  88 GT alternator to engine mount bracket
88 GT alternator to engine mount bracket by PAUL66
Started on: 07-03-2020 09:50 AM
Replies: 5 (147 views)
Last post by: Notorio on 07-08-2020 06:18 PM
PAUL66
Report this Post07-03-2020 09:50 AM Click Here to See the Profile for PAUL66Send a Private Message to PAUL66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just resealed my 2.8 and when I put the alternator back on, it is stuck and won’t rotate. When I look at it from the side I can see the bottom of the bracket looks sucked in. I loosened the bracket to engine mount bolt and the problem goes away. I dont remember a spacer between the two but it seems like it needs it. Any Info would be appreciated.
Paul
fierosound
Total ratings: 286
Report this Post07-03-2020 10:55 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only thing behind the low bolt of the alternator bracket is the top end of the L-shaped front motor mount bracket.
It is about 3/16" thick. Was the 88 engine mount bracket different?
[This message has been edited by fierosound (edited 07-03-2020).]
PAUL66
Report this Post07-03-2020 03:25 PM Click Here to See the Profile for PAUL66Send a Private Message to PAUL66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the pic. Now I am stumped, I knew there wasn’t a spacer back there but didn’t have the problem when I took it apart. It’s all original car 88 GT.
PAUL66
Report this Post07-03-2020 04:14 PM Click Here to See the Profile for PAUL66Send a Private Message to PAUL66Edit/Delete MessageReply w/QuoteDirect Link to This Post
PAUL66
Member since Jun 2019
Pics[img]https://images.fiero.nl/userimages/PAUL66/C9 95AA72-9631-48D8-B537-6D88B584CF5A.jpeg[/img]
3rd is without washer, you can see the gap. 4th I put a washer in it and everything is good. I just am not sure why.
fierosound
Total ratings: 286
Report this Post07-03-2020 10:23 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by PAUL66:
... I put a washer in it and everything is good. I just am not sure why.
Things happen.
I had to put a washer behind my lower alternator bracket on my Indy's SD4
as well as behind the rear A/C compressor bracket (was throwing the V-belt)
Notorio
Report this Post07-08-2020 06:18 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hate when that happens ... not a good feeling or confidence inspiring
