  Replaced Getrag Shifter Select Cable
Replaced Getrag Shifter Select Cable by Kelvin Vivian
Started on: 09-12-2020 11:02 PM
Replies: 5 (905 views)
Last post by: cvxjet on 09-13-2020 11:25 AM
Kelvin Vivian
Report this Post09-12-2020 11:02 PM Click Here to See the Profile for Kelvin VivianSend a Private Message to Kelvin VivianEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 GT had developed difficulty in its shifting a few years back - it was difficult shifting side-to-side to find the gears. It was probably about 3 years back that I had purchased a set of Rodney Dickman shifter cables, including the shifter select cable, but back then I never replaced the shifter select cable as I had called around a few shops and friends to see if they could do the job for me, but it seemed shops were reluctant to use customer-sourced replacement parts, and my go-to local Fiero guru friend was busy on other projects. Since I rarely drove the car, I just continued to drive the car from time-to-time with its notchy shifting - I just had to use more effort as I shifted the shifter sideways.
That was until this past Friday night - after having read Avengador's archived write-up on how to replace the shifter select cable, I figured I could do it on my own. I did not unplug the ECM and therefore did not have to disconnect the battery. I also did not have to remove the plastic skeleton of the center console - I did, however, remove the two screws closest to the firewall (and unclip the 4 carpet clips (two on each side) holding the carpet to the skeleton) so that I could fish/pull the shift select cable through/underneath the skeleton as I lifted the skeleton.
The most challenging part for me was figuring out how to release each single c-clip that respectively secures each end of the shifter cable. I used the head part of a hammer wedged against some other metal part near each c-clip to pry each c-clip loose. I was also successful in re-installing each c-clip by hammering down each c-clip as I held each end of the shifter cable in place as far as I could within its retaining structure. There is also a rubber grommet in the firewall through which the cable goes through at the firewall. When inside of the car (after having removed the center console/glove box, unbolting the ECM and laying it aside while still connected, and removing the plastic frame holding the ECM), you can pull on the rubber grommet and it will pop off the firewall but it will still be connected to the old shifter cable. To remove the grommet for reuse on the new cable, I used a razor blade knife to cut a slit in the grommet from an inner edge closest to the cable to the outer edge - once doing so, you can pull the grommet off the old cable and then place it on the new cable.
I routed my shifter cable underneath the cross-over tube (rather than over as the original had been routed). The cable is close to the exhaust down pipe (e.g., 2 inches), but it's not touching it and the Rodney cable includes a double-sleeved heat shield to protect the cable so it should be ok, but I did buy some large zipties to ziptie the cable so that it does not come into direct contact with the exhaust down pipe.
The 5-speed shifter now shifts flawlessly with ease side-to-side, there's no need to hunt for gears. If I can do this job, anyone can do this job - it just takes patience and a good write-up to follow. Avengador's write-up gave me the confidence that I could attempt this job myself, and I also first tested to see if I could figure out how to pry loose the c-clip holding the rear part of the shifter cable to its retaining structure in the engine bay - once I loosened that c-clip loose with the head end of a hammer I was off to the races... and two hours later, the job was done!!! I'll post pics of the completed job soon.
If you need to replace your shifter select cable, go with Rodney's well engineered cables - they can withstand the temps reached within the confines of our engine bays - the heat shield is a MUST HAVE given that the cable routes near the exhaust down pipe. Happy Fiero-ing. - Kelvin
88 GT T-Top 5-spd #338 of 1252
87 SE 4-cyl 5-spd sunroof, spoiler, performance sound
85 2M4 base coupe T-Top 5-spd, rackless decklid, 15-in 88 GT rims, aero-conversion
fierosound
Total ratings: 287
Report this Post09-13-2020 12:47 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
cvxjet
Report this Post09-13-2020 01:10 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just did this 3 months ago- changing the shift cables....just take it slow!
I noticed that my Select cable was right against the exhaust down-pipe, so I bent the bracket that holds it at the transmission to angle it away from the exhaust- instead of 3/4" I now have 2 1/2" gap...and then installed a heat shield of my own design.
The shift cables that were in it had really deteriorated- in fact the select cable BROKE- could not move the rest of the cable afterwards. After changing them I could move the shifter sideways with my little finger!
[This message has been edited by cvxjet (edited 09-13-2020).]
fierosound
Total ratings: 287
Report this Post09-13-2020 01:26 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getrag 5-speed cable routing.
http://www.meisners.net/Fiero/TSB/TSB88714.htm
Kelvin Vivian
Report this Post09-13-2020 06:51 AM Click Here to See the Profile for Kelvin VivianSend a Private Message to Kelvin VivianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats on your successful replacement, too! Bending the bracket that holds the cable at the transmission seems like an interesting idea to further angle the cable away from the exhaust pipe. I'll look into that tomorrow as I've not yet ziptied the cable to anything, but as it is routed now, I believe that it's ok without zipties... I'd rather not use any zipties as it get fairly hot in the engine bay... - Kelvin
cvxjet
Report this Post09-13-2020 11:25 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is some more pics of what I did...I did not bend anything very far and then used spacers to move the bracket out to the left a bit also to help and align the cable.
