  heater radiator connection V8
heater radiator connection V8 by moi-maxim
Started on: 10-10-2020 08:18 PM
Replies: 3 (449 views)
Last post by: fierosound on 10-11-2020 11:44 AM
moi-maxim
Report this Post10-10-2020 08:18 PM Click Here to See the Profile for moi-maximSend a Private Message to moi-maximEdit/Delete MessageReply w/QuoteDirect Link to This Post
so hi every body first off im from quebec so sorry for my english !
i have a 350 TPI in my fiero and install a electric pump in the quarter panel and i let the OEM tubing under the fiero and i didnt plug the outlet/inlet of the heater radiator . the one connect to the OEM tubin under passenger side is still connect but the other hose is not connect and i am wondering where is suppose tu be i try to draw a litle plan of my system !
hope you guys can understand and help me out !!!
fierosound
Total ratings: 286
Report this Post10-10-2020 08:45 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
We don't know what exact year of engine or intake manifold style you have.
Generally, there should be a connection on the intake manifold near the thermostat housing for the heater hose TO the heater core.
I found this diagram for a TPI engines, and the hose connection seems to be directly under the throttle body.
[This message has been edited by fierosound (edited 10-10-2020).]
moi-maxim
Report this Post10-10-2020 09:51 PM Click Here to See the Profile for moi-maximSend a Private Message to moi-maximEdit/Delete MessageReply w/QuoteDirect Link to This Post
that would make sense because this hose is block since i bought the car so maybe is the answer !
fierosound
Total ratings: 286
Report this Post10-11-2020 11:44 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrong connection. I think that's air to valve cover for PCV system.
https://www.thirdgen.org/fo...i-owners-i-need.html
The Throttle Body has coolant running through it so it doesn't freeze in winter conditions.
It is unnecessary in summer and if you never drive in winter.
In a normal system, coolant OUT to heater core would be connection "2".
If you want to bypass Throttle Body heating, connect hose to heater core to connection "1" (remove U-shape hose)
This guy has flow direction backwards when he explains it, but it shows the connections.
[This message has been edited by fierosound (edited 10-11-2020).]
