  Supernatural 3.7L 9,000RPM Project (Page 5)
Supernatural 3.7L 9,000RPM Project by La fiera
Started on: 04-27-2021 09:19 PM
Replies: 196 (6174 views)
Last post by: Spadesluck on 09-04-2025 10:18 PM
La fiera
Report this Post06-01-2023 10:46 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil pan and front cover are done. Now I can put the engine and start on the oil lines.
sleek fiero
Report this Post06-10-2023 04:27 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rae now you've got me thinking I should build a dry sump/cooler system for mine. I already have some design ideas for a more efficient intake. I better start Not listening to you because your going to have me using up all my spare time !!!
La fiera
Report this Post06-12-2023 08:55 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Upgrading your engine with ideas is life, everything else is just waiting!
La fiera
Report this Post06-12-2023 09:36 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
It's finished. Now its goint into the car for testing.
Trinten
Report this Post06-12-2023 10:25 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looing crazy man! Like modern art or something!
That's some awesome work on the intake, I can't wait to hear how it performed!
La fiera
Report this Post06-13-2023 10:20 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Trinten! Now I have to install the oil tank and do the hoses.
StreetRod4
Report this Post06-14-2023 11:05 AM Click Here to See the Profile for StreetRod4Send a Private Message to StreetRod4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks awesome!! Can't wait to see some videos on this when you get it all together 😎 Are you planning on lowering the drivetrain at all for a lower center of gravity?
La fiera
Report this Post06-14-2023 10:03 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not on the Fiero. I'm working on getting an Exocet chassis and for it I will definatelly put this engine as low as possible but for this Fiero it is not worth it. I will start the engine with the tunnel ram manifold and once broken in, dialed and dynoed I will change to this intake to have solid comparisons.
La fiera
Report this Post08-24-2023 12:23 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
sleek fiero
Report this Post08-24-2023 10:02 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rae man it sounds so good . can't wait to see it/ you on the track! sleek
La fiera
Report this Post01-17-2024 08:09 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally finished the last touches on the TR6 "Thunder" intake I designed for the engine in the car now. Now is off to the dyno with the TR5 intake to get data and some basic tuning before the "Thunder" is installed and optimized!
https://rumble.com/v3wdg7e-...anifold-design..html
[This message has been edited by La fiera (edited 01-17-2024).]
sleek fiero
Report this Post01-17-2024 09:12 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rae what are the 2 outer pipes and connector line? sleek
La fiera
Report this Post01-18-2024 10:16 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I noticed that with the intake on the car now, when driving it hard with sustained full throttle the intake gets very cold regardless of the temperature outside. Conversely the fuel rails get hot because of their location. So instead of just running long fuel lines that were going to be exposed to the raising heat of the headers which is why the fuel rails get hot now, I opted to add those side fuel rails to keep the fuel cool.
Spadesluck
Report this Post01-18-2024 10:35 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Intake looks great my friend!
Total ratings: 200
Report this Post01-19-2024 08:03 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, that is insane looking!!!
I can only imagine what kind of CFM that thing must be pushing!
La fiera
Report this Post04-21-2024 08:39 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
And a couple of years later!
https://youtu.be/s33RLv5gmbI?si=mhNpJoL5m4wbOEyb
Enjoy the sound!
sleek fiero
Report this Post04-21-2024 11:59 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
so impessive Rae. lots of Pontiac Excitement !!! sleek
La fiera
Report this Post08-29-2024 10:02 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Report this Post08-30-2024 04:44 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/XItOfLzdncs?si=fInL_yg3skEDVmyk
Getting there.
386 whp ... yeah - you're totally 'getting' there! ;-)
Report this Post08-31-2024 03:34 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The power that you getting from the 60* V6 is certainly impressive and I admire your fabrication skills and creativity. It looks like an expensive build and from a standpoint of $$$ spent vs HP gained it would seem that you would have done better with the 3800SC. There is a video of a 3800SC series III engine where a full stack intercooler, improved exhaust and 3" pulley was added and the engine made 425 HP w/o any internal mods.
Total ratings: 200
Report this Post08-31-2024 04:00 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Enjoy the sound!
It sounds amazing!
sleek fiero
Report this Post08-31-2024 06:54 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis the whole point of the 60 degree V6 is it's not a Buick or some other GM engine shoe horned in. It is the correct series of engine the car was designed for and better yet he has done huge hp naturally asperated . Yes it's harder to get these results but when you do there is nothing better. Way to go Rae. I like your style and detemination. For all you that prefer different engines and turbo or supercharging there is nothing wrong with that. To each his own and we all have the car that is the most fun of almost any car ever built. sleek
Total ratings: 200
Report this Post08-31-2024 10:10 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
For me personally, I really like the "sound" of the V6/60. It's such a well-balanced motor when done properly... and this one sounds so fantastic when really wound out. It probably sounds better in person. Really, it kind of sounds a little bit like a Ferrari.
Trinten
Report this Post09-01-2024 02:48 AM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
He has this Fiero in class racing. If he does an engine swap, it changes the class he's in. I think somewhere earlier in this thread (or his other build thread) he talked about the rules of his class, things about the block... maybe the heads? Anyway, that's why he's putting all that work into squeezing what he can from this platform.
