  Supernatural 3.7L 9,000RPM Project (Page 2)
Supernatural 3.7L 9,000RPM Project by La fiera
Started on: 04-27-2021 09:19 PM
Replies: 196 (6173 views)
Last post by: Spadesluck on 09-04-2025 10:18 PM
fishsticks
Report this Post06-07-2021 08:35 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by La fiera:
I don't know what injectors are you guys using on your engines but I only use these. Bosch EV1 with 4 hole. The spray pattern is not a "pencil" like the regular Fiero injectors everyone uses. These newer injectors spray like a "fan". With that said, The injector's height is strategically mounted to spray right around the intake valve, not on the stem or the intake walls but exactly in the perimeter of the intake valve.
This is actually why I raised the concern, the wider pattern seems like it will put more fuel on the walls of the plenum - specifically on the long wall closest to an injector nozzle.
How much runner length did you end up with? My guess is 3" or less.
La fiera
Report this Post06-07-2021 09:21 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I placed the injectors high enough to umbrella the diameter of the intake valve. The reminder fuel if any, will puddle on top of the valve to make up for the laggy throtle response. I can model this on the MegaSquirt but I can do it much easier and faster mechanically.
I didn't just came up with this intake. I've been working on this for this for 2 years.
La fiera
Report this Post06-08-2021 11:24 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is how the Supernatural concept was born. Here I found some old videos with the old 2.8L ! I forgot about these!! But anyways, you can even hear the sound in engine frequencies diferenciate from stock. That's when I trusted my gut to stay with the iron heads.
Stock Fiero with the old tired 2.8L with 1.6 rockers and TR1 intake.
https://youtu.be/uRf0UgHKJ9E
This is breaking in the rebuilt and upgraded 2.8L
https://youtu.be/PKi-EJPBQmw
Rebuilt 2.8L with cam, head work and same TR1 intake.
https://youtu.be/IyAIFD_LG8Y
As you can see, the interior hasn't changed much!
La fiera
Report this Post06-08-2021 11:43 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
Originally posted by Will:
I note that he didn't show the runner entries inside the plenum... for this to work, those have to be carefully radiused and sculpted. They'll also be quite short, but probably not unreasonably short.
You know that stock injector bong tha takes 1/4 of the intake's entry diagonal? Well, in this manifold it is gone.
Total ratings: 236
Report this Post06-09-2021 07:41 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't think you'd built that box and put it on top of a stock lower....
La fiera
Report this Post06-09-2021 10:03 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know, I just don't have the luxury (money) to do otherwise! I have to spend every penny wisely. This is one man operation relying on side jobs to make my toy make some po'er!. If I had the means of Fishsticks, one blows up and order another one type deal; would be a different story!
[This message has been edited by La fiera (edited 06-09-2021).]
fishsticks
Report this Post06-10-2021 01:48 AM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't let my amibitions fool you. I ain't rich, just motivated. It's been a fire sale here at my place as I sell/trade stuff I don't need. Sold the Vortec heads and all the extra stuff off the new longblock I got. Even sold the cracked 327 block to a guy who wants the rotating assembly.
I still think you're gonna have fuel beading issues on those smooth plenum walls.
[This message has been edited by fishsticks (edited 06-10-2021).]
Blacktree
Total ratings: 350
Report this Post06-10-2021 10:13 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I like about the Falconer lower intake... no injector bungs. Also, there's no cold-start or idle air passages. So the intake ports can be bigger.
It also has a big port on the end, for crankcase vacuum. That's what the blue fitting is for.
La fiera
Report this Post06-10-2021 06:15 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think so. There is way more injector to wall clearance than the intake I'm running now and I don't have any fuel beading issues.
This is the injector aiming straight at the valve. And the little runner that will get some fuel mist is textured.
This is the intake I'm running now. Injector is pointing directly to the intake valve.
This is looking under it, from the intake valve up the intake you can see the injector tip pointing towards it.
Outside view of the injectors orientation.
fishsticks
Report this Post06-10-2021 11:59 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your welds are way nicer than mine.
I agree you're fine in the runner and with injector positioning. I'm worried air rushing into the plenum is going to (partially) disrupt the spray pattern from the injectors since they're so high up and put fuel on the plenum walls.
I have made the world's worst diagram illustrating what I suspect will happen. I apologize in advance for it.
Basically, incoming air is going to ignore the radiused part of the plenum below the TB and head straight for the back wall. You see a similar effect in cylinder head ports, which is why a lot of shaping is done to the ceiling, and sometimes the floor is raised.
I think that airflow is going to push fuel to that back wall, and possibly the other walls of the plenum.
Do I think your design is somehow critically flawed and doomed to failure? Not at all. In fact, I could be flat out wrong. If it were my intake, I'd stick the nozzle of a sand blaster inside there and give the plenum walls a little texture just in case. That's all I'm saying.
