  Fuel pressure drop with increased throttle (Page 1)
Fuel pressure drop with increased throttle by fierobear
Started on: 06-26-2020 01:32 PM
Replies: 42 (1501 views)
Last post by: fierobear on 07-21-2020 12:47 PM
fierobear
Total ratings: 383
Report this Post06-26-2020 01:32 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is on a Formula pushrod 3.4. The engine swap was done years ago, and ran perfectly for years. The car sat for about 8 years, and I'm trying to revive it. I replaced the fuel pump, cleaned the injectors, new battery. Did the factory manual tests on the evaporative canister. Starts, runs and idles fine. After revving the engine, and/or driving it up and down the block, the fuel pressure drops from 34 lbs to less than 20 lbs, and if you keep advancing the throttle it drops more and will stall. I suspect a bad new fuel pump, or some kind of vapor lock. I really need some suggestions. Thanks.
Total ratings: 461
Report this Post06-26-2020 01:56 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check to make sure your tank is not creating a vacuum, that the pump is having to work against. The easiest way is to loosen the gas cap, and see if the problem is still there.
If it goes away, start troubleshooting the vent lines from the tank.
Try unplugging and capping the vacuum line to the FPR. With no vacuum, it should show increased pressure. Or at least no major reduction.
Also try blocking off the return line. (I've seen some "dull" plastic pliers that are used for just that purpose. Clamps the rubber line without pinching or cutting anything.)
[This message has been edited by Raydar (edited 06-26-2020).]
Blacktree
Total ratings: 350
Report this Post06-26-2020 02:12 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regarding the fuel pressure regulator test, unplug the vacuum line from the FPR while the engine is idling. That will trick the FPR into thinking the engine is at wide-open throttle. Fuel pressure should increase by about 8-10 PSI. If it doesn't, the FPR is probably faulty.
fierobear
Total ratings: 383
Report this Post06-26-2020 03:17 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran some of these tests. I loosened the fuel cap, and there wasn't a change. But the car is on the lift, so it isn't under load. It had fluctuations in fuel pressure, but I wasn't able to replicate the problem of the pressure dropping way off.
Before I take the car off the lift and run it under load, I wanted to talk about the Fuel Vapor Tank, which is located under and forward of the battery. Is there any possible issue that can cause problems with this tank?
fierobear
Total ratings: 383
Report this Post06-26-2020 03:19 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
Member since Aug 2000
I was able to pop the vacuum line off while running, but there wasn't room to cap off the vacuum line. The pressure did go up, but I'm wondering if that could happen due to now having a vacuum leak?
fierobear
Total ratings: 383
Report this Post06-26-2020 04:59 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
Started the car, got it warm and run up up and down the block. Same problem, fuel pressure drops way down, drops more the more throttle you give. During the warm up, revving the engine, it was sputtering and backfiring. When running under power, it pings.
Report this Post06-26-2020 05:53 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think we are all assuming you changed the fuel filter, but you did not include it when listing fixes.
fierobear
Total ratings: 383
Report this Post06-26-2020 06:19 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, sorry, fuel filter was changed when doing the fuel pump.
I used a cheap fuel pump from O’Reilly. Has anyone had issues with new fuel pumps going bad or malfunctioning?
Total ratings: 154
Report this Post06-26-2020 06:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Optimally, fuel pressure should be above 40 psi at idle. The stock regulator is set at 43.5 psi and that's what it should provide when the fuel rail is primed without the engine running. After the engine starts, ideally, the pressure shouldn't drop below 38 psi. With it sitting as long as it has, there's probably a bunch of sediment in the tank. We lost a set of injectors after a car had set for about 4 years, and even a fresh fuel filter didn't prevent the superfine particles from passing through and clogging the inlet to some of the injectors.
