  Where to run wires from passenger compartment through firewall into front compartment
Where to run wires from passenger compartment through firewall into front compartment by imacflier
Started on: 09-05-2020 08:26 PM
Replies: 6 (175 views)
Last post by: cmechmann on 09-08-2020 08:24 PM
imacflier
Report this Post09-05-2020 08:26 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Evening, All,
I swear I saw this recently but can't find it.
I need to run some wires from the cab through the front firewall into the front (spare tire) compartment. What is the easiest method of doing so?
TIA,
Larry
rbell2915
Report this Post09-05-2020 09:04 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by imacflier:
Evening, All,
TIA,
Larry
I ran the wires for my auto dimming mirror's temp sensor through a hole near the pedals. I can try and get a photo for you tomorrow.
imacflier
Report this Post09-05-2020 10:40 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
rbell2915,
Thanks! I would appreciate it!
Larry
rbell2915
Report this Post09-08-2020 04:46 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Inside the cabin. Wires go through the hole for the clutch.
In the front compartment.
cmechmann
Report this Post09-08-2020 05:41 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depending on the gauge of the wire. If you want to keep the clutch hole open for other things, there is a bulk connector above the gas pedal. This is where the wiring for the HVAC, radiator fans and some lighting. If you only have a few wires, there is normally a few places in the bulk connector that don't have spaces occupied.
imacflier
Report this Post09-08-2020 06:01 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
My hole is in use for the clutch! But I am sure I can find space on that bulkhead with a bit of looking.
Thanks to all!
Larry
cmechmann
Report this Post09-08-2020 08:24 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some more info.