La fiera
Report this Post09-02-2024 11:55 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Dennis! But I don't really have skills of fabrication. I see what Fieroguru, Ericjon, Will and Fierobsessed just to name a few have created with their own hands and I envy their skills. The only thing I'm good at is to disassemble stuff and see how I can make them better with unconventional thinking. Everything you've seen that "I've made" is not mine, I just tell my fabricator what I want and why I want it like that and let him do his thing and usually I get exactly what I asked. Sometimes I have to cut the intake in sections and bring it back to him and explain again why I want it this way, but sometimes what I get from him after I tell him what I want is way better than my original design! I grew up listening the the sound of the Formula One engines from the 80's and 90's and out of all of them two got my attention; the old Cosworth DFV from the 60's to 80's and the Lamborghini LE3512 in the 90's. Never liked how those turbo engines sounded muffled by the turbos. Anyways, I did extensive research on the DFV and the Lambo to see what I can learn from it and apply it to the tiny 60 degree V6. And that brings us to how I design the cam timing on my engines.
When I send the cam specs to my local grinder of what I want and what lobes to use for each side the intake and exhaust he just does it. The same cam company with the previous owner refused to do my cams, he was absolutely sure it would not work, the younger guy who bought him out has seen my work and he just do exactly what I want, they are SUPER weird for the veteran cam experts and the young YouTube Certified cam experts of today. It has taken me years to get the engine formula right but its paying off. I got it down to in a science, all calculated but ONLY for the 60* V6 pushrod engine.
And then there is the weight issue. The 60* V6 is much lighter compared to the newer V8's of today.
https://youtu.be/gwdXs0IEO0Q?si=m80m92XCIj-HrCVh
[This message has been edited by La fiera (edited 09-04-2025).]
lou_dias
Report this Post09-03-2024 09:31 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mods are mods. That said, I generally don't compare boosted engines to N/A ones. With the mods we've done to the V6/60 we can spin it to 8000 rpm. I'd somewhat love to see him build a turbo version of his engine someday just for poops and giggles.
That said, it would be a completely different cam and intake design ... not to mention exhaust. As Rei said - his research is for V6/60 N/A.
Perhaps once he's 'done' aka 'gotten there' he can pick a new topic.
sleek fiero
Report this Post09-03-2024 10:29 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou I doubt Rae or myself will ever give up on GM 60 Degree V6 engines. When you get them right they are reliable and strong . It is a challanging and fun engine to work at perfecting and nobody ever said these engines were perfect from the factory!!! sleek
lou_dias
Report this Post09-03-2024 12:52 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
sleek,
By 'new topic' - I meant boosted v6/60. ;-)
Total ratings: 236
Report this Post09-08-2024 07:57 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see what... ...Ericjon...
And then there is the weight issue. The 60* V6 is too heavy compared to the newer V8's of today.
Speaking of Eric, have you been watching what he's doing with roller lifters?
Speaking of weight... There are still BowTie blocks out there. The factory bore size is small for you, though, and I'm not sure if the block can be sleeved larger while maintaining its strength
Edit: With a BowTie block and aluminum heads, you should be able to keep your car with a boosted 3.2 as light as your car with the naturally aspirated iron head/iron block combo
[This message has been edited by Will (edited 09-08-2024).]
La fiera
Report this Post09-08-2024 10:16 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by La fiera (edited 09-08-2024).]
La fiera
Report this Post09-08-2024 10:17 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
I have not!
La fiera
Report this Post09-08-2024 10:21 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
La fiera
Report this Post09-08-2024 11:36 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Will, boost takes away the ingenuity out of building NA engines! That's the trend now, put a turbo on a LS and make 1000hp and call yourself an engine builder, my 15 year old niece can do that and she has no mechanical background. The turbo and intercooler makes up for the weight of the iron heads!
lou_dias
Report this Post09-09-2024 08:57 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
screw it Rei !!! Drop the stroke back down to 3" like he's suggesting with the 3.2 comment using 6.3" rods and spin it to
[This message has been edited by lou_dias (edited 09-09-2024).]
La fiera
Report this Post09-09-2024 10:39 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
How about adding another liter to the 3.2L? Just saying! How does that saying goes? "There's no replacement for displacement". That will make the 60* V6 bigger than a NorthStar 4.0L!
[This message has been edited by La fiera (edited 09-09-2024).]
La fiera
Report this Post09-04-2025 08:28 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the dyno run promised for this 3.7L LR (long rod version) and please forgive me for the lateness, this is just my hobby. I'm working on the short rod version of this 3.7L and I wanted to post this dyno to document my progress. As you can see it is nowhere near 9000rpm and the reason being is that 9000rpms was not going to work on the intended use of the engine. I didn't want a peaky engine, I wanted a torque monster off the line with a wide power band.
As you can see in the previous pictures and in the picture above this engine has "one of" parts no other V6 has, and innovations that no one has tried.
As I make progress with the 3.7L SR I will update it at its appropriate topic, but as of now this engine served its purpose and has been disassembled and put away for later use.
Here is a little break down of some parts:
-Tunnel Ram intake with injectors located 3 inches higher in the runner.
- Solid flat tappet Camshaft .585 intake/ .620 exhaust lift.
-Super light valves and valve train components.
-2 ring package with top ring gapless superlight flat top forged pistons 10.47:1 compression
-6.2 inches A beam connecting rods.
-Lighten crankshaft (-2.4lbs)
-All rotating assembly balanced.
-Dry sump system (12 quarts)
-ATI Super Damper
-Electric water pump
-And much more....!
Spadesluck
Report this Post09-04-2025 10:18 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
