  Manual R/H mirror ball joint tensioner
Manual R/H mirror ball joint tensioner by Time Traveller
Started on: 11-01-2020 02:10 PM
Replies: 1 (84 views)
Last post by: theogre on 11-01-2020 02:33 PM
Time Traveller
Report this Post11-01-2020 02:10 PM Click Here to See the Profile for Time TravellerClick Here to visit Time Traveller's HomePageSend a Private Message to Time TravellerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My manual R/H mirror finally went from loose to dangling. After removing the pivot assembly from the housing and successfully removing the glass without breaking it, I see this little plastic or fiberboard plate that tensions the ball has split. I'm guessing I should drill out the rivets and replace it with something, but after reading every forum result and every parts search on mirrors, all I can find is new glass, or a whole new housing and assembly. Suggestions on this?
[This message has been edited by Time Traveller (edited 11-01-2020).]
Report this Post11-01-2020 02:33 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You sure it isn't sheet metal? Looks like a simple stamped metal part. Maybe spring steel stamped then heat treated.
When you drill out the rivets, make sure that won't spin. Spinning can easily wreck the plastic even if doesn't touch directly.
Might use other things to replace it but may not last long. So likely don't want to make it hard to fix again.
Think this part is same part use in other cars w/ same shape glass even tho mirror shells are a bit different.
