  How to remove small front fascia molding?
How to remove small front fascia molding? by ninedriver
Started on: 01-14-2021 05:25 PM
Replies: 5 (294 views)
Last post by: ninedriver on 01-15-2021 12:22 PM
ninedriver
Report this Post01-14-2021 05:25 PM Click Here to See the Profile for ninedriverSend a Private Message to ninedriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like the subject says. How do I remove the front fascia molding so I can paint it? The small piece forward of the indicator light molding.
Thanks
fierosound
Total ratings: 286
Report this Post01-14-2021 06:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has a nut on the back (same as nose emblem)
Spadesluck
Report this Post01-14-2021 06:34 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the best way to get to that nut with the bumper still on is to remove the inner wheel well plastic. Then you will be able to just reach in.
Total ratings: 154
Report this Post01-14-2021 11:15 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depends upon the year. I think there was at least 1 year that it was a cast part of the fascia.
ninedriver
Report this Post01-14-2021 11:20 PM Click Here to See the Profile for ninedriverSend a Private Message to ninedriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply’s. Tomorrow I’ll check if I can access it behind the wheel well plastic. I’d like to avoid removing the front nose.
ninedriver
Report this Post01-15-2021 12:22 PM Click Here to See the Profile for ninedriverSend a Private Message to ninedriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spadesluck, as advertised. Reached in through the wheel well to access the nuts, thanks for the tip!
