  Fuel pump relay wiring weirdness
Fuel pump relay wiring weirdness by 842m4SE
Started on: 11-03-2020 04:57 PM
Replies: 2 (685 views)
Last post by: CSM842M4 on 11-05-2020 06:13 PM
842m4SE
Report this Post11-03-2020 04:57 PM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all, just dropped the tank and have all the hoses disconnected one way or another. The only thing left is the wiring and the fuel pump relay to disconnect. The only thing is I can't seem to find which relay it is. I've looked all over in my manual(s) and I can't find it, and the 84's wiring is very different from other years. The wires also seem to go into taped or wrapped bundles, so how do I get the tank and the wires free?
[This message has been edited by 842m4SE (edited 11-03-2020).]
Report this Post11-03-2020 06:16 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tank wire disconnect is 3 pin weather pack (C502) on firewall just above the tank tunnel, below two wire bulkhead pass thru seals.
CSM842M4
Report this Post11-05-2020 06:13 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Listen to the ogre! The connector can be a heartbreaker to find, but if you follow the wires up to the engine compartment, you will eventually find it. I've disconnected and re-connected it both from under the car and leaning over it, but you gotta want it.
