2020).]
Notorio
Report this Post06-25-2020 11:40 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could you add a picture or two showing the situation? Some of us haven't done this job yet and we can learn with you
cvxjet
Report this Post06-26-2020 12:28 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
It takes a lot to break the tapered end of the BJ loose....I bought Rodney Dickman's BJ removal tool which goes between the two BJ ends and then expands- Be prepared- when one breaks loose it makes quite a loud sound. Also, leave the nut on but loose by 1/8" to contain it when it pops loose.
[This message has been edited by cvxjet (edited 06-26-2020).]
Brent7088
Report this Post06-26-2020 02:07 AM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you - I'm assuming this tool is for the upper joints. I may just decide to use a fork (even though it may be tougher to get under the collar). I'm not worried about damaging the BJ since it's being replaced.
rubyredfiero
Total ratings: 58
Report this Post06-26-2020 07:27 AM Click Here to See the Profile for rubyredfieroSend a Private Message to rubyredfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had that problem before. Here's what I did. Check to make sure someone didn't tack weld the the BJ from the underside. Put the BJ back in the spindle with the nut on as far as you can, but don't tighten it. Lift the car and put something solid under the lower control arm, but NOT on the grease fitting. Now make sure there's space between the upper control arm and the spindle and pound the top control arm close to the BJ flange with a flat nose of a hammer or dull chisel. Repeat around the flange. I was surprised how stubborn it was but I got it out. Then you should be able to remove the old BJ while the lower control arm is still propped up. Wear safety equipment and exercise caution at all times. Good luck.
AsaBergman
Report this Post06-26-2020 09:43 AM Click Here to See the Profile for AsaBergmanSend a Private Message to AsaBergmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the time I hit the part of the knuckle the ball joint stud is inserted into perpendicular to the stud rather than the ball joint stud itself while pulling down on the knuckle. Other note is leave the castle nut on the end of the threads flush with the end of the stud, gives you a larger surface to hit with a hammer but it'll probably damage the threads(doesn't matter here).
I know for sure I removed my passenger side upper ball joint with the pickle fork however I had the lower ball joint disconnected when I did this, might not be able to fit it with the lower still connected.
Notorio
Report this Post06-26-2020 12:26 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for adding the picture. Now I see what you are dealing with. Lots of great suggestions are being posted. (But I still don't look forward to that job in the future.)
rubyredfiero
Total ratings: 58
Report this Post06-26-2020 12:42 PM Click Here to See the Profile for rubyredfieroSend a Private Message to rubyredfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if I misunderstand your issue. Is your problem, 1- getting the tapered stud out of the spindle or 2- can't get the bj out of the control arm? I thought #2 is your problem. In that case my post will not help you a bit. Sorry.
Report this Post06-26-2020 12:48 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put the nut back on the stud so spring etc hits the nut not you. leave nut 1 or 2 turns loose ref to full tight.
Buy/make a tool above and use it to push out the stud.
To help that, bump the side of knuckle hole area w/ a hammer to shake/vibrate the joint area. Do Not "beat" the knuckle, use repeated light hits
Between the two, should pop out w/o tighten the tool "to death."
Do Not use a "Pickle Fork" for BJ or Tie rod ends.
Rod end used a "press" tool to push out the stud. Can bump the knuckle same as above to pop the taper easier.
Total ratings: 463
Report this Post06-26-2020 02:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another vote for Rodney's balljoint tool. It locks between the upper and lower balljoint studs. As you unscrew it, it expands and forces against both balljoints. As others have said, leave the nut screwed on, but only loosened a couple of turns.
When if finally lets go it'll make a nice "bang".
You'll probably never be able to pry it off, and a pickle fork will just tear things up.
Spadesluck
Report this Post06-26-2020 02:59 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pickle forks have always worked for me. Unless I am not following what is trying to be done here.
Report this Post06-26-2020 03:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just to be clear, it's for both upper and lower ball joints. Works like a charm. I'll never go back to using a pickle-destroy-the-BJ-fork again.
IMSA GT
Total ratings: 250
Report this Post06-26-2020 05:08 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go to the auto parts store and get one of these. You just need to get the proper size for the arms to fit around the top of the spindle.
I use the same one for my Dodge truck and Hummer ball joints. It is a breeze once you have this tool.
[This message has been edited by IMSA GT (edited 06-26-2020).]
Report this Post06-26-2020 07:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by IMSA GT:
Go to the auto parts store and get one of these... It is a breeze once you have this tool.
It's nice to have options... but I fail to see how that tool could be anywhere near as much of a "breeze" to use than Rodney Dickman's BJ removal tool. With Dickman's tool (that doesn't sound right ), both upper and lower ball joints can be loosened... without even repositioning it.
sspeedstreet
Total ratings: 53
Report this Post06-26-2020 07:42 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another huge plus for Rodney's tool.
IMSA GT
Total ratings: 250
Report this Post06-26-2020 09:04 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh I'm just giving another option. I'm sure Rodney's tool works awesome.
Brent7088
Report this Post06-27-2020 01:09 AM Click Here to See the Profile for Brent7088Send a Private Message to Brent7088Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well - I was able to get my hands on a ball joint separator, and I finally got it to pop off (surprisingly it wasn't as loud of a pop as I thought it would be). I'm sure getting the new one in is going to be just as much of a treat as getting it off.
Ordering the RD tool would have been my plan B - I just didn't care to wait an additional 2 weeks for it to arrive (shipping has been Xtra slow lately due to the virus situation). Anyhow I'll be working on the passenger side Saturday as I wait for the new joints to arrive.
I want to thank everyone kindly for chiming in. It's always a pleasure reading helpful advice from experienced folks.
Notorio (and for anyone else): When I get to the passenger side, I can try to get more pics and a few instruction as to how it worked for me.
[This message has been edited by Brent7088 (edited 06-27-2020).]
Report this Post06-27-2020 02:18 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just as a note of interest to anyone reading this thread... as much as I have exalted the use of the RD tool, it's actually super simple to make one. Necessity is the mother of invention, because ordered goods take even longer to reach Canada than they do to Ohio.
Report this Post06-27-2020 03:49 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
⚠️ Warning: Clean knuckle hole and new stud before installing new BJ.
Tapers need clean to work right. Tapers do all the real work. Nut mainly holds the taper tight.
Yes, easy to make in several ways...
And RD tool is a just "copy" of Kent-Moore/GM J-26407 listed in Fiero FSM https://www.google.com/sear...ent-moore/GM+J-26407
I make one out of parts from Power Steeling Pulley puller/install kit and 2 iron pipe plumbing fittings.
The kit is common and cheap at HF etc. and had one to install L4 WP.
Used the screw, nut, and maybe bearing plus an ½ coupler and ½ to ¾
Use ½ coupler to remove LBJ, other to remove UBJ.
Note: any tool listed in any GM FSM is a Kent-Moore tool and often use same PN. (KM is now owned by SPX.)
[This message has been edited by theogre (edited 06-27-2020).]
