  84-87 suspension knuckle bumps
84-87 suspension knuckle bumps by pmbrunelle
Started on: 12-27-2020 04:10 PM
Replies: 9 (515 views)
Last post by: Will on 12-29-2020 09:10 AM
pmbrunelle
Total ratings: 63
Report this Post12-27-2020 04:10 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is their function?
Can they be safely cut off? Looks like an easy weight savings.
84-87 front knuckles have them.
84-87 rear knucles have them.
[This message has been edited by pmbrunelle (edited 12-27-2020).]
ltlfrari
Total ratings: 127
Report this Post12-27-2020 05:36 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not totally sure and i'm too lazy to actually go and look but on the front I think it is a steering lock stop. Probably on the back because the back is just a front suspension that's been locking in place.
Dave
www.ltlfrari.com
Report this Post12-27-2020 07:04 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely is that...
Yes Fronts knuckle hits stops on LCA or other metal parts when turning so tires don't hit whatever.
Fronts rub and often make noise if you turn and hit pot holes etc. as well because no-one ever lube them w/ thin film of brake grease.
So fronts stop areas are bigger to handle full suspension up/down while turning.
Fiero Backs are front end parts off another GM car. Might save some weight by cutting/grinding but do this wrong and causes problems as can start stress risers etc.
pmbrunelle
Total ratings: 63
Report this Post12-27-2020 07:39 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the Fiero front, steering stops are included in the brake caliper brackets:
So the steering stop function is already handled by the feature on the brake caliper bracket, in the 84-87 Fiero.
I found a photo of a front knuckle on PFF, and I circled the front knuckle bump:
Maybe its a vestigial bump because the front is also parts-bin?
Total ratings: 236
Report this Post12-28-2020 08:55 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a steering stop for the other direction.
pmbrunelle
Total ratings: 63
Report this Post12-28-2020 12:28 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Talking about the bump on the front knuckle? If both my caliper brackets have stops that hit the LCA, then these knuckle stops would be redundant, right?
At right full lock, the RH caliper stop should hit the RH LCA.
At left full lock, the LH caliper stop should hit the LH LCA.
Makes sense?
Report this Post12-28-2020 07:43 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes nearly all vehicles not just cars one part of knuckle on each side hits stop turning L to L.
Fiero FSM seems doesn't cover this.
Not crawling under car in winter to look how done or exactly where stops contact.
If front knuckle has "spare metal..." Could cut/grind but have same warning as above.
Is likely ductile iron but can break if someone screws up cause stress risers and related problems.
[This message has been edited by theogre (edited 12-28-2020).]
DimeMachine
Report this Post12-28-2020 08:03 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
If a guy were to cut off the chunk with a thin cut off wheel and then smooth the area that was cut with something like a 36grit roloc disk - that should minimize any risk of stress risers - or is there a better method? I still find it hard to believe newer cars use aluminum knuckles - i would think much weaker than iron...?
[This message has been edited by DimeMachine (edited 12-28-2020).]
pmbrunelle
Total ratings: 63
Report this Post12-29-2020 12:33 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not too worried about stress concentrations.
As I transform my Fiero from lowly econobox into my vision of a high-end sports car, rough cast parts with visible parting lines are smoothed into fancier-looking parts.
Some benefits:
Making smooth surfaces and gradual transitions between sections reduces stress concentrations.
Without jagged corners, paint film thickness becomes much more even, so you're less likely to get rust starting at the outside corners were the paint is thin.
Looks nicer!
Here is an unmodified GM Metric caliper:
Unsightly...
Here is a GM Metric caliper that I ground and sanded smooth:
After I sandblast and recoat this shiny red, it's something that I could display behind an open-spoke wheel.
For smoothing castings, I use a combination of:
Angle grinder / thin cutoff disc (for cutting off huge chunks)
Lathe/milling for more "controlled" material removal
Angle grinder / flap wheel
Angle grinder / grinding disc
Files
Sandpaper
Wirewheel
Total ratings: 236
Report this Post12-29-2020 09:10 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The load on the tie rod is pretty low anyway, so not much of a concern.
Some benefits:
Looks nicer!
Unsightly...
Files
Sandpaper
Wirewheel
You know, at least for the Camaro version of the Metric caliper, PowerStop will sell you reman ones that are already powder coated red. RockAuto carries them.
