  Modify upside-down Cadillac Seville rear calipers for easier bleeding (GA, LeBaron )
Modify upside-down Cadillac Seville rear calipers for easier bleeding (GA, LeBaron ) by pmbrunelle
Started on: 02-02-2021 11:56 PM
Replies: 8 (525 views)
Last post by: Frenchrafe on 02-05-2021 04:52 AM
pmbrunelle
Total ratings: 63
Report this Post02-02-2021 11:56 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps you are using the Seville caliper with a Grand Am or LeBaron rotor in the rear...
GA:
https://www.fiero.nl/forum/A...14-2-083566.html#p28
LeBaron:
https://www.fiero.nl/forum/A...120111-2-109042.html
In many installs, the brake cable is routed below the CV joint, which results in the bleeder screw at the bottom of the caliper. As a result, air bubbles trapped inside the caliper cannot rise and exit through the bleeder. Typically, you have to unbolt the caliper and orient it right-side-up; it's a kludgy manoeuver.
With these brake setups, the banjo bolt is near the top... if only the air bubbles could escape via the banjo bolt, then the caliper could be bled in-situ.
For those that aren't aware, here is a banjo bolt bleeder :
In this writeup, I will explain how I modified my Cadillac Seville calipers to use banjo bolt bleeders.
So far, I have only performed this modification on the bench; road testing won't be for a while.
pmbrunelle
Total ratings: 63
Report this Post02-03-2021 08:58 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is an excerpt from the Goodridge catalog:
  • M10 thread is required (to center the stock 10 mm banjo fitting and copper washers)
  • 1.0 pitch is preferred, but maybe 1.25 could work (easier to cut threads for finer pitch)
  • Stainless steel is nice, but zinc-plated steel should be OK.
  • 20 mm length is pretty much required
I ordered the Goodridge 992-31BNC from the Internet.
  • M10x1.0x20
  • Stainless steel
jjd2296
Report this Post02-03-2021 12:22 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
so do these go in place of the banjo bolt? are you then mounting the brake line in the bleeder location? if so what are you using for that?
pmbrunelle
Total ratings: 63
Report this Post02-03-2021 01:02 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, they replace the Cadillac banjo bolt.
The banjo bleeder bolt still functions in the usual manner to fix the brake line's banjo fitting to the caliper's fluid port. It's like a regular banjo bolt, just with a bleeder built in.
The bleeder location isn't touched... it's just a bleeder that can be used to drain fluid out the bottom, but it doesn't work to evacuate air bubbles.
pmbrunelle
Total ratings: 63
Report this Post02-03-2021 07:24 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
pmbrunelle
Member since Sep 2008
The Seville caliper has an M10x1.5 banjo bolt thread.
The Goodridge banjo bleeder bolt (and others like it) has a thread size of M10x1.0.
Using a Heli-Coil, the original hole can be converted to work with the Goodridge banjo bleeder bolt. Alternatively, one could purchase custom-made banjo bleeder bolts that would be compatible with the Seville M10x1.5 thread.
To align the caliper with the drill press, I screwed an M10x1.5 bolt (head cut off) into the fluid port. Then, I tightened the drill chuck onto the bolt shank.
With the caliper hanging in the air, aligned with the drill press spindle, I adjusted the table to fix the caliper in position.
Once the caliper was fixed in place, I could drill and tap for the Heli-Coil.
I like to align the tap with a cone in the chuck. This keeps the tap straight, provided that you apply a slight downwards pressure on the quill.
I do not recommend installing the Heli-Coil wire just yet...
Looking into the caliper, we find that the banjo hole is not quite at the uppermost point of the caliper cavity. This could cause air to be trapped at the top of the bore.
To rectify this issue, a groove should be cut from the uppermost point of the bore, going towards the banjo bolt. There should be a slight constant upwards slope.
To cut this, I used a 1/4" spherical carbide burr on my Dremel. I also needed a 90° gearbox for the Dremel.
I bought this cheap Eyech gearbox from Amazon:
pmbrunelle
Total ratings: 63
Report this Post02-03-2021 08:13 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
pmbrunelle
Once the groove is done, then the Heli-Coil wire can be installed.
There are two reasons to install the wire after cutting the groove:
1. Prevent damage to the wire while cutting the groove with the Dremel
2. The wire must not penetrate down into the caliper deeper than the uppermost point of the groove. If the wire comes down too low, a high point will be created that could trap air. Until you cut the groove, it's hard to evaluate this.
Likewise, the banjo bolt face must terminate above the end of the Heli-Coil wire, to avoid creating an air trap.
Here is the final result viewed from the inside:
And the outside:
This test fit was performed with new copper washers and an old Fiero brake hose.
The original bleeder remains untouched at the bottom of the caliper.
Spoon
Total ratings: 61
Report this Post02-03-2021 11:06 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very clever concept.
Spoon
pmbrunelle
Total ratings: 63
Report this Post02-04-2021 07:42 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
I just borrowed it from the motorcycle / powersports world!
Frenchrafe
Report this Post02-05-2021 04:52 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another "cheap" way to get the air out of these calipers is just to crack open the banjo bolt when bleeding the system.
A bit messy, but with some rags, an assistant in the car who holds down the pedal and just doing one caliper at a time, I've always had good rear brakes.
"Turbo Slug" - '87 Fiero GT. 3800 turbo. Sticky tyres. Driven hard!
https://www.youtube.com/cha...1wZvWQlkYxTjivW_0XNg
[This message has been edited by Frenchrafe (edited 02-05-2021).]
