  Intake Manifold / Throttle Body Vacuum Ports: What are they called? Where to buy?
Intake Manifold / Throttle Body Vacuum Ports: What are they called? Where to buy? by reinhart
Started on: 05-02-2021 07:40 PM
Replies: 4 (339 views)
Last post by: reinhart on 05-03-2021 03:47 AM
reinhart
Report this Post05-02-2021 07:40 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to get replacement vacuum port fittings or intake manifold fittings, where would I find them? I'm talking about the metal cylinders that the vacuum hoses go on. I've searched online for "throttle body port" "vacuum port" etc and not getting any hits. I'd like to find both the press in fittings as well as the screw in kind. What's the proper name and where can I buy?
Total ratings: 259
Report this Post05-02-2021 08:27 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hose barb.
Most hardware stores will have brass ones that thread in. The press fit ones are not commonly available, just tap the current hole for a threaded version.
reinhart
Report this Post05-02-2021 11:46 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hose barb has the christmas tree fitting on the end. Looking for the ones like the factory ones with a tube and a flanged end.
Report this Post05-02-2021 11:48 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Vac Ports ON TB TBI and carbs are Part of them and not available any other way.
Other vac ports on other thing are often same.
Vac ports that are "screwed into" intake man are mostly NPT fitting can find at many places, mostly at junk yards.
NPT is US National Pipe Threads.
reinhart
Report this Post05-03-2021 03:47 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
