  New Wheels . . .
New Wheels . . . by The_Q42
Started on: 01-07-2021 12:42 PM
Replies: 18 (813 views)
Last post by: The_Q42 on 09-02-2021 12:36 PM
The_Q42
Report this Post01-07-2021 12:42 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi. I know there are probably a whole bunch of threads on this, but I wanted to get the community's thoughts on these wheels: https://www.tirerack.com/wh...&autoModClar=Premium
Will they fit (and fully turn)? Anyone use these, or similar Sparco wheels?
Edit: tried to edit the URL to something that might be more likely to work for everyone . . .
[This message has been edited by The_Q42 (edited 01-07-2021).]
Total ratings: 463
Report this Post01-07-2021 12:58 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just based on the size, width, and offset, I'm thinking they'll fit just fine, and will look good, too.
(I had to doctor the url that you posted, in order to get the link to work. It doesn't want to post here.)
Edit - This is the part #. Google will bring it up. W29071500ILG
[This message has been edited by Raydar (edited 01-07-2021).]
The_Q42
Report this Post01-07-2021 01:58 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! Tried to edit it. Yeah, Iv'e seen others put 17" wheels on, but thought it wouldn't hurt to ask here on the thread. I don't want a crazy narrow sidewall, but also want to increase my contact patch a bit, and give myself some additional stability/traction. The tires that came on my little project car have some rot on them, so I'm going to need to swap the wheels sooner than I originally planned. So, I'll have nice new wheels on a beat up car in need of restoration and paint, but hey, I have to be able to drive the thing to and from the storage facility to work on it. :-)
cvxjet
Report this Post01-07-2021 02:48 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are heavy wheels (Over 20 lbs each)....A while back I went to a new wheel/tire package; From 15 x 7 215/60 and 225/60 BFG comp TAs to 16 x 7 205/55 and 225/55 General G-Max tires- I took 3 lbs off each rear and 6 lbs off of each front corner- The difference was hard to believe. The car rode better, accel' and braking performance improved and it felt much more modern/advanced/refined. Later I made the mistake of going with some BFG G-Force sport comp tires that were 2 lbs heavier per corner- felt like the car was club-footed!
I am now back with the G-max tires and it feels much better again. Try to find some lighter wheels- it will really make a difference...The Sparco Asseto Gara is 18.8 lbs which is an improvement....and only $20 more per wheel...But look around- you may find something even lighter. (TR has some lighter wheels if you have a bazillion bucks to spend....)
Total ratings: 463
Report this Post01-07-2021 08:02 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both of my cars have 17x8, 35mm wheels on the rear. The fit is (IMHO) ideal.
The fronts are 17x7, 38mm on one car, and 17x7, 48mm on the other. (Both are 88s, that require the goofy offset for the front wheels.)
It is my opinion that 35mm offset is ideal for 84-87 Fieros, on all four corners, with anything up to 8" width.
17s are (again IMHO) perfect for the Fiero. They are large enough to be able to fit "modern" (i.e. less expensive) tires, but also allow for a "tall" enough sidewall so that you don't get beat to death by imperfections in the road.
Generally, anything that will fit the first generation of the VW "new Beetle" will be ideal for a pre-88 Fiero.
The_Q42
Report this Post01-08-2021 12:04 AM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ah, really good point about the weight--I missed that. Those are pretty heavy.
cvxjet
Report this Post01-08-2021 01:23 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I also would like to point out that even a loaded Fiero's empty weight would not be above 2800 lbs...Take a newer (C7) Grand Sport Vette which weighs over 3500 lbs...The ratio is 1.25 to 1.....So the Vette's 285 front and 335 rear tires become 225 and 265........I like really wide tires but don't go overboard and end up with a car that doesn't function well.
Most of the guys I was around growing up were into straight-line drag racing where you really don't care about anything except Power and Traction (in the rear).....I was always into handling so wide tires front and rear but those fronts would really start creating problems because of steering. I slowly realized that those really good looking WIDE tires would create a whole set of conditions that you then need to deal with; Fitment, obviously, overloading your suspension, and then as I mentioned, weight...
Just something to consider...
Daryl M
Report this Post01-08-2021 10:29 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is 20 pounds allot for a wheel? I looked just now and it was hard to find larger wheels under 20 pounds.
cvxjet
Report this Post01-08-2021 12:39 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem with large diameter wheels on older cars is that the suspensions were never designed to deal with all of that weight; Modern (Big wheel) cars have all-aluminum suspensions, and the shocks are more advanced which helps to eliminate the effects of those heavy wheels.
If you could get aluminum spindles and A-arms then that would improve what happens with a Fiero when swapping in heavy wheels. And of course, the new performance cars (Vette/Camaro/Mustang) all have active shocks.
