Yes, is no "Best HL" for anything. Even many New vehicles w/ "bright" HL don't perform as many would think.
Many Aftermarket "DOT legal" bulbs have lawsuits for crap lighting and short life including "big names" like Osram/Sylvania.
IIHS have tested several new cars and trunks and found problems too. Many modern HL barely Pass FMVSS rules because many car makers spend absolute minimum to design and make HL assembles even on many "luxury" models.
For Fiero and many others... Most "new" halogens are brighter and hotter
because eats more power. Including Sealed Beam SilverStar and many others pulls more power.
Many "old" cars can barely handle OEM 35/60w halogens w/o problems. Worse problems after 5 - 10 years of driving in many places...
So "Dim" OEM Halogens HL is not the bulbs many times but wiring problems. Install new hot bulbs may seem to work while make wiring problems worse.
See my Cave,
HeadlightsIf you or Prev Owner already have used SilverStar etc... These bulbs don't last long to start, only rated a few hundred of hours, and make more/worse electrical problems.
Short lifetime is/was on sylvania FAQ but seem data it moved again. Others use FAQ etc to buried short lifetime too and not listed w/ other spec's for a bulb.
Even if you ignore most LED are crap... DOT Legal LED from GE Trucklite etc have problems and many don't last as ad's say.
IOW Even if you buy high $ Trucklite LED, electrical issues/problems in a vehicle can quickly kill them and makers can void any warranty blaming the car.
Plus most HL Buckets don't let air flow to back of "bulb" to cool the LED. Backs are heat sinks for LED.
Note: If you flip HL to change them in cave... Carefully watch the front "flap" hitting the hood... the "flap" can break/cut the bumpers the door hit when closed.