[This message has been edited by fierofool (edited 06-26-2020).]
wftb
Report this Post06-26-2020 08:35 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you put in a new rubber line that goes from the the pump to the line that runs to the injector rail hardline? they look good untill pressure builds up and then they leak and bleed off pressure.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
fierobear
Total ratings: 383
Report this Post06-26-2020 09:51 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drained all the old fuel when i changed the pump, and made sure the tank was clean.
fierobear
Total ratings: 383
Report this Post06-26-2020 09:53 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
I replaced all of the rubber lines on the back of the tank with new parts, including the two curved hoses that go to the gas fill.
fierogt28
Report this Post06-27-2020 03:08 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think buying a 'cheap' fuel pump wasn't a good idea.
For the 88 Formula, get an AC Delco EP378 which is the stock fuel pump.
You can always connect a mechanical fuel pump gauge to the fuel Schrader valve to find out the fuel PSI pressure.
Should be between 40-46psi.
I'd clue its the fuel pump.
fierogt28
88 GT, Loaded, 5-speed.
Report this Post06-27-2020 03:45 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure you actually answered the question, as I believe wftb was referring to the short piece of submersible hose in the tank.
Did you put in a new rubber line that goes from the pump to the line that runs to the injector rail hardline? they look good untill pressure builds up and then they leak and bleed off pressure.
Total ratings: 154
Report this Post06-27-2020 08:16 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
We did, too. Even took a water hose and washed the tank out. It was horrible inside. The water coming out after rinsing was nice and clean.
Installed a new pump and screen and removed the pulsator due to bad seals in it. Not only did we have to replace the injectors, but the new Bosch pump failed, too. MikeMac then rinsed it with a commercial wash.
fierobear
Total ratings: 383
Report this Post06-27-2020 01:30 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by wftb:
[/QUOTE]
There is no rubber hose inside the fuel tank, at least not this one. The pump mounts directly to the pulsator, which mounts directly to the hard metal line.
FYI, this is all on a brand new Fiero Store sending unit setup.
fierobear
Total ratings: 383
Report this Post06-27-2020 01:32 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
I plan to order the AC Delco pump, at worst I'll have one on hand for the next reclamation project. I’ll inspect the tank for contamination and corrosion when i change the pump.
Report this Post06-27-2020 03:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah, you still have a pulsator with the new setup. That's where most Fieros these days now have a short piece of hose installed instead... hopefully submersible hose.
fierobear
Total ratings: 383
Report this Post06-27-2020 04:22 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I figured it might be a year specific thing. 88 is definitely pulsator.
Report this Post06-27-2020 05:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, it's a fuel pump specific thing. The earlier years originally had pulsators installed as well. I forget the name of the style of pump from the factory, but a pulsator was required to reduce/eliminate pulses in the fuel pressure. The newer style fuel pumps don't produce these same pulses in fuel pressure, therefore pulsators have mostly become redundant. That's what I've read here over the years anyway.
fierosound
Total ratings: 286
Report this Post06-27-2020 06:31 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
They changed from a roller vane design to a gerotor design.
https://www.onallcylinders....t-fuel-pump-designs/
[This message has been edited by fierosound (edited 06-27-2020).]
fierobear
Total ratings: 383
Report this Post06-27-2020 07:06 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great info guys, thanks.
fierobear
Total ratings: 383
Report this Post06-28-2020 04:48 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Matt Meyer dropped by, and he noticed something that i missed. The vacuum line running from the evaporatorative canister to the throttle body wasn’t connected to the boot on the throttle body. He said that will keep the canister from opening to the gas tank, and will cause a vapor lock. I haven’t connected it yet and done a test run. Probably get on that tomorrow.
Sometimes, its the little stuff you miss...
Report this Post06-28-2020 08:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think Raydar's suggestion of temporarily loosening the gas cap while the engine was running would've eliminated that potential issue, but we'll see!
fierobear
Total ratings: 383
Report this Post06-29-2020 01:51 AM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point! I did mention that to Matt. Ill run it past him.
fierobear
Total ratings: 383
Report this Post06-29-2020 03:02 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
Here is the problem...the vacuum line not working causes a vapor lock situation in the fuel lines, not the tank. That’s why loosening the gas cap didn’t make a difference. I have the Rodney Dickman stainless steel lines, and the bend was off just enough to keep the line from doing its job under vacuum.