Your first manifold appears to have the injectors in the runners still, so I don't see this issue coming up.
Over all, I think you may run into a scenario where the front cylinders run rich and the rear cylinders run lean, and you may have to play with injector timing to compensate. You've given up the individual cylinder tuning of port injection in exchange for charge cooling like a carb or TBI would have.
[This message has been edited by fishsticks (edited 06-11-2021).]
La fiera
Report this Post06-12-2021 02:04 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
That will not happen, this intake is designed to "STALL" incoming airflow speed to maximise pressure and eliminate turbulance inside the plenun so the fuel goes were it is design to go. It is plain physics. I've been modeling this approach for a couple or years now. Same story with the intake I use now, I started that back in 2014.
Blacktree
Total ratings: 350
Report this Post06-12-2021 10:28 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rei has a good point. The air isn't going to fly straight back and bounce off the back wall, like a ping-pong ball. That's not how aerodynamics works. The top part of the plenum will act like a diverging nozzle, and the bottom part will act like a converging nozzle. The middle of the 90-degree bend is where airflow will be the slowest. There might be a dead spot, up in the corner. But I don't think that will push the fuel spray around.
fishsticks
Report this Post06-12-2021 01:17 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
We will agree to disagree then. There's little about a box with sharp corners that's going to do much to shape airflow, and your throttle body opening is too large to cause that plenum to be much of an expansion chamber. Where does this massive charge deceleration happen, especially at significant RPM and high air velocity? "Plain physics" says you'll have a low pressure area that air is going to try to fill as quickly as possible, and also that air likes to travel in a straight path.
You are taking a diagram which I warned was bad (with exaggerations drawn in) literally.
I'm kinda over this, so let me bring one last point up and I'll be on my way.
OEMs, even in performance motors, have been moving point of fuel entry closer and closer to the combustion chamber for decades, to the point that GDI is commonplace now. There are reasons for that - charge precision and detonation resistance among them. F1 cars are on the wagon, so this isn't entirely a CAFE driven move.
What Rei's done is the opposite of that, and he's going to experience situations that were rendered moot by port injection and GDI. But hey, maybe he's found some secret sauce in "plain physics" that everyone else missed.
I HOPE that I'm wrong and he makes 500whp on this thing, but I suspect I'm not.
La fiera
Report this Post06-12-2021 11:45 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, if that's the case airplanes would not fly!
Instead of me drawing what my intake concept is designed to do lets allow a physics simulator to do it.
Velocity and pressures are for reference only but regardless of the values the result is the same, velocity goes up and pressure will drop and vice versa.
And by varying the shape and volume in the plenum you can achieve either result.
https://youtu.be/WFtkAZQCy7A
Incoming velocity= 43.1ft/s @ 8.9psi hi velocity and low pressure
Plenum velocity= 4.6ft/s @ 18.87psi low velocity and high pressure.
That's a 89% velocity decrease and 100+% pressure increase. If an airplane gets this percentages changes on its wings in mid air it would cause the plane to stall and fall to the ground. That's what this intake is designed to do.
Pay attention how the black dots follow the contour or the radius below the "TB".
Joseph Upson
Total ratings: 88
Report this Post06-14-2021 06:58 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I get what you're saying, I don't believe laminar flow over an airfoil (wing) is the best example. All else the same, the same quantity of air would need to flow faster through a smaller throttle body than with a larger throttle body to maintain equilibrium for the same engine output, or to maintain the same flow rate on the backside of a smaller throttle body, the media would have to move at a higher velocity, than with a larger.
Likewise, a larger plenum has more reserve, so the pressure drop as cylinders pull air in from it, will not occur with as much velocity through the throttle body as it would with a smaller plenum, basically, you're less likely to feel one cubic foot of air being sucked out of the back door of a house, while standing in the front door way, than you would while standing in the doorway of a small room as it's being sucked out of a window. So yeah, I can see how inlet air on a plenum that size will not likely affect the fuel injection stream.
Is that correct, or close?
zkhennings
Report this Post06-14-2021 09:23 AM Click Here to See the Profile for zkhenningsSend a Private Message to zkhenningsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let’s also not forget that it is not pressurized air entering the throttle body but a vacuum formed at the mouth of each runner, that alone will encourage the air to bend around the short radius of the intake. As demand increases at higher rpms there will of course be some momentum that the air will have that will send air at the rear wall of the plenum, but I don’t think it will be drastic due to the large plenum volume relative to the size of the intake ports. There will be some vortices that form at the dead spot in the corner that could disrupt the spray pattern, but with each runner demanding air and fuel it should help guide the injector spray where it is trying to go. At the same time I don’t think the suggestion of texturing the walls is a bad idea as regardless of plenum shape, spraying fuel near shiny surfaces will probably result in some puddling of fuel. I just want to hear this thing on the dyno.
