  New Spare Tire Available
New Spare Tire Available by Boozeman
Started on: 12-02-2020 01:42 PM
Replies: 20 (819 views)
Last post by: johnyrottin on 03-14-2022 09:16 AM
Boozeman
Report this Post12-02-2020 01:42 PM Click Here to See the Profile for BoozemanSend a Private Message to BoozemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I needed to replace my spare, as the original either blew apart sitting in the frunk, or the PO attempted to drive on it, causing it to come apart:
I had searched this forum only to find that folks were having a hard time finding a suitable replacement that would fit the original spare rim and/or fit in the area where the spare lives. After some searching, i did find that there is indeed a tire is available to fit these spare tire rims. I was able to order the Kumho 125/70R15 95L tire from my local Firestone Car Care center (yoiu can't find it on their website), and had them mount it for me. Total cost was about $65:
Just thought I'd pass this along in the event it might help someone replace their spare.
Report this Post12-02-2020 01:55 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great info. Most of us are driving around with mid 30 year old spares. Wear and age influence tire strength. If the original OEM spare is kept fully inflated and not exposed to bad environmental conditions; for a short distance at reasonable speed, it should be able to get you to the next service station or tire store. The one shown in the pictures here appears to be an old tire driven on low air pressure for more miles than the tire is rated for. These are short distance lower speed tires. Keep that spare inflated. Still no guarantee it will work but there are reports here that these unused old OEM spares work.
[This message has been edited by Dennis LaGrua (edited 12-03-2020).]
cvxjet
Report this Post12-02-2020 03:48 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your tire pressures at least once a month- and when doing that also Check your spare...a >>FLAT<< spare is NOT a spare....(And they should be inflated to whatever is stated on the side of the tire (I have a Subaru spare to clear my 12" front brakes)
Report this Post12-02-2020 08:57 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has been covered before but not recently...
While spare tires will "rot" from age... Looks more like Old tire was "run flat" cause belt failure then stored again. New regular and spares tires can and do have same failure w/ low inflation.
Above is T125/70D15 95M. Just read label and sidewall.
Other brands also makes them.
Tire Rack has complete spares and tire alone.
Sells, or did in past, compete spares, tire w/ rim, because many stores won't mount spares.
enter site and fill in car, then https://www.tirerack.com/ti...erfCat.jsp?perf=TEMP
Or easier email them about T125/70D15
If you have them mounted, should ask DOT Date Code are on same side and neat the fill valve.
Tire Date Code only "stamped" on one side in one spot.
Think above is close to that so can read w/o pulling tire out. Loosen the "clamp" and rotate valve point to MC should show DOT data.
For very old tires, Last 3 numbers of SN is Date Code as WWY, Week of Year
Problem was Y was same 70's 80's and 90's tires... IOW WW6 but which Decade? A lot of "New" tires was 10+ years old stored god knows where and how.
Is part of Why after 1999 last 4 digits of DOT code is WWYY
eelecurb
Report this Post12-05-2020 07:43 PM Click Here to See the Profile for eelecurbClick Here to visit eelecurb's HomePageSend a Private Message to eelecurbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good post. I did the same. Got my new spare at Discount Tire for $61 plus $30 to mount it to the original rim.
Total ratings: 463
Report this Post12-06-2020 07:12 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
What I need is a spare that will fit over fieroguru's 13" brakes, as well as fitting into the front compartment, over a front mounted battery.
Bueller? Bueller?
Rickady88GT
Total ratings: 200
Report this Post12-06-2020 08:11 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Under inflation is the number one cause for tire failures. When under inflation is compounded with other factors, the tire failure can obviously be catastrophic and unpredictable.
Rickady88GT
Total ratings: 200
Report this Post12-06-2020 08:12 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rickady88GT
Member since Dec 2002
I have never used one of these on a Fiero, every Fiero I ever owned had a spare tire in mint condition.
eelecurb
Report this Post12-06-2020 08:26 PM Click Here to See the Profile for eelecurbClick Here to visit eelecurb's HomePageSend a Private Message to eelecurbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine "looked" mint but wouldn't hold air long term. And it was 32 years old so I didn't trust it.
Rickady88GT
Total ratings: 200
Report this Post12-06-2020 08:41 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I totally agree. Tires have an expiration date. Most people just don't know it.
I used to work at Pirelli building Tires. At one time I was told to cut and destroy several pallets of PZerro Tires that were specifically made for Lamborghini. These tires hade been in storage to long and destroyed. I have no idea how much the total value of the Tires were, but each tire at the time was selling for over $600 each. They were freaking wide and unbelievable low profile. I myself cut and carved off the DOT number from pallets of these Tires.
