Hi Everyone - Thanks in advance for any help.
Long time lurker, first time poster.
I know overheating is a (usually) easy to diagnose problem as there is a standard checklist to run through...but I am stuck and could use some help before I start ripping things apart.
V6 Stock- 86K miles and driven with respect.
Problem: Overheats after warm-up, after 15-20 minutes of driving or so. Coolant starts to boil out of the overflow.Hoses are "squishy" with no blockage
Cooling pipes are not pinched
Water Pump has been replaced
Cooling system is burped
Thermostat replaced
Fan kicks on when motor reaches temp
No coolant in oil/spark plugs (a tad of smoke on startup, but I think this is because of the valve seals)
Radiator in good condition
a bit of sludge in the reservoir, but nothing alarming. Could use a proper flush.
Now I am just smart enough to not be stupid... but I don't know what else to check.
Before typing this out - I ran through the list again to mitigate being an idiot (so much for that) and think I have one solution but was hoping for feedback.
When I kick the A/C on while driving, the condenser begins to squeal a
slight amount as if it is seizing up AND when idling the motor struggles to stay above 1K rpm's. And I mean Struggles. But we still have cold air.
Could the condenser potentially seizing really be causing that much stress on the motor/not cool properly to cause it to overheat?
I think this is my last diagnosis before ripping the head off and looking for a blown head gasket or cracked head.
Again, thanks in advance.
-burtman
[This message has been edited by burtman (edited 05-06-2021).]
