Appreciate PFF? Please consider making a donation.
Pennock's Fiero Forum has been the largest source for Fiero related information during the past 23 years and it has always been free for everyone - members, vendors and visitors. However, it isn't free for me to maintain. If you want to help me keep PFF up and running, please consider a donation. Your support will be greatly appreciated. Not only by me, but by the thousands of daily visitors that use PFF. If you want to make a donation (PayPal, Bitcoin, Ethereum, etc.) please (or simply send your PayPal donation to info@pennock.nl).
Thanks!
Cliff Pennock
  Ignition switch wires.
Ignition switch wires. by Chief08
Started on: 12-10-2020 02:12 PM
Replies: 6 (496 views)
Last post by: Chief08 on 12-12-2020 01:18 PM
Chief08
Report this Post12-10-2020 02:12 PM Click Here to See the Profile for Chief08Send a Private Message to Chief08Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
I'm working on installing a keyless entry with push button start. One of the things I need to do is cut the red wire from the ignition switch to the battery, however there are two red wires. One comes out of the blue connector and one comes out of the black connector, I'm not sure which on to cut. Here is a pic of the instructions.
Rick Vanderpool
Report this Post12-10-2020 03:03 PM Click Here to See the Profile for Rick VanderpoolSend a Private Message to Rick VanderpoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 factory service manual and it shows both red wires coming from the same source and connected together inside the switch. I can only surmise it is for redundancy.
Rick
Chief08
Report this Post12-10-2020 03:16 PM Click Here to See the Profile for Chief08Send a Private Message to Chief08Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rick
You may be right, the manual is a bit unclear..
Rick Vanderpool
Report this Post12-10-2020 04:33 PM Click Here to See the Profile for Rick VanderpoolSend a Private Message to Rick VanderpoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you look at page 202-12 you'll see the 2 ignition switch plugs. B2 is in the blue 1 and B3 is in the black 1. Both red wires come from S206 and are connected together inside the switch.
Chief08
Report this Post12-10-2020 07:28 PM Click Here to See the Profile for Chief08Send a Private Message to Chief08Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for pointing that out. I still don't know which one to cut though.
Rexgirl
Report this Post12-11-2020 03:11 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are two red power wires because the Pontiac ignition switch apparently provides a LOT of current to the Fiero's components. My guess is that the iKey is low current and designed for new cars that have relays for high current needs. Your new iKey Module must be able to handle the same current flow (25 plus amps?.. total guess) as the Fiero's ignition switch. If it can, cut both red wires and connect their battery side to your big red iKey wire. If not, you will need relays.
Chief08
Report this Post12-12-2020 01:18 PM Click Here to See the Profile for Chief08Send a Private Message to Chief08Edit/Delete MessageReply w/QuoteDirect Link to This Post
The I key module requires two positive and two negative wires to be connected directly to the battery, and it can handle the current. I cut both red wires, so we'll see how that works out.
