  evrv
evrv by michael jatcko
Started on: 07-06-2020 10:14 AM
Replies: 14 (444 views)
Last post by: cvxjet on 07-07-2020 05:13 PM
michael jatcko
Report this Post07-06-2020 10:14 AM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
where is the evrv valve and how do I check it
dremu
Report this Post07-06-2020 12:24 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be helpful to know some background: what year? What motor? Did you get a check engine light, and if so, what was the code?
It could be that you're referring to the EGR solenoid for a code 32, but that's a guess. If so, searching on that name will get you more info here.
-- A
michael jatcko
Report this Post07-06-2020 12:57 PM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
86 fiero v6 4 speed
in the repair manual it shows el. vacuum reg. valve. but it does not show where.
and I can't find it on car
car won't start, but will with either
no codes just code 12
michael jatcko
Report this Post07-06-2020 01:00 PM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
michael jatcko
Member since Nov 2019
in haynes page 278
Report this Post07-06-2020 02:58 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
in haynes page 278
The 'evrv' is likely for another car....Haynes is full of mis-information.
https://www.fiero.nl/forum/A...030204-2-025702.html
Total ratings: 328
Report this Post07-06-2020 05:06 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That valve is called the Electronic Vacuum Regulator Valve. It is used to regulate the vacuum to the EGR valve. If you have a Fiero 2.8L you are probably referring to the EGR solenoid. It can be tested with a VOM for opens and/or continuity.
dremu
Report this Post07-06-2020 05:18 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
86 fiero v6 4 speed
Emissions stuff won't *generally* prevent a start like that, so I don't think the EGR is your problem child. I'd go back to the basics: To run, the engine needs fuel, air, and fire (spark.)
If putting ether (starting fluid) in makes it go, I'm thinking it has air and fire, but is lacking fuel. Check fuel pressure at the manifold (schrader valve on the passenger side, annoying to get to), to make sure the pump is giving you the forty-odd PSI of fuel pressure. Should stay there fore some time (ie not leak down.) No pressure means pump issues (bad pump, wiring, hoses maybe.)
Heck, make sure you can hear the fuel pump CHUNK on at all when you turn the key, or search for the ALDL jumper to manually run the pump briefly.
Also check the fuel injector fuses (IIRC, two of them) in the fusebox.
And check out the "Ogres Cave" link at the top of the page. He'll prolly venture in with some specific links but I'm sure there's something in there about the fuel system.
-- A
[This message has been edited by dremu (edited 07-06-2020).]
cvxjet
Report this Post07-06-2020 05:44 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my (Later version) Haynes manual it shows that valve on page 278...So then I checked in my GM 1985 Fiero manual and it shows there also....I suspect it is only on Automatic cars....SO, although Haynes can be wrong sometimes, this appears to be a direct copy out of the GM book. Page 8A-21-3....The following page has the sensors listed with page numbers for the in depth information page on each....The EVRV is LISTED....But it has NO PAGE listed!
I have personally NEVER heard of this sensor!
RWDPLZ
Total ratings: 306
Report this Post07-06-2020 06:24 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 84 GM Service Manual also has a page for a power steering sensor, the books have issues...
dremu
Report this Post07-06-2020 07:14 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not so much a sensor as a solenoid/valve, but saying that gets it confused with the EGR valve proper on the driver's side of the car. This one goes on the passenger side of the car, hangs off the upper plenum or whatever you call the aluminum thing you did up fancy on your car, forward of and lower of the MAP sensor.
-- A
Report this Post07-06-2020 07:45 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never trust Haynes or Chilton for actuate data for a given year of car. These rags has burned many people. Most times is only a rough guide to find a problem.
For GM and some others Alldatadiy.com has data directly from GM et al FSM for Model, Engine and Year.
Even then GM and other FSM have issues. Example: 84-86 Fiero FSM have many problems w/ rear brakes section and confuse many including Dealer Service staff.
cvxjet
Report this Post07-07-2020 02:31 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
In looking at the EGR valve and the Haynes and GM manuals, the EVRV is actually the EGR control valve.....But the two manuals show differences in wiring- and I can't tell which is right.
So EVRV = EGR valve.....
dremu
Report this Post07-07-2020 02:38 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Then what do you call this?
(As I said above, THAT's the EGR valve. The black gizmo with the wiring is the EGR solenoid.)
Anyway, we're waaaaay off topic for the OP.
-- A
Total ratings: 465
Report this Post07-07-2020 02:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, referring to it as the EGR solenoid certainly helps to avoid confusion.
[This message has been edited by Patrick (edited 07-07-2020).]
cvxjet
Report this Post07-07-2020 05:13 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
-- A
OK....Lesson for the day; When I make a mistake...Don't point it out...Just agree with me!
Bad nomenclature! What I was talking about (EVRV) is the EGR SOLENOID.....the actual EGR valve is easy to find because it sticks up like a mushroom off the cross-over exhaust pipe and when I touch it I smell garbage burning! The EGR solenoid is on the RIGHT side of the engine (the "front")........I'm still lurnin' englush......
[This message has been edited by cvxjet (edited 07-07-2020).]
