Get yourself a door spring compressor. Many auto parts chains carry them.
[URL=https://www.ebay.com/i/272320911725?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=272320911725&targetid=934793864576&device=c&mktype=pla&googleloc=9011014&poi=&campaignid=10454706842&mkgroupid=100467643101&rlsatarget=aud-62252404151 8]https://www.ebay.com/i/2723...get=aud-622524041518[/URL]
la -934793864576&abcId=2146000&merchantid=6519984&gclid=EAIaIQobChMIt8zU7rq26wIVDI7ICh0miQVcEAQYBCABEgLTTvD_BwE
and open it up then insert it into the spring as far as you can push it. Ideally, the cable should be at the full depth of the V slot. Tighten down on the nut to compress the spring to the point it will come loose from the tabs on the caliper bracket and ebrake arm. Once the spring tension is off the arm, you can use a pair of channel locks, needle nose, or slip joint pliers to twist the end of the cable out of the ebrake arm. At that point you can slide the spring off the cable.
Next, to detach the cable from the caliper, you can slide a socket of the appropriate size (I think it's a 10mm) over the end of the cable and push it against the retaining tangs to let the cable slide back out of the caliper bracket. You can also use a pair of 45* needle nose to release the tabs as you pull against the cable sheath.
[This message has been edited by fierofool (edited 08-25-2020).]
