Is OK but the "Short end" of main tube still needs support and tie to body or other main tube or can easy blow off either hose as doesn't have bumps/grooves like repair tube has.
Coolant is lube to WP etc. and just 1 clamp even tiny bit loose on plain tube will simple allow hose to slide out the tube unless something else stops this.
Double clamps often won't stop this either.
Others just cut at kink and open tubes, often using exhaust tools, and use 1 hose. Then Have same problem.
SS tube is hard to make anti blow-off bumps by DIY or many "pro's." normal solder and most glues won't stick. Or worse, May seem to work but fails later. Brazing needs Heat, almost same Heat as welding, and can make thin metal to crack.
I had this happen many years ago after someone doing same job to my car. Only thing handy was old windshield wipers and hose clamps... After jointing hose and refill, I used the old parts to tie both tubes by clamping SS flat wire from wiper to the metal tube then bend "wires" so can't move. Been there now for ~ 20 years.
But seems support wire tied "short end" to frame broke and now hanging down so need to tied the up again as weather allows.