This above only addresses the vertical suspension movement of the suspension and wheels...But then there is the ROTATIONAL effect that extra mass has- If you have a 400 hp engine then it would be negligible....But adding 40 lbs of extra weight on your wheel/tire package can kill a lot of the performance of a 140 hp Fiero.....40 lbs rotational mass EQUALS 200 lbs on the chassis...I notice a drop in performance when I have my GF in the car (No, she is NOT 280 lbs! She is only 124)
16 inch wheels are very easy to find light alternatives- I have some VOXX Monzas that are beautiful and light at 14 lbs....Once you go to the big wheels (17s) you start to have difficulty with finding light weight wheels. They have lots of 17" wheels around 20 lbs but to get lower weights you have to pay more; the Enkei RPF 1 weighs 14.8 (17 x 7) and 15.6 (17 x 8) but they cost $261 and $275. NOTE; Tirerack shows few wheels under "Fiero"...Try searching "Subaru BRZ" (Only difference is more offset- which is GOOD)
Another good thing about these wheels is that they have more offset (42 or 45)- Up front that will reduce your scrub radius which will lighten the steering and cut back on the kick-back you feel through the steering wheel. Out back you can add a spacer to move the tire/wheel out a bit.
(I had 30 mm back spacing on the 15s, then swapped to the VOXX 16s which had 38 mm...Big difference (Although some would be from the slightly narrower tire (215 down to 205)...When I was installing the 88 brakes up front, I added back approx' 10 mm (Thickness of the hub of Vette 12" disc) and the steering was bad...Then I got a set of Aluminum hubs from Sluppy123 with 10 mm backset and the steering was good again.
[This message has been edited by cvxjet (edited 01-08-2021).]
The_Q42
Report this Post01-08-2021 05:14 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, but how heavy were the stock wheels? Has anybody weighed GT wheels? I imagine they were fairly heavy (OEM wheels usually are/were, especially in the 80s). Maybe at least 18 lbs? My project car doesn't have stock wheels on it, or I'd weigh them (the ones on there now are crap, hence me buying wheels AND tires instead of just tires). They're currently 205/60 R16s. I'm not against sticking the 16" realm to keep the weight down either, though I do want to shrink the side-wall a LITTLE to get better stiffness in the corners (I live in Ohio, so there's gotta be SOME sidewall in there).
To me, one of the best things about this car, in terms of potential, is it's ability to handle (with a low CG, and mid-engine layout). To that end, I don't want to kill my handling with wheel choice. I also plan to overhaul the suspension with coilovers all around and beefier sway bars, front and rear. Maybe I'll do even more on the suspension too--dunno yet. :-)
So, with all that in mind, I'm not sure which wheels to pick :-)
[This message has been edited by The_Q42 (edited 01-08-2021).]
cvxjet
Report this Post01-08-2021 05:58 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a pic of my Fiero with the 16 x 7s and 205/55 and 225/55 tires.....Also, I did some odd-ball things with mounting my stabilizer bars to improve BOTH turn-in and DTO...Here is a link to my thread on that; https://www.fiero.nl/forum/Forum2/HTML/140674.html
The_Q42
Report this Post01-09-2021 04:57 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the info cvxjet, it's sincerely appreciated. For the size/weight of the car, I'm betting that the trade-offs in weight might not be worth it to go to 17"s. I'm actually less concerned with aesthetics than I am performance. I mean, I want it to look nice, but I care a lot more about how it handles :-)
Report this Post01-11-2021 08:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I may be permitted to chime in. My 3800SC Fiero has 7.5" W 17" wheels w 35mm offset 225 x 45-17 Rear and 205 x45 x 17 front. My wheels weigh about 18 lbs. The performance and handling is great but the ride is much harder than stock especially when I had the KYB shocks on the front. Changing to Monroe shocks did soften the ride a little. IMO, 17" wheels have a nice look that makes the Fiero look more modern but at a cost in ride. Side walls are 4" and 3.6"
On my next project I will use 16" wheels 225 x 50 -16 R and 205 x 50 -16 F Side walls are 4.4" and 4"
With these tires you only give up .4"- .6" on the sidewall.
Stock Fiero tire sidewalls are 5.1" and 4.8" .
Side wall comparison
Stock 15" 5.1" and 4.8"
16" tires 4.4" and 4"
17" tires 4.0" and 3.6"
Conclusion that extra side wall rubber makes a BIG difference in the ride..
[This message has been edited by Dennis LaGrua (edited 01-11-2021).]
The_Q42
Report this Post01-13-2021 12:51 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still REALLY curious about how much the stock wheel weigh . . . but, yeah, I get the ride quality thing. I'm still thinking I'll have better tire availability with the 17" wheels going forward though, since I'll be putting high performance summer tires on there.
[This message has been edited by The_Q42 (edited 01-13-2021).]
The_Q42
Report this Post05-18-2021 02:35 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Reviving an old thread to ask a question . . . I notice, in combing through a lot of old threads, that a lot of you (if not most of you) put wider tires on the rear. I know the principles of putting a fatter set of tires on the rear (maybe 16 x 8?), but, on the Fiero, I'm wondering if it makes a ton of difference? I DO plan on a motor swap in the future (I'll probably start with an NA 3800 Series II or III, then turbo it further down the road), so more grip in the rear would be nice, but I'm just wondering how much a difference it'll make.
I've had a car with difference size tires on it in the past and, while it's manageable, it's a bit less convenient for obvious reasons. :-)
To keep the weight down, I'm thinking 16" wheels, so that'd probably mean 16 x 8 in the rear and 16 x 7 in the front. 17" wheels that are ALSO light are bloody expensive, even though they do look quite nice.