Total ratings: 236
Report this Post06-19-2021 09:58 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
OEMs, yes. Not so in motorsport. High RPM race engines with a throttle per cylinder have been using shower injectors ABOVE the throttle plates for a long time. This was every F1 engine before the new turbo era. Also race bikes as well. DI works better with forced induction, which is why F1 cars have DI in the new turbo era.
thesameguy
Report this Post06-22-2021 12:51 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the relationship is the other way.... turbos are better with DI. No?
Total ratings: 236
Report this Post06-22-2021 03:19 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I said.
Notorio
Report this Post06-23-2021 11:33 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to go look at my stock lower to see the injector bongs indeed taking up a chunk of vertical space. So in the much different Falconer intake it must have a different Middle and different Upper as well?
Blacktree
Total ratings: 350
Report this Post06-24-2021 08:30 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Completely different.
Notice how the injectors are way up high. And they're aimed at the intake valves.
Notorio
Report this Post06-24-2021 12:08 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very interesting!
La fiera
Report this Post06-24-2021 01:51 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a DTM Alfa Romeo 155 from the '90s. 420bhp @ 11,500rpms.
[This message has been edited by La fiera (edited 06-24-2021).]
thesameguy
Report this Post06-24-2021 03:11 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It may be worth keeping in mind engines like that don't need to idle well or pass emissions or be terribly reliable or be tractable at low speeds. None of these are obstacles to pursuing your vision, I just think it's important to remember that things that work well on race cars don't always translate to street cars. I've got a friend who's a well-known E30 M3 enthusiast and he'll be happy to tell you why his personal '88 M3 is mostly as it came from the factory and not similar to the DTM cars. 9000rpm is intoxicating but 2000rpm is pretty important for getting to work.
I would probably be looking more towards things like ITRs than AR DTMs.
[This message has been edited by thesameguy (edited 06-24-2021).]
La fiera
Report this Post06-24-2021 03:21 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely! That's why my Fiero is a dedicated race car, not a daily driver.
thesameguy
Report this Post06-24-2021 05:10 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Word. Then who the eff cares?
IMO, this is the best way to approach it. Having to build one size fits all stuff is stressful.
Total ratings: 236
Report this Post06-25-2021 10:41 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Image not showing
Total ratings: 236
Report this Post06-25-2021 10:43 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
My previous Northstar would accelerate uphill from 1000 RPM in 5th gear.
pmbrunelle
Total ratings: 63
Report this Post06-26-2021 10:31 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now that I walk 3100 feet to work, I can think of having a totally impractical car!
[This message has been edited by pmbrunelle (edited 06-26-2021).]
La fiera
Report this Post07-11-2021 08:23 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rotating assembly is finally balanced! Due to the lightweight of the pistons, rings and rods the crankshaft had to be lightened 40g!
Next, the heads. The porting part is done, just waiting to finish the fitting of the new valves!
Blacktree
Total ratings: 350
Report this Post07-12-2021 12:25 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neato.
RandomTask
Total ratings: 150
Report this Post07-13-2021 11:21 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Either this will sound glorious or you'll launch a piston to the moon. Both outcomes should be considered a success.
[This message has been edited by RandomTask (edited 07-13-2021).]
La fiera
Report this Post07-19-2021 09:55 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Random!! The piston to the moon will be very unlikely, I've been doing the math for over a year before making any parts. As far as the glorious sound, I can't wait to hear it because it's never been done!
Skybax
Total ratings: 78
Report this Post07-19-2021 10:09 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blacktree
Total ratings: 350
Report this Post07-20-2021 10:32 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ Those are old photos of it. The intake originally belonged to Kris Munson. After he passed away, his wife sold it to me.
La fiera
Report this Post11-20-2021 10:39 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some progress. Got the block and front cover ready for the upcoming mods. I'm deleting the old cooling pipes and replacing all the rubber hoses to -20 AN lightweight hose.
[This message has been edited by La fiera (edited 11-20-2021).]
Notorio
Report this Post11-22-2021 07:39 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you are still working on this project. Are your new pistons standard bore or oversized?
La fiera
Report this Post11-22-2021 08:37 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oversize.
Blacktree
Total ratings: 350
Report this Post11-23-2021 10:36 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
That front cover doesn't look familiar. What engine is it from? I really like the clean look.
La fiera
Report this Post11-23-2021 11:08 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's off the 3400 roller block. Since I don't use the mechanical water pump I wanted to clean the front of the engine and reduce clutter in the engine bay.
I may have to put a bleeder on top of it once I modify the intake manifold with a -20AN fitting on the thermostat hole.
[This message has been edited by La fiera (edited 11-23-2021).]
