  Door hinge spring apparatus rebuild
Door hinge spring apparatus rebuild by Daryl M
Started on: 08-29-2020 02:36 PM
Replies: 11 (161 views)
Last post by: Daryl M on 08-29-2020 06:58 PM
Daryl M
Report this Post08-29-2020 02:36 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am rebuilding my doors and have not found replacement plastic bushings for the roller that stops the door from swinging freely, so I am making them. Is anyone interested in seeing how I am doing it? If so, I will post photos.
Daryl
Report this Post08-29-2020 03:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes!
The driver's door of my Formula "squawks" from the roller area every time I open and close it. No amount of lubrication will get rid of that annoying sound. I can see that the roller and/or what it rotates on is worn.
Daryl M
Report this Post08-29-2020 06:15 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what you start with. 50 cents at the hardware store in the little drawers with the bolts and nuts. 1/2" O.D. 1/4" I. D.
[This message has been edited by Daryl M (edited 08-29-2020).]
Daryl M
Report this Post08-29-2020 06:19 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Member since Aug 2016
Cut a slot down one side with a rotary grinder .
Daryl M
Report this Post08-29-2020 06:22 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Mark and cut to the proper length. I used my lathe to get a straight cut, but that is not necessary.
Daryl M
Report this Post08-29-2020 06:26 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Grind a small bevel to one end , then use a vice to press the plastic bushing into the metal roller. My rollers were in ok shape.
Daryl M
Report this Post08-29-2020 06:29 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Use a 5/16" bit to ream out the hole to the proper size.
Daryl M
Report this Post08-29-2020 06:31 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Use a hammer and punch to gently tap the plastic bushing out of the metal roller. I didn't get a good photo of the rest of the procedure, but it is pretty straight forward. Lube the plastic bushing with grease and slide it on the pin it goes on. If the pin is damaged, you will have to find another hinge to rebuild, but I had one good set. Last use a small piece of pipe or a deep socket and hammer to tap the metal roller onto the plastic bushing.
Daryl M
Report this Post08-29-2020 06:40 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
This probably should have been the first photo. I used a roller change breaker tool to remove the metal roller in the first place. A c-clamp will compress the spring.
Daryl M
Report this Post08-29-2020 06:54 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Finished product
Daryl M
Report this Post08-29-2020 06:57 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
This is a photo of a damaged pin that would require replacement, and a photo of a c-clamp used to compress the spring.
Daryl M
Report this Post08-29-2020 06:58 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
THE END.