Report this Post12-06-2020 11:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Expiration date" is 6 years after date code in most doc's and web sites including NHTSA site.
Many vendors and manufacturer will destroy unsold new tires in less then that for several reasons.
Unsold and unmounted tires still "rot" from crap in the air, more so in most shops and warehouses allows oil and other fumes, dirt, etc, getting to the inventory.
Mounted then 99+% will have wet oily and otherwise polluted air use to keep up inflation and "rot" inside out so Spares may look new outside and still be bad.
Even when compressor has no oil in it often still output wet polluted air.
Plus spare tires under stress holding 60 PSI (~ 4 Bars) 24/7 for 10+ years mean isn't just Fiero needed new spares.
Instead of fill 60psi every month... keep small cheap compressor. Then when you need the spare, can inflate to 60 w/o risk of belt fail or worse.
Any tire under a few % of "full" of door frame sticker are "Running Flat." When you see a tire is low by looking, tire has a short life or is "dead" even after filling.
"Running flat" starts happening at higher pressure these tires so running 40-50PSI can easily destroy them.
RacerX11
Report this Post12-07-2020 09:20 AM Click Here to See the Profile for RacerX11Send a Private Message to RacerX11Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will vote for " blew apart sitting in the frunk" on this one. I have seen an identical failure as the original post, and it was not due to driving on the tire underinflated. It was a mid-90's Saturn a friend recently purchased. The spare had no air, so he aired it up. About a month later he had a flat, went to retrieve the spare, and it looked just like this tire. Theory is the tire had been in the car for so long with no pressure, the tread rubber took a set. Once inflated to proper pressure, the aged/rotted tread soon delaminated. All belts intact, still held air.
Old tires = bad, and keep your spare properly inflated.
Rickady88GT
Total ratings: 200
Report this Post12-07-2020 10:01 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correction,..replace "old" tires. They have a life expectancy of less than 30 years,.....to say the least. No matter the manner or method of storage.
Not that I completely disagree with what you said becauseyou did not say anythingwrong (persay), but old is old and old tires are dangerous tires. You can never tell when or how bad they will fail.
Even the tires that look perfectly good, as in my case, they still can not be trusted with your life or anyone else's. Just spend the $100 or less for a reliable spare. THEN , keep the spare up to regulation.
Stay safe out there people
fireboss
Total ratings: 58
Report this Post12-09-2020 12:28 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bueller? Bueller?
try here
jim94
Report this Post03-11-2022 05:28 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just had mounted a continental tire spare. I feel better now, I will not be stranded away from my house.
Cokeologist
Report this Post03-11-2022 05:52 PM Click Here to See the Profile for CokeologistSend a Private Message to CokeologistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Size and source?
cvxjet
Report this Post03-11-2022 07:48 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bueller? Bueller?
Raydar, I have 88 brakes with 12" Vette discs....I was able to get a spare out of a Subaru that would clear these brakes- may be able to clear your 13s...
Not sure how old the tire is- but I'd like to replace it; Does anyone know where I could find a 115/70-16?
reinhart
Report this Post03-12-2022 07:58 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I certainly wouldn't be concerned about "my life" driving 5 miles on a spare at 35 mph, even if the spare is 40 years old. Especially in a low profile vehicle like the Fiero.
Everyone should have a $20 tire pump in the trunk that plugs into the cigarette lighter. I've had times where I came back to the car and I could tell I had rolled over a nail or something and the air was slowly leaking out and I'd top off the tire, drive it home to pull the nail and patch the tire or remove at home and take to a tire shop. You shouldn't need to install a spare in a situation like this (slow leak) and the time and dirtiness of doing that in a parking lot rather than having a $20 tire pump makes it a no brainer.
As Ogre said, it probably does stress the tire over time having it in the front compartment at 70 psi. I typically will check and fill mine if I'm going on a long trip, otherwise it's probably wise to keep it at 40 psi and then top it off to the spec when you install it using a tire pump in your trunk.
Spoon
Total ratings: 61
Report this Post03-13-2022 06:21 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
A co-worker bought a new 85 Pontiac Trans Am and he claimed the factory tire would not fit in the trunk even when flat. He could put the donut on but if there were 4 occupants total someone would have to walk. Maybe two come to think of it.
Should you have a flat where are you guys putting your oversized tires in the Fiero?
Spoon
fierosound
Total ratings: 286
Report this Post03-13-2022 07:15 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even a regular Fiero wheel will only fit in the rear trunk.
Gotta keep it reasonably empty or move that stuff to the front after you get your spare out.
johnyrottin
Total ratings: 85
Report this Post03-14-2022 09:16 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Keep a full size spare on the same rim you use on your car at your house…and towing on your insurance policy. Best peace of mind there is.
