  V6 valve springs. Need some help please.
V6 valve springs. Need some help please. by voron.308
Started on: 02-05-2021 10:59 AM
Replies: 7 (441 views)
Last post by: Spoon on 02-06-2021 10:06 PM
voron.308
Report this Post02-05-2021 10:59 AM Click Here to See the Profile for voron.308Send a Private Message to voron.308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings all
v6 stock. i ordered new set of valve spring from fierostore, they don't look like the original. Shields inside is different. Does it matter? Just put new one in or pull shields from the old and new ones and reinstall old shields into new springs?
Help will be greatly appretiated.
Thank you
[This message has been edited by voron.308 (edited 02-05-2021).]
Blacktree
Total ratings: 350
Report this Post02-05-2021 01:59 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The shields probably won't fit inside the new springs, anyway. But it's not a big deal. You can leave them out.
Notorio
Report this Post02-05-2021 07:27 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Knowing that GM would not put in a part that it could leave off and save 2 cents/car, what are the shields supposed to do? There's filtered air flowing through the valve covers, oil vapor, exhaust gas ... presumably these protect the valve stem seals??
pmbrunelle
Total ratings: 63
Report this Post02-05-2021 08:01 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are dampers.
They expand outwards and create friction with the spring's coils as they rub up and down.
The idea is to damp unwanted oscillations/movements of the middle coils.
Here we can see the middle coils of a valve spring moving around:
The damper and spring are made to work with each other, so I would use the GM damper with the GM spring, and your aftermarket damper with your aftermarket spring.
Notorio
Report this Post02-05-2021 10:45 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are dampers ...
Thanks for explaining that and posting the cool video. It's quite amazing how much oscillation there is and I was especially interested to see how much the valve stem tip moves left-to-right as it gets to the top of its travel !!
skywurz
Report this Post02-05-2021 10:51 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would argue modern springs don't have this issue... But wtf do i know.
voron.308
Report this Post02-06-2021 07:02 PM Click Here to See the Profile for voron.308Send a Private Message to voron.308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Gentleman's - Thank you very, very match.
Spoon
Total ratings: 61
Report this Post02-06-2021 10:06 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great video. I watched the whole thing expecting to see a valve drop and disappear into the cylinder.....
Spoon
