  Is 1/4" enough clearance between strut and wheel?
Is 1/4" enough clearance between strut and wheel? by Mct2green
Started on: 08-11-2020 07:29 PM
Replies: 7 (1209 views)
Last post by: Spadesluck on 08-16-2020 04:59 PM
Mct2green
Report this Post08-11-2020 07:29 PM Click Here to See the Profile for Mct2greenSend a Private Message to Mct2greenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installed new 17x7 wheels with 235/45/17 in rear (225 in front) today. Everything looks good except the clearance between the top inside crown of the tire and the bottom of the strut spring. Clearance is right at 1/4". I have driven for a few short rides, and over several speed bumps, and heard no rubbing and the tires show no damage on the inside crown. Is 1/4" enough clearance? Does the gap between the tire and the strut remain constant, meaning when you go over bumps the spring and shock compress and move upward? I will pull the rear tires off in a few days to put eyes on the inside of the tires. I plan on doing coilovers soon which should give more space. Just wondering if there is any issue with the gap I have currently. See Pics
Report this Post08-11-2020 07:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The wheel/tire and bottom of strut move up and down as one. Should be fine.
Report this Post08-11-2020 09:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hub bearings are make to have a little wheel play...
That and tire moving sideways while turning might make tire to hit the strut w/ low clearance.
Tires move sideways on bottom you can see easy but other areas move too.
Spadesluck
Report this Post08-12-2020 08:27 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
If all is in working order it should not be a problem.
BillS
Report this Post08-16-2020 01:06 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have to disagree. I tore two tires up on one of my race cars with double the clearance you have. If you corner hard, the tire rubber moves more than you'd ever think and when it touches the immovable suspension bits it can rip the sidewall out of the tire (or with lighter contact just wears a hole through the sidewall).
The tires can flex more than you'd think - better to have more clearance than to find out the first time you decide to corner really hard that what you have isn't enough.
Blacktree
Total ratings: 350
Report this Post08-16-2020 01:14 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the car is just a cruiser, then it probably won't be an issue. But in hard cornering, there may be some interference.
Report this Post08-16-2020 03:11 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are we interpreting the image and info supplied above differently? Looks to me like there is no issue with the sidewall whatsoever. What's it possibly going to rub on?
Originally posted by Mct2green:
...the clearance between the top inside crown of the tire and the bottom of the strut spring. Clearance is right at 1/4".
Spadesluck
Report this Post08-16-2020 04:59 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would have to agree with Patrick on this. From the angle of the picture it looks as the shock/spring are above the tire by a 1/4 of an inch. How would the sidewall hit this under hard corning? Maybe the tire will flex out some at speed but don't think it will be anything to worry about.
