  high idle speed
high idle speed by michael jatcko
Started on: 03-22-2021 01:47 PM
Replies: 8 (746 views)
Last post by: Spoon on 04-19-2021 10:52 PM
michael jatcko
Report this Post03-22-2021 01:47 PM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
is there any other way to lower idle speed, besides of vacuum leaks? I have plug al manifold ports with no change, I vacum all lines off of manifold found one small leak all held vacuum. I changed the egr, idle control valve, throttle sensor. I sprayed with wd40 and with water no change. idles 2000 cold the 1500 hot. I read you can change with the idle control valve? checked brake line good has no cruise control what am I missing?
Report this Post03-22-2021 02:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the engine doesn't stall with your finger covering the IAC port (and throttle closed), you've got a massive vacuum leak... and/or possibly someone has messed with the idle stop screw. (There should be a "plug" covering/hiding the head of this screw.) To take the idle stop screw out of the equation, cover the entire opening to the throttle body with the palm of your hand while the engine is running. If the engine still runs, there is definitely a huge vacuum leak.
[This message has been edited by Patrick (edited 03-22-2021).]
86fierorestoproject
Report this Post03-27-2021 01:08 AM Click Here to See the Profile for 86fierorestoprojectSend a Private Message to 86fierorestoprojectEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does your fiero have cruise control? if so, the module has the cruise control throttle cable, which can be adjusted through 5 different holes. mine had the same problem. i put the cruise control cable on the outermost hole, and it idles at 1200 warm and 1500 cold. (they usually have retainer clips on them, check for that) (credit to 2002z28ssconv for the photo on a post here from 10 years ago) EDIT: also yes i know that picture is of a 2.5 L4 cruise control, but the 2.8 V6 is in the same place.
[This message has been edited by 86fierorestoproject (edited 03-27-2021).]
Total ratings: 291
Report this Post03-27-2021 02:17 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull off spark plug wires one at a time until you get to the target idle speed.
michael jatcko
Report this Post03-27-2021 06:41 PM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
HA HA?
Total ratings: 329
Report this Post04-01-2021 10:32 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A common cause of a high idle is a broken EGR valve pipe/line. They are made of a thin steel and do break.
michael jatcko
Report this Post04-01-2021 10:44 AM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
THANKS. got idle around 800 at coil. tack said 1200?? so good now
Potcrab
Report this Post04-14-2021 11:02 AM Click Here to See the Profile for PotcrabSend a Private Message to PotcrabEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which solution ended up working for you?
Spoon
Total ratings: 61
Report this Post04-19-2021 10:52 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curious, I'm eager to know just how many wires did you pull before you got to 800 rpm?
Spoon