I want handling out of this thing (I'll be doing suspension upgrades in the future too), and I'm not doing a drag racing build.
So, let's vote, should I buy:
1. 17 x 7.5 all four corners
2. 17 x 7.5 front, 17 x 8 rear
3. 16 x 7 all four corners
4. 16 x 7 front, 16 x 7.5 (which seems rare) rear
5. Some sizes I haven't thought of
I really, really only want to buy wheels ONE time, so I'm trying to be careful with this purchase. :-) Help me, Fiero community! You're my only hope!
[This message has been edited by The_Q42 (edited 05-18-2021).]
Total ratings: 463
Report this Post05-24-2021 12:19 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It really depends upon whether you want to be able to rotate your wheels/tires or not.
Most every GT suspension 86 and later had staggered tire sizes. In addition to that, the 88s had staggered wheel sizes as well. So GM saw a need...
With that said, probably one of the hardest drivers in our club (Yeah... YOU, Charlie) has the same size tires and wheels on all four corners of his 87 GT, on stock 15" wheels, and can still outrun most of us on a twisty road. Other than the 3.4 swap, the car is essentially stock, but very well maintained.
Edit - My own preference is for 7" wheels on the front and 8" on the rear, but that even further limits my choices for an 88.
[This message has been edited by Raydar (edited 05-24-2021).]
thesameguy
Report this Post05-25-2021 05:06 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure it applies here, but the track day types with modern cars who have staggered setups from the factory generally say the same thing: The staggered setup looks nice and improves stability for average drivers, but the hot ticket for RR/AX is generally matched tires... these guys want the rear end a little more dynamic than most.
cvxjet
Report this Post05-25-2021 07:29 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have always done something with my tires; In reading a whole bunch of C&D, R&T MT etc, I realized some dynamic things with tires and wheels. You can balance handling on just about any car with the same size tires front and rear- especially for general cruising and basic driving.
If you want a car that is dynamically well set up, then you need to recognize a few things. If you have low powered car, you don't need super-wide tires out back, but as your HP climbs, you will need more traction in the rear. Also, if you have rear weight bias (MR or RR cars) then it works better to have wider tires out back.
What I thought and then did on my Comet GT, 73' mach 1 and even my 1999 Formula, was same width wheels front and rear, but one size wider tires out back; the front tire is "Tight" on the wheel which gives good feel and fast response, while the slightly wider tire out back gives you more traction (for HP and/or weight)
On my Fiero I went TWO sizes wider in the rear (205 front, 225 rear) and this really seems to work well. I also dialed in as much caster as possible (Approx' 5*) plus 1* of camber, which makes the front tires stick better.
The setup I have works so dang well it is just amazing- I wish I could go back to when the car was new/stock and compare the two- I think it would feel like two completely different cars. I did have a race driver friend test drive my car- he was impressed with how it handled- only "Complaints" were the heavy steering at parking speeds and the rear shocks(Konis) were a little on the soft side.
Extra info; On my Comet GT I had 235/60-14s on 14 x 8 wheels up front. If you measured the tires width/sidewall height, it actually became a 55 series tire on that rim.
If you are going to drop a bunch of HP into the car (Plus extra rear weight, you then may need a much wider rear tire (Say around 245-265 mm)
The_Q42
Report this Post09-02-2021 12:36 PM Click Here to See the Profile for The_Q42Send a Private Message to The_Q42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, all!
I'm reviving this thread with what I think I might buy, and wanted to get thoughts. First, a few housekeeping things:
  1. Thank you all so very much for the detailed feedback to my original question--it was super helpful.
  2. For now, I think I'm going to roll with the same size wheels all around because, even after my power-train swap (several years down the road, probably), I won't be shooting for insane HP. My plan is to drop a 3800 N/A in there and get that up to ~250 HP (no more than 300), and I'll be a happy camper--not sure how I'll do that yet (maybe a turbo, maybe not), but that's the current plan.
  3. With that in mind, I tried to find something that'll offer me good tire choice (want decent performance tires) and grip without sacrificing handling. I also want them to be (relatively) light, especially since I'll be driving around with the 2.8 for a while. I'm going the same size all around (for now) because I just don't need the fat tires on the back yet, and it'll make buying tires easier in the short-to-mid-term.
With all of that in mind, I'm thinking about buying these: Enkei TFR 17x8 with a 45mm offset (maybe too much?). HEre's the link: tirerack.com/a.jsp?a=EA6&url=/wheels/WheelCloseUpServlet&autoMake=Subaru&autoModel=BRZ&autoYear=2018&autoModClar=Limited&target=runWheelSearch&wheelMake=Enkei+Tuning&wheelModel=TFR&wheelFinish=Copper+Painted&initialPartNumber=5167808045COP&showRear=no
I'm very interested in what the community here thinks. Anyone running a similar setup? Based on the above--8" might be too wide?
Edit: because of the many redirect services involved, you'll need to copy/paste the TEXT of the URL to go to it (sorry).
[This message has been edited by The_Q42 (edited 09-02-2021).]
