  88 Formula suspension
88 Formula suspension by Rex Raider
Started on: 08-23-2020 07:33 PM
Replies: 7 (392 views)
Last post by: falcon_ca on 08-26-2020 06:40 PM
Rex Raider
Report this Post08-23-2020 07:33 PM Click Here to See the Profile for Rex RaiderSend a Private Message to Rex RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, Newbie to forum
I picked up a 88 Formula last year.
She has 109,000 on her so it is time for some TLC.
I am starting with the front end.
This is my 3ed Fiero so I know my way around pretty much but this is my first with the newer supination.
It is straightforward so I am getting right through it with little hasal,That is until I got to torquing down the sway bar link.
The sway bar is coming in contact with the tie rod and the torque wrench is not even registering yet.
I am sure it will be fine when it down on all four but I am worried I might damage the tie rod if I continue torquing.
Total ratings: 465
Report this Post08-23-2020 07:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Without looking at my Formula, I'd guess that those sway bar end links might be too short. I believe the sway bar arms should be more parallel to the ground.
Do you need to have the front suspension hanging down while you're tightening the end links. I think I'd prefer to have the suspension loaded (closer to ride height) as I snug up the end links.
[This message has been edited by Patrick (edited 08-23-2020).]
Total ratings: 461
Report this Post08-23-2020 07:57 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hard to see exactly what you've got, but between the lower control arm and the sway bar, there should be a bolt, with a sleeve, about 4-5 inches long.
I have been doing 88s for years, and have never had one where the tie rod and the sway bar contacted one another - even when it was up on jacks.
Edit - Looks like Patrick saw about the same thing that I did. Sway bar looks waaaay too close to the LCA.
[This message has been edited by Raydar (edited 08-23-2020).]
Daryl M
Report this Post08-24-2020 12:29 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Parts geek has them, but parts geek also lists them on Ebay for 4 bucks less and free shipping.
liv4God
Report this Post08-24-2020 05:23 AM Click Here to See the Profile for liv4GodSend a Private Message to liv4GodEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the length of the new end links versus the old ones. You may have been sent a set that is too short.
I had my Formula on jacks this weekend doing brakes and there was plenty of room between the sway bar and tie rods even up on jacks.
When lowered to the ground there won't be much difference since the tie rod will also move relationally to the wheel. I would try to find some longer ones.
Edit to add: It's quite possible those are the end links for the rear sway bar, as it requires a much shorter end link and would still come up as an 88 formula end link when searching online.
[This message has been edited by liv4God (edited 08-24-2020).]
Rex Raider
Report this Post08-24-2020 07:21 AM Click Here to See the Profile for Rex RaiderSend a Private Message to Rex RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
That makes sense, I'll go thru my scrap box and retrieve the old one. Thank You for the help
Rex Raider
Report this Post08-24-2020 11:26 AM Click Here to See the Profile for Rex RaiderSend a Private Message to Rex RaiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rex Raider
Member since Aug 2020
That was it, Thanks Again
falcon_ca
Report this Post08-26-2020 06:40 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might have Rodney Dickman's lowering ball joints.
A Lot of 88 owners install those to easily lower the front end.
You need longer end-links with those.
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 | Work done 11-12 | Work done 12-13 | Work done 13-14 | Work done 15-16 | Work done 16-17 |Work done 17-18 |Work done 18-19 |Work done 19-20 |4.9 Swap |