Report this Post06-29-2020 07:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting. So it's okay now?
fierobear
Total ratings: 383
Report this Post06-29-2020 08:01 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, no.i put it all back together. Now, instead of it dropping out and sputtering randomly, it has a regular surge and drop pattern under hard acceleration. I didn’t have the fuel pressure gauge on it. Ill rerun that test tomorrow.
fierobear
Total ratings: 383
Report this Post07-13-2020 07:59 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I reran the tests, still had the fuel pressure drop problem
I replaced the fuel pressure regulator with a spare used part, inspected it carefully, looked good. No change to the fuel pressure drops. I figured this left only the hoses or the pump.
I removed the fuel filter, and noticed some rust-colored gas pouring out and some rust in the filter. I finally got a borescope, and took this picture inside the fuel filter:
I dropped the fuel tank, and noticed rust on the inside of the tank, and sediment in the bottom.
I am assuming that the pump is getting clogged with that rust/sediment.
A crusty old car guy buddy suggested I use something he called "sloshing compound" to coat the interior of the tank and seal the rust. Is there a modern name for this, maybe a product recommendation?
[This message has been edited by fierobear (edited 07-13-2020).]
Report this Post07-13-2020 09:17 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know if you've seen This recent post. Might do the trick!
fierobear
Total ratings: 383
Report this Post07-13-2020 10:26 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, that looks promising.
fierogt28
Report this Post07-13-2020 10:39 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like your going to need a new fuel pump and clean that tank. Replace the strainer too.
fierogt28
fierobear
Total ratings: 383
Report this Post07-14-2020 12:40 AM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was planning to replace the fuel pump. Do we assume the existing pump is toast?
fierogt28
Report this Post07-14-2020 01:09 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since avoiding to dropping the tank again, I would put in a new fuel pump as cheap insurance.
fierogt28
fierobear
Total ratings: 383
Report this Post07-14-2020 02:39 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah. I have a new one on hand.
My friend talked about some product that coats the inside of the tank with a paint/sealer type coating. Patrick’s link talks about an acid cleaner, but it doesnt seem to be a coating. Any ideas?
Edit: i reread the link, and it looks like what i need.
[This message has been edited by fierobear (edited 07-14-2020).]
Report this Post07-14-2020 02:55 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.eastwood.com/ga...TEAQYAyABEgJgGfD_BwE
fierobear
Total ratings: 383
Report this Post07-14-2020 03:25 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
That looks great, thanks.
Report this Post07-14-2020 03:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the concerns I might have if I was to use any of these tank cleaning agents is how they could possibly affect the plastic baffles in the tank.
Warlordsix
Report this Post07-14-2020 03:52 PM Click Here to See the Profile for WarlordsixSend a Private Message to WarlordsixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your friend is probably talking about a sealer known as "Kreem," or something similar. I've used it and do not recommend it for old, rusty tanks. It's basically like an acrylic paint. It does NOT remove the rust. It only paints over it, and surface rust is a poor foundation for paint. Over time it loosens up and the paint flakes off. It performs little different in an old, rusted tank (although it might be just fine inside a new tank). In comparison, phosphoric acid reacts with the ferrous metal to remove surface rust and, in essence, create a phosphate coating on the surface of the metal. A phosphate coating is very rust resistant. In the gunsmithing world this is basically called "parkerizing." I use phosphoric acid exclusively. Don't sweat it.
Ernie
Here's a photo of the stuff I no longer use...Kreem...it's just a acryllic/latex-type paint/coating:
'87 Fiero 4.9 5-speed
Warlordsix
Report this Post07-14-2020 03:53 PM Click Here to See the Profile for WarlordsixSend a Private Message to WarlordsixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Warlordsix
Member since Apr 2016
Phosphoric acid comes in a plastic bottle. Don't sweat it.
Ernie
